SIP trunk from 2821 to Mitel 3300
Hi All,
We need to setup a SIP trunk between ISR 2821 and Mitel 3300. Anybody has done this before? Any recommendation? Any sample config? Any underwater stone?
Thanks!
12 Replies 12
testeven
Hi!
Check this link, it includes info on how to connect a Mitel PBX with CUCM using SIP as well as features supported, limitations and configuration:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/678773.pdf
Hope this helps! :)
Regards, Tere. If you find this post helpful, please rate! :)
Thanks a lot for the answer. I have seen this link before - unfortunately it is not what I am looking for. It is about sip between Mitel and CUCM and I am looking for the info about sip between Mitel and 2821 router. But thanks anyway :)
Did you every find an answer to this? I have the same thing.
thanks
Hi, now, nobody came back to me so I had to it myself from scratch. Anyway, it was successful - it works :)
Would it be possible to share your sip config? or any gotcha's you ran into?
No, I did not use this document at all.
Hi, here below are the SIP config bits of the 2800 configuration. The only unexpected problem that we had was the fact that Mitel sends all numbers (including internal extension) as E.164 compliant (effectively puts + in front of everything). So you'll need to translate the numbers and take this + away.
voice service voip
allow-connections sip to sip
redirect ip2ip
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
options-ping 90
no update-callerid
ip address ???.???.???.??? 255.255.255.0
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
hold-queue 2048 in
hold-queue 2048 out
dial-peer voice 30 voip
description *** From Mitel ***
translation-profile incoming FROM_MITEL
voice-class codec 1
session protocol sipv2
session transport tcp
incoming called-number +32...
dtmf-relay rtp-nte sip-notify
dial-peer voice 10 voip
description *** To Mitel ***
destination-pattern 32...
voice-class codec 1
session target ipv4:???.???.???.???
sh ver
Cisco IOS Software, 2800 Software (C2800NM-IPVOICE_IVS-M), Version 12.4(15)T5, RELEASE SOFTWARE (fc4)
great thank you!!
Awesome config! Thanks for posting. (old, but still great) Did you use this for voicemail also or test it? I have a 3300 and a SX-2000 connected. I was thinking of doing the SIP connection to my 2851.
So Sx-2000 phones connect to the 3300, then 3300 to the 2851 to CUCM/Unity
Not sure it will, but maybe?
No, sorry, have never used it with voicemail.
can you tell me from which reference guide you have configure above stpes, because i have to terminate my E1 PRI line on voice gateway, so the call routing will be complex in my scenario:
i have to route the call from / to:
PBX,
CUCM &
PSTN
also , i have to configure SRST between two sites. I have tried to search for the configuration gude and can also able to dig out somthing but it is not upto my satisfaction.
