04-25-2016 11:10 AM - edited 03-17-2019 06:42 AM
Hello Everyone!
I am confused on a seemingly harmless error/warning I am getting on a router (ISR 4351) iOS XE 03.16.00.S.155-3.S-ext.SPA
On incoming calls a "debug ccsip all" shows this:
Apr 25 12:34:22.494: //214953/C83C664091E7/SIP/Media/sipSPI_ipip_GetContentSDPForPthru: Updated SDP from inbound container:266
SIP: Warning: Unrecognized attribute (bsoft)
SIP: Trying to parse unsupported attribute at media level
SIP: Group (a= group line) attribute, level 65535 instance 1 not found.
Apr 25 12:34:22.494: //214953/C83C664091E7/SIP/Info/verbose/1/sipSPIValidateConnectionAddress: Dest port = 52146
SIP: Attribute mid, level 1 instance 1 not found.
Apr 25 12:34:22.494: //214953/C83C664091E7/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Apr 25 12:34:22.494: //214953/C83C664091E7/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: peer_tag=2201
I am unsure why this is happening or how can I resolve. I've tried a few things to no avail and just don't know enough about normalization or diversion headers to address this. I am just guessing it's where this can be fixed... ??
Please help!
Thank you and have a great day!
04-25-2016 02:44 PM
This looks like the attribute in the SDP is not supported or having issue in parsing by GW , AFAIK this is just a warning message as it won't cause any issue.
How frequent you see this message on GW? do you have any complete along with error so that i can tell which particular attribute value causing this issue and generating this error msg.
Br,
Nadeem Ahmed
04-25-2016 02:54 PM
Hello Nadeem!
thanks for replying!
Every incoming call causes 4 messages like this to be logged "SIP: Trying to parse unsupported attribute at media level", so I see hundreds of lines like this a day on the GW. As far as I can see it is the "a=bsoft: 1 image udptl t38" attribute...
I am attaching a full detailed log of "debug ccsip all"
Again, thanks!
04-25-2016 09:56 PM
Hello Mario,
It seems like GW unable to understand and parse this attribute value "a=bsoft: 1 image udptl t38" generating warning message.
Received:
INVITE sip:8702027015@65.124.27.90:5060 SIP/2.0
Via: SIP/2.0/UDP 21.20.6.9:5100;branch=z9hG4bKv3tg5e306065pbnt62j0.1
From: "CORRAL,MARIO"<sip:6787945491@voip.centurylink.com;user=phone>;tag=1447024678-1461605662438-
To: "8702027015 8702027015"<sip:8702027015@voip.centurylink.com>
Call-ID: BW113422438250416883169632@10.73.16.5
CSeq: 658390900 INVITE
Contact: <sip:6787945491@21.20.6.9:5100;transport=udp>
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Recv-Info: x-broadworks-client-session-info
Accept: application/btbc-session-info,application/media_control+xml,application/sdp,multipart/mixed
Max-Forwards: 69
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 266
v=0
o=BroadWorks 435188536 1 IN IP4 21.20.6.9
s=-
c=IN IP4 21.20.6.9
t=0 0
m=audio 52146 RTP/AVP 18 0 96
a=rtpmap:18 G729/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:96 telephone-event/8000
a=fmtp:96 0-15
a=sendrecv
a=ptime:2
Br,
Nadeem Ahmed
