Showing results forĀ
Search instead forĀ
Did you mean:Ā
SIP trunk outgoing calls issue
I have a issue with sip trunk outgoing calls. The incoming calls work well.
I my network the path to join provider sip server is like this: phone--firewall--CUCM--CME srst router--firewall--sip server.
phone ip address: 10.19.51.X
CUCM ip address: 158.113.41.84
CME router ip address: 158.113.41.80
SIP server ip address: 172.20.254.252
You can see in attached the running configuration of the CME router and the debug ccsip messages output.
Please share your experience.
Aristide
29 Replies 29
Hi Aristide.
Can you try to let your Cube to contact the provider with its real public IP and send a debug ccsip message output?
Let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
do you want me to bypass my CUCM server?
Aristide
No.
Sip trunk is between your Voice Gateway and your provider.
Now you are natting your provider's IP Address.
I'm asking you to point to your provider with its real Public IP Address.
Carlo
Ok Carlo, I understand now, but now I want to make a direct sip trunk with a CUCM server to make a test, because I have three location which will use SIP trunk.
Aristide
Can you please describe your call flow?
Are you putting CUCM behind nat?
Carlo
Carlo,
finally I will use the same configuration and the call flow will the same as I describe:
phone--firewall-CUCM--CME router--firewall--Sip server.
I have new information. I can ping sip server with a CUCM but the sip server can't ping the CUCM.
Do you think it can be the issue?
Aristide
Hi Aristide,
this kind of layout could lead to many issues if firewall are not correctly configured.
Because you are communicating through Voice gateway to Sip server, it should reach your VG on the source  port that it uses to register to Sip proxy.
I suggest you to investigate further on your network reachability and also to avoid to put a firewall between CUCM  and ip phones
Carlo
Hi Aristide.
Please enable sip user agent on your gateway adding this:
sip-ua
retry invite 3
retry response 3
retry bye 3
retry cancel 2
After that please post another debug ccsip message
Carlo
Hi Carlo,
I put sip-ua command in configuration but always same issue.
You can see the debug in attached.
Aristide
Hi Aristide,
did you check your firewall if  SIP inspection is enabled or there are some rules blocking SIP traffic?
Please let us know
Carlo
Hi Carlo,
I will check and I will back to you.
Aristide
Hi Carlo,
Firewall have a diagnostic tool.
Does I have to check the traffic between the ip phone: ip address 10.19.51.75 and sip server: 172.20.254.252
or traffic between the CCME router(ip address 158.113.41.80) which establish trunk link with the sip server: 172.20.254.252
Aristide
Hi Aristides,
Were you able to find a solution? I'm curious to know!
BR,
NURLAN
As this is a 9-year-old-post, I encourage you to create your own new post with a description of your problem, and your config and debug and we'll be happy to help.
Maren
NurlanED
Thanks a lot, Maren!
I'll definitely get to it when I have some free time. Your help is much appreciated!"Thank you, Maren.
