Showing results forĀ
Search instead forĀ
Did you mean:Ā
SIP Trunk + Transcoder understanding
drbabbers
Level 3
Level 3
All,
I was wondering please for a bit of fundamental help understanding a call flow involving an ITSP and a codec mismatch, with the possible use of a transcoder. The transcoder part is what I am mainly interested in understanding.
If we go with this call setup as an example:
HQ PHONE<--------CUCM<---------SIP TRUNK<--------CUBE<--------------ITSP<-------PSTN PHONE
<----------------------------------------------INBOUND CALL FROM PSTN TO HQ PHONE-----------
  • The phone and SIP Trunk are in a Device Pool + Region that only supports g729
  • CUBE is setup with the only permitted codec being g729
  • An INVITE comes in from the ITSP to the CUBE with an early offer of g711 only
  • For the inbound call leg we have a codec mismatch between CUBE and the ITSP
My questions are...
  • I assume normally the call will fail with a media negotiation issue?
  • Can I implement a local transcoder on the CUBE to fix this situation? (Standalone and not registered with CUCM?) Therefore we have a media stream between CUBE and the ITSP in g711 and a media stream between CUBE and the HQ PHONE in g729?
  • If the transcoder can assist, then will the SIP call successful with what the ITSP are offering? So in this case g711 is negotiated in the call setup end to end?
  • Is a transcoder invoked at the 'problem end' of the call leg? For example the CUBE here can't support what the ITSP are offering.
Your help is much appreciated! I would love to lab this but don't have a spare CUBE laying around :-)
D
Dennis Mink
there is probably no silver bullet, but if you cant change the codec negotiation to include G711 end to end then yes, XCODE will be a necessity.
CUBE;s can do local transcoding without an SCCP dependency on CUCM:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/100480-cube-transcode.html
the requirement for this is that the CUBE is in flow through. which means ALL RTP streams go though the CUBE.
Please rate if useful
Please remember to rate useful posts, by clicking on the stars below.
Devansh
please configure a universal transcoder. this will eliminate sccp protocol.
