12-31-2013 02:58 PM - edited 03-16-2019 09:03 PM
Have posted a lot lately hopefully have not worn out my welcome! Everyone here is very helpful and it's most appreciated.
Last step in getting my CME configured is getting all the phones to ring on the second incoming call on my SIP trunk (and third, and fourth, and so on). I have ephone-dn 82 configured and receiving calls, and all phones have this DN included on an overlay to button 6. Callcentric allows me up to 2 incoming calls on the trunk, and I can purchase more if needed.
Here is the problem. Call comes in on the trunk, all phones ring, one phone picks up, call is in session. A second call placed to the same number appears on the screen of the phone that is on the first call, and it can be answered by hitting the Answer button, but none of the other phones ring at all. I've tried configuring multiple instances of the ephone-dn 82 (83, 84, etc) and adding those to the overlay, but that doesn't work either. What am I dong wrong?
sh config
Using 10065 out of 245752 bytes
version 12.4
service password-encryption
hostname GMIT-VOICEROUTER01
boot-start-marker
boot system flash c2800nm-adventerprisek9_ivs_li-mz.124-24.T6.bin
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone boston -4
clock summer-time boston recurring
dot11 syslog
no ip source-route
--More-- ip cef
ip dhcp pool Voice
network 172.16.2.0 255.255.255.0
default-router 172.16.2.1
dns-server 8.8.8.8 8.8.4.4
option 150 ip 172.16.2.1
ip domain name domain
ip name-server 8.8.8.8
ip name-server 209.28.47.62
no ipv6 cef
voice service voip
--More-- allow-connections h323 to h323
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol cisco
sip
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice class sip-profiles 1
request INVITE sip-header From modify "<sip:(.*)@(.*)>" "<sip:17772882353@\2>"
--More-- !
voice translation-rule 3
rule 1 /^7../ /2072267262/
voice translation-rule 4
rule 1 /^1[2-9]..[2-9]....../ /\0/
rule 2 /^011\(.*\)/ /\1/
rule 3 /^[2-9]....../ /1207\0/
voice translation-profile SIP_1
translate calling 3
translate called 4
voice-card 0
--More-- !
username cisco privilege 15 password 7 1511021F0725
archive
log config
hidekeys
interface Loopback0
description MANAGEMENT
ip address 172.16.254.4 255.255.255.255
--More-- !
interface FastEthernet0/0
ip address x.x.x.x x.x.x.x
ip nat outside
ip virtual-reassembly
duplex full
speed 100
no cdp enable
interface Service-Engine0/0
ip address 172.16.4.250 255.255.255.0
service-module ip address 172.16.4.251 255.255.255.0
service-module ip default-gateway 172.16.4.251
interface FastEthernet0/1
no ip address
duplex full
speed 100
interface FastEthernet0/1.10
encapsulation dot1Q 10 native
ip address 192.168.5.2 255.255.255.0
ip nat inside
--More-- ip virtual-reassembly
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 172.16.3.1 255.255.255.0 secondary
ip address 172.16.2.1 255.255.255.0
ip nat inside
router eigrp 100
redistribute static
passive-interface default
no passive-interface Service-Engine0/0
no passive-interface FastEthernet0/1
no passive-interface Loopback0
network 172.16.0.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 24.39.49.185
ip http server
ip http authentication local
no ip http secure-server
--More-- ip http path flash:gui
ip nat inside source list 101 interface FastEthernet0/0 overload
access-list 101 permit ip 192.168.5.0 0.0.0.255 any
access-list 101 permit ip 172.16.0.0 0.0.255.255 any
nls resp-timeout 1
cpd cr-id 1
snmp-server community marvelous RO
tftp-server flash:OS79XX.TXT
tftp-server flash:P00307010200.bin
tftp-server flash:P00307010200.loads
tftp-server flash:P00307010200.sb2
tftp-server flash:P00307010200.sbn
tftp-server flash:TERM41.DEFAULT.loads
tftp-server flash:Jar41.2-9-1-45.sbn
tftp-server flash:cnu41.2-7-5-50.sbn
--More-- tftp-server flash:CVM41.2-0-1-45.sbn
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
ring number 2
connection plar opx 7001
description Connected to 207-764-1834
caller-id enable type 1
voice-port 0/1/1
shutdown
--More-- dial-peer voice 3 voip
description *** Voicemail Extension 7000 - Do not delete! ***
destination-pattern 7000
session protocol sipv2
session target ipv4:172.16.4.251
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2000 voip
shutdown
destination-pattern 200.
codec g711ulaw
dial-peer voice 700 voip
description SIP Trunk - Incoming
voice-class sip dtmf-relay force rtp-nte
session target dns:callcentric.com
incoming called-number .%
--More-- !
dial-peer voice 701 voip
description SIP Trunk - Outgoing 3-Digit Calls
translation-profile outgoing SIP_1
preference 1
destination-pattern [2-8]11
voice-class codec 1
session target sip-server
dtmf-relay rtp-nte
dial-peer voice 702 voip
description SIP Trunk - Outgoing 11-Digit Calls
preference 1
destination-pattern 1[2-9].........
voice-class sip profiles 1
dtmf-relay rtp-nte
--More-- dial-peer voice 703 voip
description SIP Trunk - Outgoing 10-Digit Calls
preference 1
destination-pattern [2-9]..[2-9]......
voice-class codec 1
no vad
dial-peer voice 704 voip
description SIP Trunk - Outgoing 7-Digit Local Calls
preference 1
destination-pattern [2-9]......
voice-class codec 1
no vad
--More-- !
sip-ua
credentials username 17772882353 password 7 0728331F1D0714040519 realm callcentric.com
authentication username 17772882353 password 7 0728331F1D0714040519
no remote-party-id
retry invite 2
retry register 10
timers connect 100
mwi-server ipv4:172.16.4.251 expires 3600 port 5060 transport udp
registrar dns:callcentric.com expires 60
sip-server dns:callcentric.com
host-registrar
gatekeeper
shutdown
telephony-service
max-ephones 42
--More-- max-dn 100
ip source-address 172.16.3.1 port 2000
auto assign 1 to 10
system message Greenmark IT
url services http://phone-xml.berbee.com/menu.xml
load 7960-7940 P00307010200
voicemail 7000
mwi relay
max-conferences 8 gain -6
moh music-on-hold.au
web admin system name admin secret 5 $1$UfDD$ffCmnvpfJnT5NpJBgnDfk1
dn-webedit
transfer-system full-blind
transfer-pattern 1001
night-service weekday 17:00 07:30
night-service weekend 23:59 23:59
create cnf-files version-stamp 7960 Oct 13 2012 19:30:35
ephone-dn 1 dual-line
number 7010 no-reg both
description Eric Warren
name Eric
--More-- call-forward busy 7000
call-forward noan 7000 timeout 10
huntstop channel
no huntstop
mwi-type both
mwi sip
ephone-dn 2 dual-line
number 7011 no-reg both
description Jenn Edgecomb
name Jenn
huntstop channel
no huntstop
mwi-type both
mwi sip
ephone-dn 3 dual-line
number 7012 no-reg both
description Charly Chandler
--More-- name Charly
huntstop channel
no huntstop
mwi-type both
mwi sip
ephone-dn 4 dual-line
number 7013 no-reg both
description Tim Levesque
name Tim
huntstop channel
no huntstop
mwi-type both
mwi sip
ephone-dn 5 dual-line
number 7014 no-reg both
--More-- description Becky Blodgett
name Becky
huntstop channel
no huntstop
mwi-type both
mwi sip
ephone-dn 6 dual-line
number 7015 no-reg both
description Jessica Grigsby
name Jessica
huntstop channel
no huntstop
mwi-type both
mwi sip
ephone-dn 7 dual-line
--More-- number 7016 no-reg both
description Jon Kimball
name Jonathan
huntstop channel
no huntstop
mwi-type both
mwi sip
ephone-dn 8 dual-line
number 7017 no-reg both
description Tech Bench
name Tech Bench
huntstop channel
no huntstop
mwi-type both
ephone-dn 9 dual-line
number 7018 no-reg both
description Server Room
--More-- name Server Room
huntstop channel
no huntstop
mwi-type both
ephone-dn 10
ephone-dn 11
number 8000
mwi on
ephone-dn 12
number 8001
mwi off
ephone-dn 13 dual-line
number 7001
--More-- label 764-1834
name 764-1834
huntstop channel
ephone-dn 15
call-forward night-service 2000
night-service bell
ephone-dn 81 dual-line
number 12072267262 no-reg primary
label 226-7262
description Callcentric SIP Trunk DID 1
ephone-dn 82 dual-line
number 17772882353 no-reg primary
label 17772882353
description Callcentric SIP Trunk Public
ephone 1
--More-- device-security-mode none
mac-address 0019.E778.4559
type 7960
button 1:1 6o13,81,82
ephone 2
mac-address 000E.D76D.F67C
type 7960
button 1:2 6o13,81,82
ephone 3
mac-address 000E.D72E.46E0
type 7960
button 1:3 6o13,81,82
--More-- ephone 4
mac-address 000E.D76E.0192
type 7960
button 1:4 6o13,81,82
ephone 5
mac-address 000E.8461.296E
type 7960
button 1:5 6o13,81,82
ephone 6
mac-address 000E.D76E.019F
type 7960
button 1:6 6o13,81,82
--More-- !
ephone 7
mac-address 000D.BD40.7F37
type 7960
button 1:7 6o13,81,82
ephone 8
mac-address 0013.C472.847D
type 7960
button 1:8 6o13,81,82
ephone 9
mac-address 0007.5012.1B41
type 7960
button 1:9 6o13,81,82
--More-- !
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line 194
password 7 00071A150754
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
logging synchronous
login local
transport input telnet ssh
line vty 5 15
logging synchronous
login local
--More-- !
scheduler allocate 20000 1000
end
GMIT-VOICEROUTER01#
01-01-2014 01:59 AM
Please add "no huntstop & huntstop channel" to ephone-dn 82 and check.
01-02-2014 03:55 AM
Thanks for the reply sureshsub2. That changed the behavior a little bit, now the second call to that line immediately gets a "party unavailable" message, as if the CME was reporting 486 busy. The goal would be to have up to three incoming calls on that line at a time.
01-02-2014 06:39 AM
So with sureshsub2's commands, you also need to configure another DN with the same number like this:
ephone-dn 83 dual-line
label 17772882353
preference 1
Then add DN 83 as an overlay on the same button as 82.
With dual-lines, the phone that answers the first call has exclusive access to the 2nd channel for transferring/conferencing/etc. We use the "no huntstop command" to allow the system to hunt to another DN is that one has all the channels used up. By using "huntstop channel" on DN 82, we tell it to mark that DN down for incoming calls once the first channel is being used. This still allows the first phone that answered to use the 2nd channel for outgoing calls/transfers/conferencing but it will hunt to the next matching DN for incoming calls to that number.
