Skype as sip ua
techguy
Level 4
Level 4
We are planning to route our international calling traffic via Skype. Our existing setup is as below
Cisco CallManager 7.1.5 with H.323 gateways
Gateways 2951, 2921, 2911, 2901
My question is whats is CUBE? Do i need CUBE for it, Our existing hardware support CUBE.
22 Replies 22
Do we need to change some parameters on CUCM also in order to call?
Do i need to purchase CUBE license? Since i can configure all the commands related to CUBE.
Is CUBE licensines is honor based?
Do i need to purchase CUBE license? Since i can configure all the commands related to CUBE. ==> Yes
Is CUBE licensines is honor based? ==> Yes, though this could change in the future releases.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps5640/order_guide_c07_462222.html
yes , you have to purchase CUBE licenses.
Thank you
please rate all useful information
for CUCM configuration please find the below:-
1-Add SIP Trunk security profile information
System-security profile -Add new
Incoming transport type:TCP+UDP
outgoing transport type:UDP
2-Add SIP Trunk
device- trunk -SIP
3-Route pattern for SIP ourgoing calls
E.X:9.!
Thank you
Do i need to change inboumd/outbound fast start on gateway pages?
What will happen if i configured CUBE config without license activation?
You will need to enable fast start if you want to do early offer on your sip leg to your provider. You cant have slow start on h323 to EO on your CUBE..
If you dont have licenses, you are committing a crime and cisco will probably send police down to your office!
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
If this is the only punishment then i am going to use CUBE. Will purchase later .
Thanks aokanlawon
