10-08-2012 08:59 AM - edited 03-16-2019 01:34 PM
Hello, Need a help
i am getting below error
SIP Trunk Reason: Q.850;cause=102;text="recovery of timer expiry"
I configured the SIP trunk and the below is the Call Flow
IP Phone ----->>>>.CUCM------(SIP Trunk)----CUBE(2921)--------SIP server(ISP)
i can receive incoming call ringing on the IP phone andonce answer there is no audio or ring backtone.
Outgoing calls not allways provides busytone
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.1.1.x 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.1.1.x!
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
description SIP Interface
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2.245
encapsulation dot1Q 245
ip address 10.x.x.254 255.255.255.252
dial-peer voice 51 voip
description Outgoing From STC Server to CUCM SIP TRUNK
translation-profile outgoing PSTN-01
preference 1
destination-pattern 2508...
rtp payload-type cisco-codec-fax-ack 111
rtp payload-type nte 97
session protocol sipv2
session target ipv4:10.x.x.19 (Call Manager)
session transport udp
incoming called-number .
dtmf-relay rtp-nte digit-drop
codec g711alaw
no vad
dial-peer voice 301 voip
description Outgoing for Local Calls
translation-profile outgoing Strip9
destination-pattern 9T
session target ipv4:10.x.x.157
voice-class sip profiles 2
codec g711alaw
no vad
Message was edited by: Rasheed C.V. Ping test fails from STC interface to the CallManager ping 10.x.x.19(CM IP address) source GigabitEthernet0/2.245 (SIP interface) Is it normal behaviour, even i can not ping phone ip from stc interface
10-09-2012 12:32 AM
Hi Rasheed,
The CUCM should be pingable if ICMP is not blocked by firewall. I checked the traces and saw that the CUBE is forwarding the INVITE message to CUCM but CUCM is not at all responding with '100 Tring' message. Please crosscheck the SIP trunk configuration in CUCM also.
Suresh
10-09-2012 04:40 AM
Rahseed,
From your trace, I can see that your provider is not responding to your invite. CUBE sent multiple invite but doesnt get any response back from your ITSP. You need to check with them or check that you have the right config to your ITSP
095487: Oct 1 15:57:57.435: //40199/99568259ACC9/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:2508001@10.x.x.19:5060 SIP/2.0
Via: SIP/2.0/UDP 10.x.x.254:5060;branch=z9hG4bK2E72493
Remote-Party-ID: <90509142839>;party=calling;screen=no;privacy=off
To: <2508001>
Date: Mon, 01 Oct 2012 15:57:57 GMT
Call-ID: 9957BAA9-B1711E2-ACCFDC16-306C038F@10.x.x.254
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 2572583513-0186061282-2898910230-0812385167
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1349107077
Contact: <90509142839>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 30190509142839>2508001>90509142839>90509142839>
v=0
o=CiscoSystemsSIP-GW-UserAgent 1389 8563 IN IP4 10.x.x.254
s=SIP Call
c=IN IP4 10.x.x.254
t=0 0
m=audio 23240 RTP/AVP 8 0 18 97
c=IN IP4 10.x.x.254
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:97 telephone-event/8000
a=fmtp:97 0-15
095488: Oct 1 15:57:59.435: //40199/99568259ACC9/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <2508001>
Date: Mon, 01 Oct 2012 15:57:59 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1349107079
Expires: 180
Max-Forwards: 69
v=0
s=SIP Call
c=IN IP4 10.x.x.254
t=0 0
c=IN IP4 10.x.x.254
a=fmtp:97 0-15
095489: Oct 1 15:58:03.435: //40199/99568259ACC9/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <2508001>
Date: Mon, 01 Oct 2012 15:58:03 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1349107083
Expires: 180
Max-Forwards: 69
v=0
s=SIP Call
c=IN IP4 10.x.x.254
t=0 0
c=IN IP4 10.x.x.254
a=fmtp:97 0-15
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
10-09-2012 08:30 AM
Hi all,
Isn't the problem with early offer in SIP invite ? I know it's an identified problem
Best regards
Benoît PETRY
10-09-2012 10:30 AM
Early offer in SIP invite is perfectly normal. There is no problem with it. What problem do you know with it?
06-12-2013 06:56 PM
What was the resolution ?
Amir
06-12-2013 07:34 PM
Amir,
This post is kind of old, if you have the same issue, you may open a new discussion. However, based on the trace, most likely was a ITSP problem. They were not replying to the SIP INVITE sent by the CUBE.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
06-13-2013 10:15 AM
Hi Jorge,
Thanks for the reply. I have a very strange situation where I have the following symptom:
1. 7925 <-> CUCM <-> CUBE <-> TSP <-> PSTN <-> Called Party ---- FAILS
2. 7937 <-> CUCM <-> CUBE <-> TSP <-> PSTN <-> Called Party ---- FAILS
3. 7945 <-> CUCM <-> CUBE <-> TSP <-> PSTN <-> Called Party ---- SUCCEEDS
The above results are consistent and there is absolutely no difference in the configuration of the various calling phones. All are SCCP, all have the same DN and DEVICE level CSSs, DPs, MRGLs etc.
Very strange.
TIA,
Amir
06-13-2013 11:24 AM
I suggest you open a new thread...Please send us debug ccsip messages from a failed call
"opportunity is a haughty goddess who waste no time with those who are unprepared"
06-13-2013 03:53 PM
Hi Aokanlawon,
Will do.
TIA,
Amir
06-13-2013 04:32 PM
Hi Aokanlawon,
Here is the new thread. I know it will be easy for you to resolve! : )
https://supportforums.cisco.com/thread/2222892
TIA,
Amir
02-25-2021 02:11 PM
hello, What was the resolution ? i have the same issue some calls are not complete
regards!
03-08-2021 08:27 AM
Post up your debugs from the CUBE "debug ccsip mess" to start with. It's highly unlikely that your problem is the same as the OPs.
