SIP trunk - making outside calls from the other side
John Kim
I'm looking to implement CME 9.1 on Cisco 2951 at new office.
Since there's Toshiba VoIP system in place at old office, we are migrating the whole ISDN channels to the new office and looking to set up a SIP trunk via P2P WAN link and route the calls.
My questions are;
1) Is it possible to make outside calls for people at the old office via a CME at new office?
    I know it's possible to call extension to extension but I'm not too sure whether it's possible to make outside calls via this way.
2) If it's possible, can someone advise what kind of config is required on CME?
John
Terry Cheema
1) Yes its possible as long as your CME at new site has PSTN connectivity via SIP Trunk or ISDN lines.
2) Look at below document it has example config for SIP Trunking. You will need to come up with your own config but it will give you a reference point to start
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/91535-cme-sip-trunking-config.html
You will need to create a SIP Trunk from old voice system to CME and point the CME extensions and all PSTN patterns to this trunk to route to CME. CME side you will need an incoming voip dial-peer to catch these and outbound dial-peer to route calls(for external calls only). You will also need to create dial-peer to point to the old voip system so that extension to extension calls work.
-Terry
Please rate all helpful posts
Terry Cheema
-Terry
Thanks a lot for your kind reply, Terry.
I'll go over the link you attached.
Cheers!
No Worries John and please do rate helpful posts.
-Terry
