06-14-2012 12:26 PM - edited 03-16-2019 11:40 AM
We have configured a trunk with a provider using CUBE.
Callmanager--------CUBE--------Provider
The provider wants early offer and G729r8
So we configured a SIP trunk with a device pool/region so that only g729 is allowed between SIP trunk and the rest.
We have configured an IOS MTP resource, and this is registered on callmanager:
dspfarm profile 2 mtp
codec g729r8
maximum sessions software 20
associate application SCCP
The mtp resource is assign to the trunk using MR-list and MR-group
The trunk has MTP enabled with "MTP prefered Codec" G729b/G729ab
On CUBE we enable "deb ccsip mess" and we see the invite comming from callmanager, but without attached SDP
What must be done to make callmanager use early-offer?
Thanks for the help,
Jan
09-03-2013 12:56 PM
Yes, I have the SIP Trunk between CUCM and CUBE.
I change the dial-peer to:
dial-peer voice 2 voip
description # Call Leg VOIP #
session protocol sipv2
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte digit-drop sip-kpml
But not working.
Attached logs.
Thanks!
Joao.
09-03-2013 01:08 PM
The call is still sent to MTP not the fax device. What do you have configured on your sip trunk dtmf method? Is it rfc2833 or no preference?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
09-03-2013 01:11 PM
no preference.
Thanks!
Joao.
09-03-2013 01:14 PM
ok..Can you go to the ATA187 config on cucm and check if you have the option of "RFC2833 enable"..If its there please selct the tick box and reset the phone then test again
09-03-2013 01:21 PM
In ATA187 don´t have this option.
Have (Require DTMF Reception) uncheck.
Thanks!
09-03-2013 01:39 PM
I attached new log fax_problem_log4.txt.zip
IP ATA187 is 21.10.0.14
In log IP the ATA is ok in RTP.
v=0
o=CiscoSystemsSIP-GW-UserAgent 4424 2824 IN IP4 21.10.0.3
s=SIP Call
c=IN IP4 21.10.0.14 -->IP ATA187
t=0 0
m=audio 16386 RTP/AVP 8 101
c=IN IP4 21.10.0.14
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
Thanks!
Joao
09-03-2013 02:11 PM
You need to look at your ATA confgiuration properly. It looks like its not setup correctly for T38..
When CUBE send a re-INVITE with t38 parameters, CUCM doesnt respond correctly..It send an IP of 0.0.0.0 and no T38 parameterd advertised
Received:
SIP/2.0 200 OK
Via: SIP/2.0/TCP 21.10.0.3:5060;branch=z9hG4bKE3ADC3
To: "ATA187 Core" <6001>;tag=24797~fb89236f-816b-47f5-8c94-b8d3c388dd7c-646653136001>
Date: Tue, 03 Sep 2013 20:30:04 GMT
Call-ID: 96aae900-226146c3-c42-7000a15@21.10.0.7
CSeq: 102 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Allow-Events: presence, kpml
Supported: replaces
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Session-Expires: 1800;refresher=uas
Require: timer
P-Asserted-Identity: "ATA187 Core" <6001>6001>
Remote-Party-ID: "ATA187 Core" <6001>;party=called;screen=yes;privacy=off6001>
Contact: <6001>;+sip.instance="
Content-Type: application/sdp
Content-Length: 240
v=0
o=CiscoSystemsCCM-SIP 24797 2 IN IP4 21.10.0.7
s=SIP Call
c=IN IP4 0.0.0.0
b=TIAS:64000
b=AS:64
t=0 0
a=ptime:20
a=inactive
a=fmtp:101 0-15
09-03-2013 02:46 PM
ATA187 configured for T38 fax relay.
Thanks.
Joao.
09-04-2013 04:21 AM
I also had several ATA187 which worked perfectly with an ISDN PRI line.
Then customer switched to SIP trunk and faxes didn't work anymore.
Didn't want to spend to much time on it and configured pass-thru, and faxes work perfectly again.
JH
09-04-2013 07:20 AM
Hi JH,
I change to pass-thru, but not working!
Thanks for help!
Joao.
09-04-2013 07:26 AM
You have to change to pass-thru on the ATA187 and the cube
fax protocol pass-through
Bye,
Jan
09-04-2013 07:29 AM
Yes, in ATA and CUBE.
Bye!
Joao
09-04-2013 07:25 AM
Hi Aokanlawon,
In ATA device config for T38 is correct.
I collect debug ccsip all and attached logs, if you can analyze.
Thanks for help!
Joao.
09-19-2013 12:16 PM
I solve the problems
In my case the ISP incomming SDP messages with first m-line with fax informations, and second m-line with rtp. Cube return to CUCM malformed packet and disconect the call.
I change in CUBE for SDP messages pass-thru for CUCM, CUCM was enable to invite SDP messages (SIP Profile), CUCM don´t have problems with this, fax and dtmf working.
cube:
sip
pass-thru content sdp
thanks for help!
