IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5385 Views
  • 14 replies
Hello,I am planning an upgrade to 9.1 from 8.5.  I want to use the UCT tool to determine current licensing as is translated to the upgrade to 9.1.  I am unable to find it on the Cisco site.  All searches in the forum's and online show I should find i...
                   We are running CM version 8.5 and have CER and UC integrated on our network. One of our support personnel wants to change the passwords on the systems (why exactly I do not know) but myself and another technician are worried about ...
gp1200x by Level 2
  • 225 Views
  • 1 replies
Hello all,I have set up a voice lab with below topologySCCP Extension (2001/ Mask: +14082022001)----CUCM 7.0---H323-----CUBE-----SIP------CUCME---SCCP Extension (6001/Mask: +861062286001)However, when 2001 call 6001, 6001 only rings for 1 time, and 2...
Yan Tian by Level 1
  • 5196 Views
  • 26 replies
We are trying to transfer a calls to an after-hours call center.  Unfortunately we are getting a fast busy when we attempt to forward.  When I run 'debug isdn q931' I can see the reason we are getting a fast busy is the number prefix is incorrect.  I...
ZiPPygEEk by Level 1
  • 698 Views
  • 4 replies
Greetings to all.i had a problem to establish a voip session between 2 sites as despicted on picture.on site left, i had an 2851 ISR Router with running call manager express, in the other side of the tunnel gre i had an 2801 isr with fxo and fxs port...
