software feature license for CUCM8.5
hanimolani
Dear All
I upgraded my call manager form ver 4 to ver 8.5 and I got my DLU  by DMA.
Everything is ok but the DMA just export my DLU and Node license. As  you know we need also “software feature license”. So how can I get SW feature  license? Is there a specific part number for that?
Rob Huffman
Hi Hani,
If you ordered the 8.5 DVD's from Cisco via PUT (Product Upgrade Tool)
the PAK should be included and can be submitted to receive the Software feature
license
Cheers!
Rob
Hi Rob
Actually I downloaded the upgrade – ISO- file for CUCM 8.5. So?
