02-08-2016 09:34 PM - edited 03-17-2019 05:48 AM
I configured SIP trunk between cluster A and cluster B. Calls from cluster A go through cluster B but not other way around. When I dial a number of cluster A from cluster B, the phone displays enter number in the lower left corner of the display and after a while I get reorder tone.
I tried DNA tool to analyze the call flow. When I put the destination number matching with the route pattern, I get the following error: I do not get error if I put the number not matching with the route pattern. (of course calls will be blocked in that case). Any help will be very much appreciated.
type: Exception report
message:
description: The server encountered an internal error that prevented it from fulfilling this request.
exception:
NullPointerException
note: The full stack trace of the root cause is available in the logs.
Solved! Go to Solution.
02-08-2016 10:04 PM
In clusterB, can you please get SIP traces to check if INVITE is going out from clusterB or not...
- Vivek
02-08-2016 09:45 PM
02-08-2016 10:04 PM
- Vivek
02-09-2016 08:21 AM
Thanks Vivek. I had to engage TAC to take a look. The issues was with the trunk in the cluster A rather than B. And the solution was a simple reset of the trunk :(
He did collect traces and that's how he found out the need for resetting the trunk.
02-09-2016 08:41 AM
Sometimes even simple problem wants typical solution. Thanks for updating us back.
- Vivek
