SIP-to-SIP through CUBE between CM 6.1 and a SIP provider
valdes.argm
I’m trying to set up a CUBE between our CM 6.1 and a SIP provider for PSTN access. So far I can make a phone outside the PSTN to ring and even pick up the call, but the Cisco phone on the CM side keeps in ring out state and obviously there is no audio.
I set up the transcode on the same 2801 that host CUBE, but I think I still have a signaling problem.
Do I miss something at the router's config? Thanks.
Building configuration...
Current configuration : 4842 bytes
! Last configuration change at 15:27:29 AR Tue Jun 5 2012 by servicio
! NVRAM config last updated at 15:33:39 AR Tue Jun 5 2012 by servicio
version 12.4
service sequence-numbers
hostname CUBE01
boot-start-marker
boot system flash c2801-ipvoice_ivs-mz.124-24.T6.bin
boot-end-marker
logging count
logging message-counter syslog
logging buffered 200000
logging rate-limit 10000
no logging console
enable secret 5 *************************
no aaa new-model
clock timezone AR -3
ip source-route
ip cef
no ip domain lookup
ip domain name avvid
no ipv6 cef
voice service voip
address-hiding
allow-connections sip to sip
fax protocol cisco
sip
  midcall-signaling passthru
voice class codec 20
codec preference 1 g729r8
codec preference 2 g729br8
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice translation-rule 10
rule 1 /^************\.*/ /\1/
voice translation-rule 20
rule 1 /^*********[*,*]$/ /****/
voice translation-profile Strip
translate called 10
voice-card 0
dsp services dspfarm
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.0.0.9 255.255.255.0
duplex auto
speed auto
no cdp enable
no mop enabled
interface FastEthernet0/1
ip address [public ip] 255.255.255.240
duplex auto
speed auto
no cdp enable
ip forward-protocol nd
ip route *.*.*.* 0.0.0.0 *.*.*.* name DG
ip route 10.0.0.0 255.255.252.0 10.0.0.1 name LAN
ip http server
ip http authentication local
control-plane
sccp local FastEthernet0/0
sccp ccm 10.0.0.9 identifier 1 version 5.0.1
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
associate profile 2 register MTP-CUBE01
associate profile 1 register TX-CUBE01
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
associate application SCCP
dspfarm profile 2 mtp
codec g711ulaw
maximum sessions software 100
dial-peer voice 10 voip
translation-profile outgoing Strip
destination-pattern 0170.+
progress_ind setup enable 3
progress_ind progress enable 8
voice-class codec 20
session protocol sipv2
session target ipv4:[SIP server]
dtmf-relay rtp-nte
no vad
dial-peer voice 2 voip
answer-address 0170
voice-class codec 1
dtmf-relay rtp-nte digit-drop
dial-peer voice 20 voip
session target ipv4:10.0.0.10 /// Call Manager's IP
incoming called-number **********[*,*]
dtmf-relay rtp-nte
gatekeeper
shutdown
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 4
sdspfarm tag 1 TX-CUBE01
max-ephones 1
max-dn 1
ip source-address 10.0.0.9 port 2000
max-conferences 4 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Jun 05 2012 10:26:09
line con 0
exec-timeout 60 0
timeout login response 60
login local
line aux 0
line vty 0 4
exec-timeout 60 0
login local
scheduler allocate 20000 1000
no process cpu extended
no process cpu autoprofile hog
ntp update-calendar
end
15 Replies 15
Ayodeji Okanlawon
This sounds like when the call is about to connect cube needs a xcoder and it cant find one..
Can you please confirm what the region between the phone and CUBE is?
can you send the ff: debugs
1. debug ccsip all
2. debug voip ccapi inout
3. Can you pls put a brief description of your device ips, so i can know the call flow better
Please rate useful posts
"I am complete in God, God completes me"
Please rate all useful posts
The phones and CUBE are on the same LAN (that’s what you mean with region?), and CUBE has the other ethernet port of the 2801 direct connected to internet with a public IP, at least for now during testing.
I have a file with the log of a test call with the debug options enabled, but they are very long, do I paste here anyway?
And what do mean with “brief description of your device ips”? Sorry, maybe because of my poor english or technical skills I don’t understand what you ask for.
No, dont post them here..put them in a text file and attach them here.
By region I mean what region in cucm is the sip trunk and the phone set to use. Ie what codec is defined between these two devices. Its either g711 or g729 and this is usually configured in the region settings
By Description, I mean what ip address is for your cube, your cucm etc
I found the attach option in the reply, sorry. The log is attached now.
The SIP trunk is configured to use g711ulaw codec in CUCM and the SIP provider needs g729r8, this is one of the needs for CUBE. The phones use g711ulaw too. And because of the transcoding needed the 2801 has DSPs on it.
The CUCM and CUBE are on the same subnet, in fact they are at IP .10 (CUMM) and IP .9 (CUBE). And the phones are at the same subnet too.
+++Ok here is what we see+++Calleg to ITSP uses g729
008775: Jun  6 12:04:51.835: //160/A1B9EEDA83C3/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g729br8
Negotiated Codec Bytes   : 20
Nego. Codec payload      : 18 (tx), 18 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): [public IP]
Source IP Port    (Media): 0
Destn  IP Address (Media): [SIP provider media IP]
Destn  IP Port    (Media): 19224
Orig Destn IP Address:Port (Media): [ - ]:0
+++Call from cucm uses G711+++++ (on this calleg no codec was negotiated)
008733: Jun  6 12:04:51.815: //159/A1B9EEDA83C3/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Source IP Address (Media): 10.0.0.9
Source IP Port    (Media): 17052
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
+++Here we see CUBE saying the call needs a xcoder and it actually sent its stream to a xcoder so cube found a xcoder++
need transcoding for codec mismatch
008568: Jun  6 12:04:45.460: //159/A1B9EEDA83C3/SIP/Info/sipSPIDtmfTranscoder: local DTMF 6, peer DTMF 6
008569: Jun  6 12:04:45.460: //159/A1B9EEDA83C3/SIP/Info/sipSPIDtmfTranscoder: local codec 5, peer codec 12
008570: Jun  6 12:04:45.460: //159/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_stream:
008571: Jun  6 12:04:45.460: cc_api_set_xcode_stream Line: 4556
008572: Jun  6 12:04:45.460: //159/A1B9EEDA83C3/SIP/Info/ccsip_do_xcode_stream_ind:
So what it looks like is that the CUBE can talk to the xcoder (beacuse its local to it) but the phone cant...
Can you go to the phone and check the device pool on the phone. Can you also check the Region assigned to the device pool
Can you do the same for the cube sip trunk and then ensure that the region setting between the region if they are different is g711.
can you also send a sh dspfarm all from cube..
The SIP trunk was on different device pool and different region, I move it to the same device pools of the phones now.
I make another test call and still see the same codec mismatch error that thank to you I now about it now, I attach a new log.
Here is the sh dspfarm all output:
ARGMCUBE01# sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 1, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP   Status : ASSOCIATED
Resource Provider : FLEX_DSPRM   Status : UP
Number of Resource Configured : 4
Number of Resource Available : 4
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Codec : g729r8, Maximum Packetization Period : 60
Codec : g729br8, Maximum Packetization Period : 60
Profile ID = 2, Service = MTP, Resource ID = 2
Resource Provider : NONE   Status : NONE
Number of Resource Configured : 100
Number of Resource Available : 100
Hardware Configured Resources : 0
Hardware Available Resources : 0
Software Resources : 100
Codec Configuration
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    1   24.3.6   UP     N/A  FREE  xcode  1      -         -         -
Total number of DSPFARM DSP channel(s) 4
CUBE01#
Did you reset the sip trunk?
Do you know how to get cucm traces? if so can you send cucm traces..that will really help
when you do a test call can you send the ff: from the cube
sh voip rtp connection
sh dspfarm sessions
In fact CUBE is able to invoke XCODER. But in your debugs I can't see 200OK response from SIP Provider. This means that remote phone didn't pickup the call. SIP Provider is sending to CUBE 183 messages only then CANCLE message from provider. If the remote phone pickup the phone, ideally, SIP Provider should provide you with 200OK message.
Are you sure that remote phone is answered? If yes, then you need to escelate this to your ITSP since they aren't forwarding 200OK message to you.
I also observe that the provider is not sending 200 ok. But I observed that he said he could pickup the call. That suggest that he is calling the phone himself and he is picking it up.
So Yes Can you clarify that you are picking up the call..as we do not see a 200 ofter the session progress
You are correct, I’m calling to my cell phone and I pick up the call, but the phone on my desk still ringing out. If I hang up on the cell phone the desk phone still ringing out. If I hang up on the desk phone, then the cell phone yes disconnect the call.
The no 200OK message and still getting the 183 problem could be a bug at the CUCM as mentioned here:
http://comments.gmane.org/gmane.comp.voip.cisco/33626
Because my CUCM is version 6.1.2.1000-13, I enable the option to require MTP for the SIP trunk at the CUCM, and also create a DSP profile for MTP on the CUBE, but this part I’m not sure if is working properly.
I will try with the CUCM traces to see if there is a problem with this leg. It’s possible that the provider keeps at 183 messages because there is no RTP in the other leg between the phone and CUBE?
I forgot to mention that I reset the SIP trunk after changing the device pool, and after the first call test and the same error I reset the CUBE, just in case…
Its not a bug in your CUCM. Your provider isn't sending 200OK as we can see on CUBE. This is still before reaching CUCM.
This needs to be fixed first then we can go further.
Also, I don't see bind source-interface command in your SIP service configuration which is mandatory. Please add this as well.
Ok, and this is something I need to troubleshoot with the SIP provider right?
Yes speak to them and we can take it from there
