SIP Trunk works outbound to CME, not inbound to CUCM
ken.montgomery
Hi Everyone,
I've been struggling with this for a while now, gave up on the h323 connectivity and went back to SIP.  Here is the scenario:  We have a Cisco Unified Communication Manager 6.1 system in one office, which is up and running and working fine.  This system uses 4-digit dialing for internal extensions, all starting with 7XXX.  We also have a CME running at a remote location, all extensions 8XXX.  All is working fine there as well.  We have an MPLS network between the two, and IP connectivity is solid and easily visible.
Now, What I'm trying to do is allow users at the main site to call the remote site using 228xxx, which is working.  This is across SIP trunk to remote site.  The remote site should be able to dial 217xxx and get the 4-digit extension at HQ.  I see the SIP invites go out, yet the calls never go through.  I'm struggling to find a cause in the CUCM that is denying the call...
The CME Relevant configurations:
Current configuration : 49762 bytes
voice service voip
ip address trusted list
  ipv4 10.96.178.0 255.255.255.0
  ipv4 <CUCM-Primary>
  ipv4 <CUCM-Secondary>
allow-connections h323 to sip
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  h245 signal update
sip
  registrar server expires max 3600 min 3600
voice translation-rule 10
rule 10 /^21/ //
voice translation-rule 11
rule 11 /^22/ //
voice translation-profile CUCM-INBOUND
translate called 11
voice translation-profile CUCM-OUTBOUND
translate calling 10
translate called 10
dial-peer voice 210 voip
description *** OUTBOUND to CUCM CALL MANAGER TEST ***
translation-profile outgoing CUCM-OUTBOUND
destination-pattern 21....
session protocol sipv2
session target ipv4:<CUCM-Subscriber>
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 211 voip
description *** INCOMING CALLS FROM CUCM ****
group-name FairlawnIncoming
destination-pattern 8...
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
no remote-party-id
retry invite 2
retry register 10
timers connect 100
host-registrar
telephony-service
no auto-reg-ephone
authentication credential cmeadmin d3l3m@
max-ephones 95
max-dn 95
ip source-address <CME IP Address> port 2000
timeouts interdigit 3
timeouts ringing 20
system message VEYANCE
time-zone 43
voicemail 7999
max-conferences 8 gain -6
call-forward pattern 4....
moh "flash:music-on-hold.au"
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Aug 20 2012 21:17:28
Call Manager has a SIP Trunk setup with a separate device pool, Call Classification "On Net"
Again, outbound calls to the CME work fine.  Inbound from CME to CUCM do not work at all... here is a test, dialing 217163 on the CME:
I am running this with the following debugs enabled:
DIALPEER:
  debug voip dialpeer detail is ON (filter is OFF)
CCAPI:
  debug voip ccapi inout is ON (filter is OFF)
CCSIP SPI: SIP Call Statistics tracing is enabled       (filter is OFF)
CCSIP SPI: SIP Call Events tracing is enabled   (filter is OFF)
Here is the debug output from call from 8500 to 217163:
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=8500
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=8500T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=8500
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=211 Is Matched
   Result=Success(0); Incoming Dial-peer=20096 Is Matched
Mar 11 17:35:43.334: //-1/EF178EEE90B5/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=8500
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Mar 11 17:35:43.334: //-1/EF178EEE90B5/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x1CA10704, Call Info(
   Calling Number=8500,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20096, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Mar 11 17:35:43.334: //-1/EF178EEE90B5/CCAPI/ccCheckClipClir:
   In: Calling Number=8500(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=8500(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 11 17:35:43.334: :cc_get_feature_vsa malloc success
Mar 11 17:35:43.334:  cc_get_feature_vsa count is 1
Mar 11 17:35:43.334: :FEATURE_VSA attributes are: feature_name:0,feature_time:504015312,feature_id:147573
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=8500(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/cc_process_call_setup_ind:
   Event=0x1620BED0
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/ccCallSetContext:
   Context=0x117C92D4
   >>>>CCAPI handed cid 775709 with tag 20096 to app "_ManagedAppProcess_Default"
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/ccCallSetupAck:
   Call Id=775709
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=775709
Mar 11 17:35:43.338: //775709/EF178EEE90B5/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Mar 11 17:35:43.338: //775709/EF178EEE90B5/CCAPI/ccCallReportDigits:
   (callID=0xBD61D, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=775709
Mar 11 17:35:43.338: //775709/EF178EEE90B5/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x1CA10704, callID=0xBD61D, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x1CA10704, Call Id=775709
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=3000(ms))
Mar 11 17:35:43.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=775709, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0x21493D8, Rtp Expiration=0x0
Mar 11 17:35:43.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
   Source Call Id=775709, Digit=2, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
Mar 11 17:35:43.538: //-1/EF178EEE90B5/DPM/dpMatchCore:
Veyance_CME#Dial String=2, Expanded String=2, Calling Number=
   Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Mar 11 17:35:43.538: //-1/EF178EEE90B5/DPM/MatchNextPeer:
   Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=210
   Result=1
Mar 11 17:35:43.738: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
   Source Call Id=775709, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x21510D8, Rtp Expiration=0x0
Mar 11 17:35:43.738: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
   Source Call Id=775709, Digit=1, Duration=100,
Mar 11 17:35:43.738: //-1/EF178EEE90B5/DPM/dpMatchCore:
   Dial String=21, Expanded String=21, Calling Number=
Mar 11 17:35:43.738: //-1/EF178EEE90B5/DPM/MatchNextPeer:
   Result=1
Mar 11 17:35:43.938: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
   Source Call Id=775709, Digit=7, DigitBeginFlags=0x0,
   Rtp Timestamp=0x2158DD8, Rtp Expiration=0x0
Mar 11 17:35:43.938: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
   Source Call Id=775709, Digit=7, Duration=100,
Mar 11 17:35:43.938: //-1/EF178EEE90B5/DPM/dpMatchCore:
   Dial String=217, Expanded String=217, Calling Number=
Mar 11 17:35:43.938: //-1/EF178EEE90B5/DPM/MatchNextPeer:
   Result=1
Mar 11 17:35:44.138: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x2160AD8, Rtp Expiration=0x0
Mar 11 17:35:44.138: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
Mar 11 17:35:44.138: //-1/EF178EEE90B5/DPM/dpMatchCore:
   Dial String=2171, Expanded String=2171, Calling Number=
Mar 11 17:35:44.138: //-1/EF178EEE90B5/DPM/MatchNextPeer:
   Result=1
Mar 11 17:35:44.338: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
   Source Call Id=775709, Digit=6, DigitBeginFlags=0x0,
   Rtp Timestamp=0x21687D8, Rtp Expiration=0x0
Mar 11 17:35:44.338: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
   Source Call Id=775709, Digit=6, Duration=100,
Mar 11 17:35:44.338: //-1/EF178EEE90B5/DPM/dpMatchCore:
   Dial String=21716, Expanded String=21716, Calling Number=
Mar 11 17:35:44.338: //-1/EF178EEE90B5/DPM/MatchNextPeer:
   Result=1
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
   Source Call Id=775709, Digit=3, DigitBeginFlags=0x0,
   Rtp Timestamp=0x21704D8, Rtp Expiration=0x0
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
   Source Call Id=775709, Digit=3, Duration=100,
Mar 11 17:35:44.538: //-1/EF178EEE90B5/DPM/dpMatchCore:
   Dial String=217163, Expanded String=217163, Calling Number=
Mar 11 17:35:44.538: //-1/EF178EEE90B5/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=210 Is Matched
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/ccCallReportDigits:
   (callID=0xBD61D, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x1CA10704, callID=0xBD61D, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Mar 11 17:35:44.538: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Mar 11 17:35:44.538: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Mar 11 17:35:44.538: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Mar 11 17:35:44.538: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
   Dial String=217163, Expanded String=217163, Calling Number=217163T
   Match Rule=DP_MATCH_ANSWER; Calling Number=217163
   Dial String=, Expanded String=, Calling Number=217163T
   Result=-1
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=217163
   Result=Success(0); Incoming Dial-peer=210 Is Matched
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=210, Params=0x3AFB7F8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/ccCheckClipClir:
   Destination Pattern=21...., Called Number=7163, Digit Strip=FALSE
   Called Number=7163(TON=Unknow
Veyance_CME#n, NPI=Unknown),
   Redirect Number=, Display Info=Testing
   Account Number=, Final Destination Flag=FALSE,
   Guid=EF178EEE-89A8-11E2-90B5-9DDB61BF2B12, Outgoing Dial-peer=210
Mar 11 17:35:44.542: //775709/EF178EEE90B5/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=8500
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=7163
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Mar 11 17:35:44.542: //775709/EF178EEE90B5/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x24701AC, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=8500,(Calling Name=Testing)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=7163(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=210, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Mar 11 17:35:44.542: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 11 17:35:44.542: :cc_get_feature_vsa malloc success
Mar 11 17:35:44.542:  cc_get_feature_vsa count is 2
Mar 11 17:35:44.542: :FEATURE_VSA attributes are: feature_name:0,feature_time:504012176,feature_id:147574
Mar 11 17:35:44.542: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Mar 11 17:35:44.542: //775710/EF178EEE90B5/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Mar 11 17:35:44.542: //775710/EF178EEE90B5/CCAPI/ccCallSetContext:
   Context=0x3AFB7A8
Mar 11 17:35:44.542: //775709/EF178EEE90B5/CCAPI/ccSaveDialpeerTag:
Mar 11 17:35:44.542: //775710/EF178EEE90B5/CCAPI/cc_api_call_proceeding:
   Interface=0x24701AC, Progress Indication=NULL(0)
Mar 11 17:35:44.542: //775710/EF178EEE90B5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Mar 11 17:35:44.542: //775710/EF178EEE90B5/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:154D2CFC
Mar 11 17:35:44.878: //775710/EF178EEE90B5/CCAPI/cc_api_call_disconnected:
   Cause Value=63, Interface=0x24701AC, Call Id=775710
   Call Entry(Responsed=TRUE, Cause Value=63, Retry Count=0)
Mar 11 17:35:44.878: //775709/EF178EEE90B5/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Mar 11 17:35:44.878: //775710/EF178EEE90B5/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=775710
Mar 11 17:35:44.878: //775710/EF178EEE90B5/CCAPI/ccCallDisconnect:
   Cause Value=63, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=63)
   Cause Value=63, Call Entry(Responsed=TRUE, Cause Value=63)
Mar 11 17:35:44.878: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Mar 11 17:35:44.878: //775710/EF178EEE90B5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Mar 11 17:35:44.878: //775710/EF178EEE90B5/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x24701AC, Tag=0x0, Call Id=775710,
   Call Entry(Disconnect Cause=63, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Mar 11 17:35:44.878: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 11 17:35:44.878: :cc_free_feature_vsa freeing 1E0A9D88
Mar 11 17:35:44.878:  vsacount in free is 1
Mar 11 17:35:44.878: //775710/EF178EEE90B5/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x166A6DC8
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 8500
Called Number            : 7163
Source IP Address (Sig  ): 10.96.178.2
Destn SIP Req Addr:Port  : 10.96.210.2:5060
Destn SIP Resp Addr:Port : 10.96.210.2:5060
Destination Name         : 10.96.210.2
Mar 11 17:35:44.878: //775710/EF178EEE90B5/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 10.96.178.2
Source IP Port    (Media): 29942
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 63
Disconnect Cause (SIP)   : 503
Veyance_CME#
Mar 11 17:35:44.878: //775709/EF178EEE90B5/CCAPI/ccCallDisconnect:
   Cause Value=63, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Mar 11 17:35:44.878: //775709/EF178EEE90B5/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
Veyance_CME#
Mar 11 17:35:46.306: //775709/EF178EEE90B5/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x1CA10704, Tag=0x0, Call Id=775709,
Mar 11 17:35:46.306: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 11 17:35:46.306: :cc_free_feature_vsa freeing 1E0AA9C8
Mar 11 17:35:46.306:  vsacount in free is 0
In previous debugs, I did come across a SIP/2.0 503 error as well, but not at this time...
Any help/suggestions are appreciated.
2 Accepted Solutions
Ken,
you need to reset the sip trunk after you made the change. Please reset the sip trunk..do another test call and send me debug ccsip messages.
That command suggested wont help this case because the Invite and TO fields are the same..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Ken,
Thats a piece of good news.
The clue to solving the problem was this..
Warning: 399 "Routing failed: ccbid=17238 socket=:5060
Usually when you get that error it is indicative of three things..
1. Wrong Ip address configured on the sip trunk..In your case since we saw that the outbound call works with the correct ip that was not the case
2. The CUCM server your dial-peer points to is not in the CUCM group of the sip trunk (and you dont have "route on all active nodes" checked (your version doesnt have it)----This was the issue for your case..when you added the cucm subscriber to the cucm group calls started working
3. Incorrect bind config.
Anyways glad that its done and dusted...Dont forget to rate any other useful post! I think this thread deserves more than one rating
38 Replies 38
daniel.bloom
This looks like an issue on the CUCM side. CUCM is sending CME a sip 503 error message (this can be seen in the disconnect cause code of your debugs). Have you configured a calling search space on your sip trunk that includes the 7xxx extensions?
I have not, but I never have needed one.  The 7XXX extensions are inherent in the Call Manager (meaning all of the phones it supports locally are in that range), so does it need a calling space?
If I configure a calling search space, what effect will that have on the calls in progress, dial patterns, etc... since there never has been one... hmm....
I apologize.  I was thinking of Route Patterns, not calling search spaces.  I did not have one defined in the SIP trunk for inbound calling, have set it to be the local numbers, let me test here.
Initially, I set it to use the Internal partition setup for the site, yet the calls just get to a fast busy signal, here is the debug from the CME on that pattern:
Mar 12 12:00:14.155: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Mar 12 12:00:14.155: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Mar 12 12:00:17.007: %IPPHONE-6-REG_ALARM: 24: Name=SEPA418758B5830 Load=6911SCCP.9-2-1-a Last=Phone-Reg-Rej
Memory full, run clear telephony-service ephone-attempted-registrations to refresh the storage
Mar 12 12:00:18.163: //-1/3DF7EF0E985C/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=8500
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Mar 12 12:00:18.163: //-1/3DF7EF0E985C/CCAPI/cc_api_call_setup_ind_common:
Mar 12 12:00:18.163: //-1/3DF7EF0E985C/CCAPI/ccCheckClipClir:
Mar 12 12:00:18.163: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 12 12:00:18.163: :cc_get_feature_vsa malloc success
Mar 12 12:00:18.163:  cc_get_feature_vsa count is 1
Mar 12 12:00:18.163: :FEATURE_VSA attributes are: feature_name:0,feature_time:504010160,feature_id:148636
Mar 12 12:00:18.163: //777921/3DF7EF0E985C/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Mar 12 12:00:18.167: //777921/3DF7EF0E985C/CCAPI/cc_process_call_setup_ind:
   Event=0x161FDB40
Mar 12 12:00:18.167: //777921/3DF7EF0E985C/CCAPI/ccCallSetContext:
   Context=0x3AF8EC8
   >>>>CCAPI handed cid 777921 with tag 20096 to app "_ManagedAppProcess_Default"
Mar 12 12:00:18.167: //777921/3DF7EF0E985C/CCAPI/ccCallSetupAck:
   Call Id=777921
Mar 12 12:00:18.167: //777921/3DF7EF0E985C/CCAPI/cc_api_set_transfer_info:
Mar 12 12:00:18.167: //777921/3DF7EF0E985C/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=777921
Mar 12 12:00:18.167: //777921/3DF7EF0E985C/CCAPI/ccSetDigitTimeouts:
Mar 12 12:00:18.167: //777921/3DF7EF0E985C/CCAPI/ccCallReportDigits:
   (callID=0xBDEC1, digit_event=0x1, enable=TRUE, consume=FALSE)
Veyance_CME#
   Enabled=TRUE, Call Id=777921
Mar 12 12:00:18.167: //777921/3DF7EF0E985C/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x1CA10704, callID=0xBDEC1, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x1CA10704, Call Id=777921
Mar 12 12:00:18.531: %ENVMON-5-POWER_NOTICE: : Internal Power Supply Unit  12V is UP
Mar 12 12:00:18.939: //777921/3DF7EF0E985C/CCAPI/cc_api_call_digit_begin:
   Source Call Id=777921, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0x2179178, Rtp Expiration=0x0
Mar 12 12:00:18.939: //777921/3DF7EF0E985C/CCAPI/cc_api_call_digit_end:
   Source Call Id=777921, Digit=2, Duration=100,
   Source Call Id=777921, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x2180E78, Rtp Expiration=0x0
   Source Call Id=777921, Digit=1, Duration=100,
   Source Call Id=777921, Digit=7, DigitBeginFlags=0x0,
   Rtp Timestamp=0x2188B78, Rtp Expiration=0x0
   Source Call Id=777921, Digit=7, Duration=100,
Mar 12 12:00:19.183: //777921/3DF7EF0E985C/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x2190878, Rtp Expiration=0x0
Mar 12 12:00:19.183: //777921/3DF7EF0E985C/CCAPI/cc_api_call_digit_end:
   Source Call Id=777921, Digit=6, DigitBeginFlags=0x0,
   Rtp Timestamp=0x2198578, Rtp Expiration=0x0
   Source Call Id=777921, Digit=6, Duration=100,
Mar 12 12:00:19.651: //777921/3DF7EF0E985C/CCAPI/cc_api_call_digit_begin:
   Source Call Id=777921, Digit=3, DigitBeginFlags=0x0,
   Rtp Timestamp=0x21A0278, Rtp Expiration=0x0
Mar 12 12:00:19.651: //777921/3DF7EF0E985C/CCAPI/cc_api_call_digit_end:
   Source Call Id=777921, Digit=3, Duration=100,
Mar 12 12:00:19.651: //777921/3DF7EF0E985C/CCAPI/ccCallReportDigits:
   (callID=0xBDEC1, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 12 12:00:19.651: //777921/3DF7EF0E985C/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x1CA10704, callID=0xBDEC1, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 12 12:00:19.651: //777921/3DF7EF0E985C/CCAPI/ccCallProceeding:
Mar 12 12:00:19.655: //777921/3DF7EF0E985C/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=210, Params=0x117B7504, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Mar 12 12:00:19.655: //777921/3DF7EF0E985C/CCAPI/ccCheckClipClir:
   Guid=3DF7EF0E-8A43-11E2-985C-9DDB61BF2B12, Outgoing Dial-peer=210
Mar 12 12:00:19.655: //777921/3DF7EF0E985C/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=8500
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=7163
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Mar 12 12:00:19.655: //777921/3DF7EF0E985C/CCAPI/ccIFCallSetupRequestPrivate:
Mar 12 12:00:19.655: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 12 12:00:19.655: :cc_get_feature_vsa malloc success
Mar 12 12:00:19.655:  cc_get_feature_vsa count is 2
Mar 12 12:00:19.655: :FEATURE_VSA attributes are: feature_name:0,feature_time:504012624,feature_id:148637
Mar 12 12:00:19.655: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Mar 12 12:00:19.655: //777922/3DF7EF0E985C/CCAPI/ccIFCallSetupRequestPrivate:
Mar 12 12:00:19.655: //777922/3DF7EF0E985C/CCAPI/ccCallSetContext:
   Context=0x117B74B4
Mar 12 12:00:19.655: //777921/3DF7EF0E985C/CCAPI/ccSaveDialpeerTag:
Veyance_CME#
Mar 12 12:00:19.659: //777922/3DF7EF0E985C/CCAPI/cc_api_call_proceeding:
Mar 12 12:00:19.659: //777922/3DF7EF0E985C/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Mar 12 12:00:19.659: //777922/3DF7EF0E985C/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:154D1754
Mar 12 12:00:19.911: //777922/3DF7EF0E985C/CCAPI/cc_api_call_disconnected:
   Cause Value=63, Interface=0x24701AC, Call Id=777922
Mar 12 12:00:19.911: //777921/3DF7EF0E985C/CCAPI/ccCallReleaseResources:
Mar 12 12:00:19.911: //777922/3DF7EF0E985C/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=777922
Mar 12 12:00:19.911: //777922/3DF7EF0E985C/CCAPI/ccCallDisconnect:
Mar 12 12:00:19.911: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Mar 12 12:00:19.911: //777922/3DF7EF0E985C/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Mar 12 12:00:19.911: //777922/3DF7EF0E985C/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x24701AC, Tag=0x0, Call Id=777922,
Mar 12 12:00:19.911: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 12 12:00:19.911: :cc_free_feature_vsa freeing 1E0A9F48
Mar 12 12:00:19.911:  vsacount in free is 1
Mar 12 12:00:19.911: //777922/3DF7EF0E985C/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x1662F5E8
Mar 12 12:00:19.911: //777922/3DF7EF0E985C/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 30156
Veyance_CME#
Mar 12 12:00:19.915: //777921/3DF7EF0E985C/CCAPI/ccCallDisconnect:
Mar 12 12:00:19.915: //777921/3DF7EF0E985C/CCAPI/cc_api_get_transfer_info:
Mar 12 12:00:21.951: //777921/3DF7EF0E985C/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x1CA10704, Tag=0x0, Call Id=777921,
Mar 12 12:00:21.951: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 12 12:00:21.951: :cc_free_feature_vsa freeing 1E0A95A8
So I am still getting the 503 error, like it can't find the calling search space.
So, will tinker around with that for a while... further suggestions appreciated.
Can you send debug ccsip messages from the CCME box? (only this debug pls)
Sure, thought I had it on, but let me do that...
Mar 12 13:00:30.899: %IPPHONE-6-REG_ALARM: 24: Name=SEPA418758B5830 Load=6911SCCP.9-2-1-a Last=Phone-Reg-Rej
Mar 12 13:00:31.751: //778052/A71D4EF198EF/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:7163@:5060 SIP/2.0
Via: SIP/2.0/UDP :5060;branch=z9hG4bK9C6B21366
From: "Testing" <>8500@sipprovider>;tag=1A84C300-14B7
To: <7163>>
Date: Tue, 12 Mar 2013 13:00:31 GMT
Call-ID: A7D5A1BB-8A4B11E2-98F49DDB-61BF2B12@sipprovider
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2803715825-2320175586-2565840347-1639918354
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M1
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1363093231
Contact: <8500>:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 304
v=0
o=CiscoSystemsSIP-GW-UserAgent 8414 1683 IN IP4 10.96.178.2
s=SIP Call
c=IN IP4
t=0 0
m=audio 30182 RTP/AVP 0 8 18 101
c=IN IP4
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
Mar 12 13:00:32.007: //778052/A71D4EF198EF/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Tue, 12 Mar 2013 13:26:55 GMT
Allow-Events: presence
Content-Length: 0
To: <7163>>
CSeq: 101 INVITE
Received:
SIP/2.0 503 Service Unavailable
Warning: 399 "Routing failed: ccbid=17238 socket=:5060"
Content-Length: 0
To: <7163>>;tag=372697789
CSeq: 101 INVITE
Mar 12 13:00:32.011: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Veyance_CME#ACK sip:7163@10.96.210.2:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Hopefully that helps in figuring it out... I'll review as well to see if it makes sense to me.  (Definitely no SIP expert)
Interesting, the call flow above indicates that for some reason the CUCM is receiving an invite or returning the invite which is being interpreted as our SIP outside provider, instead of internal... weird...
Its because of imporper bind configuration..
But... I guess I have a concern there.  I have no bind commands in use.  AND... since we also use an outside SIP provider at the remtoe CME site, will the BIND command affect them?
You need to break things down..
1. You dont have a bind command, which sometimes can work but in your case the wrong interface is used to send sip traffic to cucm. Hence when cucm receives the invite it says oh I cant talk to that IP address
2. You need to undeerstand you network..How is your traffic routed? Where is what IP?
3. You can configure bind commands on dial-peer going to cucm for this traffic
dial-peer voice xx voip
voice-class sip bind control source-interface yyyyy (your interface pointing to cucm)
or you can just configure this on the dial-peer pointing to the ITSP...
This is where your issue is..
You sent an invite to CUCM and want to receive response on CCME IP address..But can cucm connect to the ip in the via header? I doubt it..thats why you are getting the error above
Sent:
What is the IP address of your sip trunk in cucm pointing to ccme?
Configure your Bind commands on that interface
While I think the bind may have been appropriate, still having the same issue.
Here is the config, which should be most everything you need, along with debug information included as well... please help me figure this out... the bind is in place...still same errors:
Current configuration : 49986 bytes
! Last configuration change at 22:02:16 MNL Tue Mar 12 2013 by kmmontgomery
! NVRAM config last updated at 22:56:01 MNL Mon Mar 4 2013 by kmmontgomery
version 15.2
hostname <--- removed  --->
boot-start-marker
boot system flash:c2951-universalk9-mz.SPA.152-4.M1.bin
boot-end-marker
card type e1 0 0
logging discriminator ENV severity drops 5 facility drops ENVMON mnemonics drops POWER_NOTICE
logging buffered 50000
<--- enable and aaa model information removed --->
aaa session-id common
clock timezone MNL 8 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
<--- crypto removed for security --->
ip domain name eng-prod.com
ip host ININ-PRIM.local <---IP Address of ININ Primary Server--->
ip host ININ-SEC.local <---IP Address of ININ Secondary Server--->
ip host sip.skype.com <---IP Address for Skype SIP Provider --->
ip name-server 8.8.8.8
ip cef
no ipv6 cef
isdn switch-type primary-net5
trunk group Veyance-E1
hunt-scheme least-idle
lpcor incoming VeyanceISDNTrunks
lpcor outgoing VeyanceISDNTrunks
voice-card 0
voice service voip
  ipv4 255.255.255.0
  ipv4 <---IP Address for Skype SIP Provider --->
  ipv4 <---IP Address of ININ Primary Server--->
  ipv4 <---IP Address of ININ Secondary Server--->
  ipv4 <---IP Address of CUCM Publisher Server--->
  ipv4 <---IP Address of CUCM Subscriber Server--->
h323
  h245 signal update
sip
  bind control source-interface GigabitEthernet0/2
  bind media source-interface GigabitEthernet0/2
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class codec 2
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
voice register global
voice lpcor enable
voice lpcor custom
group 10 VeyanceStandardUser
group 11 VeyanceExecUser
group 12 VeyanceISDNTrunks
voice lpcor policy VeyanceStandardUser
service fac
accept VeyanceExecUser
accept VeyanceISDNTrunks
voice lpcor policy VeyanceISDNTrunks
service fac
accept VeyanceStandardUser fac
no accept VeyanceISDNTrunks
<--- removed voice translation rules that do not apply---->
rule 10 /^21/ //
rule 11 /^22/ //
voice translation-profile FAIRLAWN-INBOUND
translate called 11
voice translation-profile FAIRLAWN-OUTBOUND
translate called 10
license udi pid CISCO2951/K9 sn FHK1447F3R4
license boot module c2951 technology-package securityk9
license boot module c2951 technology-package uck9
hw-module pvdm 0/0
hw-module sm 1
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
trunk-group Veyance-E1 timeslots 1-31 preference 1
controller E1 0/0/1
ip ssh time-out 15
ip ssh version 2
class-map type inspect sip match-any sip-class1
match request method invite
class-map type inspect sip match-any sip-class2
match request method message
policy-map type inspect sip sip-policy
class type inspect sip sip-class1
  allow
class type inspect sip sip-class2
  reset
gw-accounting aaa
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
description CONNECTION TO CME-LAN "$ES_LAN$"
ip address <--- IP Address of CME ---> 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface SM1/0
description CUE APPLICATION
ip unnumbered GigabitEthernet0/2
service-module ip address <--- IP Address of CUE ---> 255.255.255.0
!Application: CUE Running on SM
service-module ip default-gateway <--- IP Address of CME --->
interface SM1/1
description Internal switch interface connected to Service Module
no ip address
interface Vlan1
no ip address
router eigrp 13
network <--- all internal network overview --->
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
no ip nat service sip udp port 5060
ip route 0.0.0.0 0.0.0.0 <--- IP Address of Internet Router --->
ip route <--- IP Address for MPLS Networks ---> 255.255.0.0 <--- Ip Address of MPLS Router --->
ip route <---IP address of CUE---> 255.255.255.255 SM1/0
access-list 1 permit <--- MPLS Networks --->
access-list 120 deny   udp any any range 16384 32768
access-list 120 deny   tcp any any range 1719 1720
access-list 120 deny   tcp any any range 5000 5998
access-list 120 deny   tcp any any range 2000 2002
access-list 120 deny   udp any any range 5060 5061
access-list 120 deny   tcp any any eq 2427
access-list 120 deny   udp any any eq 2428
access-list 120 deny   tcp any any eq telnet
access-list 120 permit ip any any log
nls resp-timeout 1
cpd cr-id 1
<--- SNMP, Tacacs and other extraneous info removed --->
control-plane
<--- Misc Voice Ports for serial stuff removed --->
mgcp fax t38 ecm
mgcp profile default
dial-peer cor custom
name veyancelocalcalls
name veyanceCUE-CME
name DefaultDialPeerZero
name veyanceIDDcalls
name veyanceNDD-MobileCalls
dial-peer cor list veyanceEMP1
member veyancelocalcalls
member veyanceCUE-CME
member veyanceIDDcalls
member veyanceNDD-MobileCalls
dial-peer cor list veyanceEMP2
dial-peer cor list veyancelocalcalls
dial-peer cor list veyanceIDDcalls
dial-peer cor list veyanceNDD-MobileCalls
dial-peer cor list veyanceCUE-CME
dial-peer cor list DefaultDialPeerZero
member DefaultDialPeerZero
dial-peer voice 103 pots
corlist outgoing veyancelocalcalls
description ***** Outgoing POTS Call Leg from CME Phones to Local PSTN *****
destination-pattern 9[1-9]T
port 0/0/0:15
no sip-register
dial-peer voice 1 pots
corlist incoming veyanceCUE-CME
description ***** Incoming POTS Call Leg to 9178XXX (ISDN-PRI) *****
translation-profile incoming INCOMING_TRANS
translate-outgoing called 1
direct-inward-dial
port 0/0/0:15
dial-peer voice 102 pots
description ***** Outgoing POTS Call Leg from CME Phones to 1800 ***
destination-pattern 1800T
port 0/0/0:15
forward-digits all
prefix 18
no sip-register
dial-peer voice 6000 voip
session target ipv4:<---IP Address of CUE--->
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 100 pots
trunkgroup Veyance-E1
corlist outgoing veyanceIDDcalls
description ***** Outgoing POTS Call Leg from CME Phones to IDD *****
destination-pattern 9[0][0]T
forward-digits 11
prefix 00
no sip-register
dial-peer voice 101 pots
corlist outgoing veyanceNDD-MobileCalls
description ***** Outgoing POTS Call Leg from CME Phones to Mobile & NDD ***
destination-pattern 9[0][1-9]T
no sip-register
dial-peer voice 7000 voip
corlist outgoing veyanceCUE-CME
description ***** VEYANCE AUTO ATTENDANT *****
destination-pattern 8030
session target ipv4:<--- IP Address of CUE --->
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 7001 voip
description ***** VOICEMAIL *****
destination-pattern 7999
codec g711ulaw
no vad
dial-peer voice 7002 voip
description ***** PROMPT MNGMNT *****
destination-pattern 7997
codec g711ulaw
no vad
dial-peer voice 10 pots
corlist incoming veyanceEMP1
description ***** FAX *****
destination-pattern 8059
port 0/1/0
no sip-register
dial-peer voice 200 voip
description *** INCOMING CALLS FROM SKYPE NETWORK ***
translation-profile incoming SKYPE_INBOUND
session target dns:<--- DNS Name of SIP Provided by Skype --->
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 201 voip
description *** OUTGOING CALLS TO SKYPE NETWORK ***
translation-profile outgoing SKYPE_OUTBOUND
destination-pattern 5....T
voice-class codec 1
voice-class sip localhost dns:<--- DNS Name of SIP Provided by Skype --->
dtmf-relay rtp-nte
no vad
dial-peer voice 202 voip
description *** CALLS OUTBOUND TO ININ USERS ***
translation-profile outgoing CISCO_TO_ININ
preference 1
destination-pattern 4....
session target ipv4:<---IP Address of ININ Primary Server--->
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 203 voip
description *** INBOUND CALLS FROM ININ SYSTEM PRIMARY ***
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 204 voip
description *** INBOUND CALLS FROM ININ SYSTEM SECONDARY ***
session target ipv4:<---IP Address of ININ Secondary Server--->
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 205 voip
description *** CALLS OUTBOUND TO ININ USERS SECONDARY ***
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 206 voip
description *** Route 8036 Calls to ININ ***
destination-pattern 8036$
voice-class codec 1
no vad
dial-peer voice 207 voip
preference 2
voice-class codec 1
no vad
dial-peer voice 15 pots
destination-pattern 8057
port 0/1/1
description *** OUTBOUND to FAIRLAWN CALL MANAGER TEST ***
translation-profile outgoing FAIRLAWN-OUTBOUND
session target ipv4:<---IP Address of CUCM Subscriber Server--->
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/2
voice-class sip bind media source-interface GigabitEthernet0/2
dtmf-relay rtp-nte
no vad
description *** INCOMING CALLS FROM FAIRLAWN ****
voice-class codec 1
dtmf-relay rtp-nte
no vad
num-exp 8473 50014024651540
gateway
timer receive-rtp 1200
sip-ua
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar dns:<--- DNS Name for Skyp SIP Provider ---> expires 3600
sip-server dns:<--- DNS Name for Skyp SIP Provider --->
host-registrar
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 95
max-dn 95
ip source-address <--- IP Address of CME ---> port 2000
timeouts ringing 20
system message <--- Name of system message --->
load 7937 apps37sccp.1-4-4-0
load 6921 SCCP69xx.9-2-1-0
load 6911 SCCP6911.9-2-1-a
time-zone 43
voicemail 7999
web admin system name cmeadmin password d3l3m@
dn-webedit
time-webedit
<--- cut off from here, no need to list the 100 or so e-phones --->
Debug output, call from 8500 to 217163 (extension 7163)
Veyance_CME#term mon
Mar 12 14:30:05.440: //-1/2ACD98959A1C/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=8500
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Mar 12 14:30:05.440: //-1/2ACD98959A1C/CCAPI/cc_api_call_setup_ind_common:
Mar 12 14:30:05.440: //-1/2ACD98959A1C/CCAPI/ccCheckClipClir:
Mar 12 14:30:05.440: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 12 14:30:05.440: :cc_get_feature_vsa malloc success
Mar 12 14:30:05.440:  cc_get_feature_vsa count is 4
Mar 12 14:30:05.440: :FEATURE_VSA attributes are: feature_name:0,feature_time:504012624,feature_id:148860
Mar 12 14:30:05.440: //778281/2ACD98959A1C/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Mar 12 14:30:05.440: //778281/2ACD98959A1C/CCAPI/cc_process_call_setup_ind:
   Event=0x1620BED0
Mar 12 14:30:05.440: //778281/2ACD98959A1C/CCAPI/ccCallSetContext:
   Context=0x3AEC268
   >>>>CCAPI handed cid 778281 with tag 20096 to app "_ManagedAppProcess_Default"
Mar 12 14:30:05.440: //778281/2ACD98959A1C/CCAPI/ccCallSetupAck:
   Call Id=778281
Mar 12 14:30:05.440: //778281/2ACD98959A1C/CCAPI/cc_api_set_transfer_info:
Mar 12 14:30:05.440: //778281/2ACD98959A1C/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=778281
Mar 12 14:30:05.440: //778281/2ACD98959A1C/CCAPI/ccSetDigitTimeouts:
Mar 12 14:30:05.440: //778281/2ACD98959A1C/CCAPI/ccCallReportDigits:
   (callID=0xBE029, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=778281
Mar 12 14:30:05.440: //778281/2ACD98959A1C/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x1CA10704, callID=0xBE029, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x1CA10704, Call Id=778281
Mar 12 14:30:05.640: //778281/2ACD98959A1C/CCAPI/cc_api_call_digit_begin:
   Source Call Id=778281, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0x23E14D8, Rtp Expiration=0x0
Mar 12 14:30:05.640: //778281/2ACD98959A1C/CCAPI/cc_api_call_digit_end:
   Source Call Id=778281, Digit=2, Duration=100,
Mar 12 14:30:05.840: //778281/2ACD98959A1C/CCAPI/cc_api_call_digit_begin:
   Source Call Id=778281, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x23E91D8, Rtp Expiration=0x0
Mar 12 14:30:05.840: //778281/2ACD98959A1C/CCAPI/cc_api_call_digit_end:
   Source Call Id=778281, Digit=1, Duration=100,
Mar 12 14:30:06.040: //778281/2ACD98959A1C/CCAPI/cc_api_call_digit_begin:
   Source Call Id=778281, Digit=7, DigitBeginFlags=0x0,
   Rtp Timestamp=0x23F0ED8, Rtp Expiration=0x0
Mar 12 14:30:06.040: //778281/2ACD98959A1C/CCAPI/cc_api_call_digit_end:
   Source Call Id=778281, Digit=7, Duration=100,
Mar 12 14:30:06.240: //778281/2ACD98959A1C/CCAPI/cc_api_call_digit_begin:
Veyance_CME#Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Rtp Timestamp=0x23F8BD8, Rtp Expiration=0x0
Mar 12 14:30:06.240: //778281/2ACD98959A1C/CCAPI/cc_api_call_digit_end:
Mar 12 14:30:06.440: //778281/2ACD98959A1C/CCAPI/cc_api_call_digit_begin:
   Source Call Id=778281, Digit=6, DigitBeginFlags=0x0,
   Rtp Timestamp=0x24008D8, Rtp Expiration=0x0
Mar 12 14:30:06.440: //778281/2ACD98959A1C/CCAPI/cc_api_call_digit_end:
   Source Call Id=778281, Digit=6, Duration=100,
Mar 12 14:30:06.640: //778281/2ACD98959A1C/CCAPI/cc_api_call_digit_begin:
   Source Call Id=778281, Digit=3, DigitBeginFlags=0x0,
   Rtp Timestamp=0x24085D8, Rtp Expiration=0x0
Mar 12 14:30:06.640: //778281/2ACD98959A1C/CCAPI/cc_api_call_digit_end:
   Source Call Id=778281, Digit=3, Duration=100,
Mar 12 14:30:06.640: //778281/2ACD98959A1C/CCAPI/ccCallReportDigits:
   (callID=0xBE029, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 12 14:30:06.640: //778281/2ACD98959A1C/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x1CA10704, callID=0xBE029, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 12 14:30:06.640: //778281/2ACD98959A1C/CCAPI/ccCallProceeding:
Mar 12 14:30:06.640: //778281/2ACD98959A1C/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=210, Params=0x117C7EB4, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Mar 12 14:30:06.640: //778281/2ACD98959A1C/CCAPI/ccCheckClipClir:
   Guid=2ACD9895-8A58-11E2-9A1C-9DDB61BF2B12, Outgoing Dial-peer=210
Mar 12 14:30:06.640: //778281/2ACD98959A1C/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=8500
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=7163
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Mar 12 14:30:06.640: //778281/2ACD98959A1C/CCAPI/ccIFCallSetupRequestPrivate:
Mar 12 14:30:06.640: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 12 14:30:06.640: :cc_get_feature_vsa malloc success
Mar 12 14:30:06.640:  cc_get_feature_vsa count is 5
Mar 12 14:30:06.640: :FEATURE_VSA attributes are: feature_name:0,feature_time:504011504,feature_id:148861
Mar 12 14:30:06.640: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Mar 12 14:30:06.640: //778282/2ACD98959A1C/CCAPI/ccIFCallSetupRequestPrivate:
Mar 12 14:30:06.640: //778282/2ACD98959A1C/CCAPI/ccCallSetContext:
   Context=0x117C7E64
Mar 12 14:30:06.640: //778281/2ACD98959A1C/CCAPI/ccSaveDialpeerTag:
Mar 12 14:30:06.644: //778282/2ACD98959A1C/CCAPI/cc_api_call_proceeding:
Mar 12 14:30:06.644: //778282/2ACD98959A1C/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Mar 12 14:30:06.644: //778282/2ACD98959A1C/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:154C4914
Mar 12 14:30:06.644: //778282/2ACD98959A1C/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:7163@<---IP Address of CUCM Subscriber Server--->:5060 SIP/2.0
Via: SIP/2.0/UDP <--- IP Address of CME --->:5060;branch=z9hG4bK9C7AB7A5
To: <7163>>
Date: Tue, 12 Mar 2013 14:30:06 GMT
Call-ID: 2B854F37-8A5811E2-9A219DDB-61BF2B12@<--- IP Address of CME --->
Min-SE:  1800
Cisco-Guid: 0718117013-2321027554-2585566683-1639918354
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1363098606
Expires: 180
Content-Length: 304
v=0
o=CiscoSystemsSIP-GW-UserAgent 6860 1267 IN IP4 <--- IP Address of CME --->
s=SIP Call
c=IN IP4 <--- IP Address of CME --->
t=0 0
m=audio 30278 RTP/AVP 0 8 18 101
a=fmtp:101 0-16
Mar 12 14:30:06.960: //778282/2ACD98959A1C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Tue, 12 Mar 2013 14:56:30 GMT
Content-Length: 0
To: <7163>>
CSeq: 101 INVITE
Received:
Warning: 399 "Routing failed: ccbid=17422 socket=<--- IP Address of CME --->:5060"
Content-Length: 0
To: <7163>>;tag=969131199
CSeq: 101 INVITE
Mar 12 14:30:06.960: //778282/2ACD98959A1C/CCAPI/cc_api_call_disconnected:
   Cause Value=63, Interface=0x24701AC, Call Id=778282
Mar 12 14:30:06.960: //778281/2ACD98959A1C/CCAPI/ccCallReleaseResources:
Mar 12 14:30:06.960: //778282/2ACD98959A1C/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=778282
Mar 12 14:30:06.960: //778282/2ACD98959A1C/CCAPI/ccCallDisconnect:
Mar 12 14:30:06.960: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Mar 12 14:30:06.960: //778282/2ACD98959A1C/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Mar 12 14:30:06.960: //778282/2ACD98959A1C/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x24701AC, Tag=0x0, Call Id=778282,
Mar 12 14:30:06.960: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 12 14:30:06.960: :cc_free_feature_vsa freeing 1E0A9AE8
Mar 12 14:30:06.960:  vsacount in free is 4
Mar 12 14:30:06.960: //778281/2ACD98959A1C/CCAPI/ccCallDisconnect:
Mar 12 14:30:06.964: //778281/2ACD98959A1C/CCAPI/cc_api_get_transfer_info:
Mar 12 14:30:06.964: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Veyance_CME#ACK sip:7163@<---IP Address of CUCM Subscriber Server--->:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Mar 12 14:30:07.380: %ENVMON-5-POWER_NOTICE: : Internal Power Supply Unit  12V is UP
Veyance_CME#
Mar 12 14:30:08.048: //778281/2ACD98959A1C/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x1CA10704, Tag=0x0, Call Id=778281,
Mar 12 14:30:08.048: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 12 14:30:08.048: :cc_free_feature_vsa freeing 1E0A9F48
Mar 12 14:30:08.048:  vsacount in free is 3
Veyance_CME#
Mar 12 14:30:09.528: %ENVMON-5-POWER_NOTICE: : Internal Power Supply Unit  12V is UP
Veyance_CME#term no m
Mar 12 14:30:11.676: %ENVMON-5-POWER_NOTICE: : Internal Power Supply Unit  12V is UP
Any help is appreciated, I'm not familiar with this stuff... and I didn't config either system, so trying to figure out where all of the problems are.
Ken,
Ok..Looking deeper
The phone with extension 8500..Where is that phone. Is that not a phone registred to CCME?
The phone is saying that its originating from SIP provider not from CCME...The invite should be sometthing like this..
Rather it is this...in BOLD
Sent:
To: <7163>>
Let me run the debugs again.  It is a Cisco Ip Communicator attached to the CME.  (The CME is 3000 miles away
Can you also try this..add this command to the dial-peer
session transport tcp
