SIP Trunk works outbound to CME, not inbound to CUCM
ken.montgomery
Hi Everyone,
I've been struggling with this for a while now, gave up on the h323 connectivity and went back to SIP.  Here is the scenario:  We have a Cisco Unified Communication Manager 6.1 system in one office, which is up and running and working fine.  This system uses 4-digit dialing for internal extensions, all starting with 7XXX.  We also have a CME running at a remote location, all extensions 8XXX.  All is working fine there as well.  We have an MPLS network between the two, and IP connectivity is solid and easily visible.
Now, What I'm trying to do is allow users at the main site to call the remote site using 228xxx, which is working.  This is across SIP trunk to remote site.  The remote site should be able to dial 217xxx and get the 4-digit extension at HQ.  I see the SIP invites go out, yet the calls never go through.  I'm struggling to find a cause in the CUCM that is denying the call...
The CME Relevant configurations:
Current configuration : 49762 bytes
voice service voip
ip address trusted list
  ipv4 10.96.178.0 255.255.255.0
  ipv4 <CUCM-Primary>
  ipv4 <CUCM-Secondary>
allow-connections h323 to sip
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  h245 signal update
sip
  registrar server expires max 3600 min 3600
voice translation-rule 10
rule 10 /^21/ //
voice translation-rule 11
rule 11 /^22/ //
voice translation-profile CUCM-INBOUND
translate called 11
voice translation-profile CUCM-OUTBOUND
translate calling 10
translate called 10
dial-peer voice 210 voip
description *** OUTBOUND to CUCM CALL MANAGER TEST ***
translation-profile outgoing CUCM-OUTBOUND
destination-pattern 21....
session protocol sipv2
session target ipv4:<CUCM-Subscriber>
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 211 voip
description *** INCOMING CALLS FROM CUCM ****
group-name FairlawnIncoming
destination-pattern 8...
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
no remote-party-id
retry invite 2
retry register 10
timers connect 100
host-registrar
telephony-service
no auto-reg-ephone
authentication credential cmeadmin d3l3m@
max-ephones 95
max-dn 95
ip source-address <CME IP Address> port 2000
timeouts interdigit 3
timeouts ringing 20
system message VEYANCE
time-zone 43
voicemail 7999
max-conferences 8 gain -6
call-forward pattern 4....
moh "flash:music-on-hold.au"
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Aug 20 2012 21:17:28
Call Manager has a SIP Trunk setup with a separate device pool, Call Classification "On Net"
Again, outbound calls to the CME work fine.  Inbound from CME to CUCM do not work at all... here is a test, dialing 217163 on the CME:
I am running this with the following debugs enabled:
DIALPEER:
  debug voip dialpeer detail is ON (filter is OFF)
CCAPI:
  debug voip ccapi inout is ON (filter is OFF)
CCSIP SPI: SIP Call Statistics tracing is enabled       (filter is OFF)
CCSIP SPI: SIP Call Events tracing is enabled   (filter is OFF)
Here is the debug output from call from 8500 to 217163:
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=8500
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=8500T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=8500
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=211 Is Matched
   Result=Success(0); Incoming Dial-peer=20096 Is Matched
Mar 11 17:35:43.334: //-1/EF178EEE90B5/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=8500
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Mar 11 17:35:43.334: //-1/EF178EEE90B5/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x1CA10704, Call Info(
   Calling Number=8500,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20096, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Mar 11 17:35:43.334: //-1/EF178EEE90B5/CCAPI/ccCheckClipClir:
   In: Calling Number=8500(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=8500(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 11 17:35:43.334: :cc_get_feature_vsa malloc success
Mar 11 17:35:43.334:  cc_get_feature_vsa count is 1
Mar 11 17:35:43.334: :FEATURE_VSA attributes are: feature_name:0,feature_time:504015312,feature_id:147573
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=8500(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/cc_process_call_setup_ind:
   Event=0x1620BED0
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/ccCallSetContext:
   Context=0x117C92D4
   >>>>CCAPI handed cid 775709 with tag 20096 to app "_ManagedAppProcess_Default"
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/ccCallSetupAck:
   Call Id=775709
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=775709
Mar 11 17:35:43.338: //775709/EF178EEE90B5/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Mar 11 17:35:43.338: //775709/EF178EEE90B5/CCAPI/ccCallReportDigits:
   (callID=0xBD61D, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=775709
Mar 11 17:35:43.338: //775709/EF178EEE90B5/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x1CA10704, callID=0xBD61D, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x1CA10704, Call Id=775709
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=3000(ms))
Mar 11 17:35:43.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=775709, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0x21493D8, Rtp Expiration=0x0
Mar 11 17:35:43.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
   Source Call Id=775709, Digit=2, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
Mar 11 17:35:43.538: //-1/EF178EEE90B5/DPM/dpMatchCore:
Veyance_CME#Dial String=2, Expanded String=2, Calling Number=
   Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Mar 11 17:35:43.538: //-1/EF178EEE90B5/DPM/MatchNextPeer:
   Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=210
   Result=1
Mar 11 17:35:43.738: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
   Source Call Id=775709, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x21510D8, Rtp Expiration=0x0
Mar 11 17:35:43.738: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
   Source Call Id=775709, Digit=1, Duration=100,
Mar 11 17:35:43.738: //-1/EF178EEE90B5/DPM/dpMatchCore:
   Dial String=21, Expanded String=21, Calling Number=
Mar 11 17:35:43.738: //-1/EF178EEE90B5/DPM/MatchNextPeer:
   Result=1
Mar 11 17:35:43.938: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
   Source Call Id=775709, Digit=7, DigitBeginFlags=0x0,
   Rtp Timestamp=0x2158DD8, Rtp Expiration=0x0
Mar 11 17:35:43.938: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
   Source Call Id=775709, Digit=7, Duration=100,
Mar 11 17:35:43.938: //-1/EF178EEE90B5/DPM/dpMatchCore:
   Dial String=217, Expanded String=217, Calling Number=
Mar 11 17:35:43.938: //-1/EF178EEE90B5/DPM/MatchNextPeer:
   Result=1
Mar 11 17:35:44.138: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x2160AD8, Rtp Expiration=0x0
Mar 11 17:35:44.138: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
Mar 11 17:35:44.138: //-1/EF178EEE90B5/DPM/dpMatchCore:
   Dial String=2171, Expanded String=2171, Calling Number=
Mar 11 17:35:44.138: //-1/EF178EEE90B5/DPM/MatchNextPeer:
   Result=1
Mar 11 17:35:44.338: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
   Source Call Id=775709, Digit=6, DigitBeginFlags=0x0,
   Rtp Timestamp=0x21687D8, Rtp Expiration=0x0
Mar 11 17:35:44.338: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
   Source Call Id=775709, Digit=6, Duration=100,
Mar 11 17:35:44.338: //-1/EF178EEE90B5/DPM/dpMatchCore:
   Dial String=21716, Expanded String=21716, Calling Number=
Mar 11 17:35:44.338: //-1/EF178EEE90B5/DPM/MatchNextPeer:
   Result=1
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
   Source Call Id=775709, Digit=3, DigitBeginFlags=0x0,
   Rtp Timestamp=0x21704D8, Rtp Expiration=0x0
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
   Source Call Id=775709, Digit=3, Duration=100,
Mar 11 17:35:44.538: //-1/EF178EEE90B5/DPM/dpMatchCore:
   Dial String=217163, Expanded String=217163, Calling Number=
Mar 11 17:35:44.538: //-1/EF178EEE90B5/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=210 Is Matched
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/ccCallReportDigits:
   (callID=0xBD61D, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x1CA10704, callID=0xBD61D, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Mar 11 17:35:44.538: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Mar 11 17:35:44.538: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Mar 11 17:35:44.538: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Mar 11 17:35:44.538: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
   Dial String=217163, Expanded String=217163, Calling Number=217163T
   Match Rule=DP_MATCH_ANSWER; Calling Number=217163
   Dial String=, Expanded String=, Calling Number=217163T
   Result=-1
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=217163
   Result=Success(0); Incoming Dial-peer=210 Is Matched
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=210, Params=0x3AFB7F8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/ccCheckClipClir:
   Destination Pattern=21...., Called Number=7163, Digit Strip=FALSE
   Called Number=7163(TON=Unknow
Veyance_CME#n, NPI=Unknown),
   Redirect Number=, Display Info=Testing
   Account Number=, Final Destination Flag=FALSE,
   Guid=EF178EEE-89A8-11E2-90B5-9DDB61BF2B12, Outgoing Dial-peer=210
Mar 11 17:35:44.542: //775709/EF178EEE90B5/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=8500
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=7163
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Mar 11 17:35:44.542: //775709/EF178EEE90B5/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x24701AC, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=8500,(Calling Name=Testing)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=7163(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=210, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Mar 11 17:35:44.542: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 11 17:35:44.542: :cc_get_feature_vsa malloc success
Mar 11 17:35:44.542:  cc_get_feature_vsa count is 2
Mar 11 17:35:44.542: :FEATURE_VSA attributes are: feature_name:0,feature_time:504012176,feature_id:147574
Mar 11 17:35:44.542: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Mar 11 17:35:44.542: //775710/EF178EEE90B5/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Mar 11 17:35:44.542: //775710/EF178EEE90B5/CCAPI/ccCallSetContext:
   Context=0x3AFB7A8
Mar 11 17:35:44.542: //775709/EF178EEE90B5/CCAPI/ccSaveDialpeerTag:
Mar 11 17:35:44.542: //775710/EF178EEE90B5/CCAPI/cc_api_call_proceeding:
   Interface=0x24701AC, Progress Indication=NULL(0)
Mar 11 17:35:44.542: //775710/EF178EEE90B5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Mar 11 17:35:44.542: //775710/EF178EEE90B5/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:154D2CFC
Mar 11 17:35:44.878: //775710/EF178EEE90B5/CCAPI/cc_api_call_disconnected:
   Cause Value=63, Interface=0x24701AC, Call Id=775710
   Call Entry(Responsed=TRUE, Cause Value=63, Retry Count=0)
Mar 11 17:35:44.878: //775709/EF178EEE90B5/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Mar 11 17:35:44.878: //775710/EF178EEE90B5/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=775710
Mar 11 17:35:44.878: //775710/EF178EEE90B5/CCAPI/ccCallDisconnect:
   Cause Value=63, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=63)
   Cause Value=63, Call Entry(Responsed=TRUE, Cause Value=63)
Mar 11 17:35:44.878: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Mar 11 17:35:44.878: //775710/EF178EEE90B5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Mar 11 17:35:44.878: //775710/EF178EEE90B5/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x24701AC, Tag=0x0, Call Id=775710,
   Call Entry(Disconnect Cause=63, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Mar 11 17:35:44.878: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 11 17:35:44.878: :cc_free_feature_vsa freeing 1E0A9D88
Mar 11 17:35:44.878:  vsacount in free is 1
Mar 11 17:35:44.878: //775710/EF178EEE90B5/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x166A6DC8
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 8500
Called Number            : 7163
Source IP Address (Sig  ): 10.96.178.2
Destn SIP Req Addr:Port  : 10.96.210.2:5060
Destn SIP Resp Addr:Port : 10.96.210.2:5060
Destination Name         : 10.96.210.2
Mar 11 17:35:44.878: //775710/EF178EEE90B5/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 10.96.178.2
Source IP Port    (Media): 29942
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 63
Disconnect Cause (SIP)   : 503
Veyance_CME#
Mar 11 17:35:44.878: //775709/EF178EEE90B5/CCAPI/ccCallDisconnect:
   Cause Value=63, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Mar 11 17:35:44.878: //775709/EF178EEE90B5/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
Veyance_CME#
Mar 11 17:35:46.306: //775709/EF178EEE90B5/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x1CA10704, Tag=0x0, Call Id=775709,
Mar 11 17:35:46.306: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 11 17:35:46.306: :cc_free_feature_vsa freeing 1E0AA9C8
Mar 11 17:35:46.306:  vsacount in free is 0
In previous debugs, I did come across a SIP/2.0 503 error as well, but not at this time...
Any help/suggestions are appreciated.
38 Replies 38
ok..the manila device pool..assinged to the trunk has a cucm group in it....
go to the cucm group and ensure the subscriber is in that cucm group
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
The Problem is, that the INVITE phone number is different from the TO phone number?!
did you try
voice service voip
sip
call-route p-called-party-id
Ok, entered that command bernhard, made no difference.  Removed it to be safe it doesn't mess with anything on the sip provider we also use.
Ok, found it and set it, no change.
Ken,
you need to reset the sip trunk after you made the change. Please reset the sip trunk..do another test call and send me debug ccsip messages.
That command suggested wont help this case because the Invite and TO fields are the same..
Well call me Shirley... that worked.
Wow.
Thanks for the help everyone, I'm shocked, and thrilled that it is working.
Hi Ken,
Can you summerize the answer that solve the issue, since there are alot of helping posts at this thread.
Anas
Sure, let me try to summarize into one post that has the answer in it.
The working configuration consists of a CUCM at our corporate office connected to a CME at a remote office, via MPLS network connection.  I verified that both can communicate through simple routing, both are pingable and traceroute properly.  Next, the CME was configured as below:
In the voice service voip section:
  ipv4 <--- IP Address of CUCM Publisher --->
  ipv4 <--- IP Address of CUCM Subscriber --->
h323
  h245 signal update
sip
  bind control source-interface GigabitEthernet0/2    <--- this is the interface with the IP expected in Call Manager --->
  bind media source-interface GigabitEthernet0/2
rule 10 /^21/ //                <--- this rule strips the 21 prefix for the corporate office --->
rule 11 /^22/ //                <--- this rule strips the 22 prefix for the branch office --->
voice translation-profile <--- Coporate Office Inbound --->
translate called 11
voice translation-profile <--- Corporate Office Outbound --->
translate called 10
description *** OUTBOUND to Corporate Office ***
translation-profile outgoing <--- Corporate Office Outbound --->
session target ipv4:<---IP Address of CUCM Subscriber --->
session transport tcp
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/2
voice-class sip bind media source-interface GigabitEthernet0/2
dtmf-relay rtp-nte
no vad
description *** INCOMING CALLS FROM Corporate ****
group-name <--- Name of Corporate Incoming Group --->
session target ipv4:10.96.210.2
voice-class codec 1
dtmf-relay rtp-nte
no vad
Some of the configuration there may be extraneous, I haven't cleaned it all down to bare basics... there is translation on called being done in the Call Manager to only send 4 digits into the CME now, originally we were transferring it all.
In the call manager, have built the following
-Interbranch CCM Group, including both publisher and subscriber servers
-CME Device Pool, which is associated with Interbranch CCM Group
-Route Pattern, with 22.XXXX for the pattern, which indicates 22 is the prefix.  has the branch office SIP in the Gateway/Route list area, is considered OnNet and does pre-dot stripping
-Under Device, a Trunk, SIP Trunk for Branch office was created, using CME device pool named above, OnNet, with location specified, with CSS specified (see below), IP address of CME
-Finally, a Inbound_SIP_CSS was specified, with all of the locally accessible CSS added as being accessible
That is all I can find that we configured.  I won't say it is all necessary, but that is what I currently have.
Ken,
Thats a piece of good news.
The clue to solving the problem was this..
Warning: 399 "Routing failed: ccbid=17238 socket=:5060
Usually when you get that error it is indicative of three things..
1. Wrong Ip address configured on the sip trunk..In your case since we saw that the outbound call works with the correct ip that was not the case
2. The CUCM server your dial-peer points to is not in the CUCM group of the sip trunk (and you dont have "route on all active nodes" checked (your version doesnt have it)----This was the issue for your case..when you added the cucm subscriber to the cucm group calls started working
3. Incorrect bind config.
Anyways glad that its done and dusted...Dont forget to rate any other useful post! I think this thread deserves more than one rating
