some numbers are not routed
engreda22
In can't call any local number starts with 46
below the call information and attached the logging
Call Control Block (CCB) : 0x0x30E10E8
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           : 4552
Called Number            : 94646677
Source IP Address (Sig  ): 172.20.201.18
Destn SIP Req Addr:Port  : 10.0.32.220:5060
Destn SIP Resp Addr:Port : 10.0.32.220:54271
Destination Name         : 10.0.32.220
000643: Jul 27 16:37:55.320: //155969/AE4141000000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711ulaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 172.20.201.18
Source IP Port    (Media): 30136
Destn  IP Address (Media): 10.0.32.220
Destn  IP Port    (Media): 26106
Orig Destn IP Address:Port (Media): [ - ]:0
000644: Jul 27 16:37:55.320: //155969/AE4141000000/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 57
Disconnect Cause (SIP)   : 403
any advice please
The CUCM is sending an Early Offer INVITE now. That means you have enabled MTP on the SIP trunk. The codec being sent in the INVITE is G711ulaw. In order to change this, go to the SIP trunk and look for "MTP Preferred Originating Codec" and change it from default G711ulaw to G711alaw.
16 Replies 16
Chris Deren
This error is what you need to chase:
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP 10.68.12.194:5060;branch=z9hG4bK1B7BA04
Record-Route: <sip:10.200.7.157:5060;transport=udp;lr>
Call-ID: 852F5C25-339B11E5-9868D278-86C302A3@10.68.12.194
From: "reda tvtc"<sip:2504552@10.68.12.194>;tag=B2522D20-598
To: <sip:4646677@10.200.7.157>;tag=sbc0802o4fokucf
CSeq: 101 INVITE
Reason: Q.850;cause=57;text="bearer capability not authorized"
What country is this in?
What codec is expected to be used?
the service located in KSA
all other calls are working fine even local and national
attached the config file
Thanks for information. It looks like somehow the Service Provider does not like the format of the number you sent or the Provider has mistakenly barred your Local Call Services (it is doubtful but possible).
Could you please try sending the complete E.164 Format for the Local calls and see if it works, e.g. Presuming you are in Riyadh, please try using the following format +966-11-4646677
More over, just wondering I would want to see, if the 9 is really be stripped before the digits are being sent to the Carrier
this is the update from the provider ..
PCMA as first priority
PCMA as second priority
INVITE sip:4646677@10.200.0.7:5060 SIP/2.0
Via: SIP/2.0/UDP 10.141.194.62:5060;branch=z9hG4bK1E5CF05T00459
Record-Route: <sip:10.141.194.62:5060;transport=udp;lr>
Call-ID: isbcE9DEA50F-353111E5-84F3D278-86C302A3@10.68.12.194
From: "reda tvtc"<sip:2504552@10.200.0.7>;tag=sbc0804BCB97EC8-D8A
To: <sip:4646677@10.200.0.7>
CSeq: 101 INVITE
Date: Wed, 29 Jul 2015 14:06:59 GMT
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a
Allow: INVITE,OPTIONS,BYE,CANCEL,ACK,PRACK,UPDATE,REFER,SUBSCRIBE,NOTIFY,INFO,REGISTER
Contact: <sip:2504552@10.141.194.62:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Session-Expires: 1800
Remote-Party-ID: "reda tvtc" <sip:2504552@10.68.12.194>;party=calling;screen=yes;privacy=off
Cisco-Guid: 0311822592-0000065536-0000002170-3693084682
Content-Length: 244
Content-Type: application/sdp
Content-Disposition: session;handling=required
v=0
o=- 5881 1407 IN IP4 10.201.20.45
s=SBC call
c=IN IP4 10.201.20.45
t=0 0
m=audio 38004 RTP/AVP 0 101 19
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
To: <sip:4646677@10.200.0.7>;tag=tskakp4u
CSeq: 101 INVITE
Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR"
Content-Length: 0
any advise  please
but u send invite with
so do
conf t
dial-peer voice 140 voip
 codec  g711alaw
On your dialpeers facing the ITSP, can you make sure the you configure G711alaw statically and take off any voice-class.
thanks  Mohamed for your reply
if I have an issue , other calls should stopped as well .am I right ?
local and national calls are working fine
Not necessary. It depends how your ITSP is matching incoming calls. If itsp is matching all calls on single dialpeer then your thinking is valid. But if they have multiple dialpeers which might be the case here then you can have different behaviour for different calls.
In anyway your itsp is advising to make g711alaw as primary codec so we need to follow them
Dear Mohamed ,
based on the attached file
the call matches dial-peer 140 and 200
both dial peer 200 and 140 are using voice codec 1
voice codec 1 is using the required codec format
any advice how to clear this ?
thanks
Thanks a lot Tagir .. solved  :)
now my question is  why only this pattern was getting dropped ?
Thanks again for all for time and appreciate your kind support
I think call goes from cube to itsp border switch a then to the next switch 46..... witch only supports 711a
Looking at the config, all looks good. The message indicate there is a codec problem. Try to contact your ITSP and see what are they matching for calls starting with 46. Sounds to be different codec that rest of number within same dialpeer.
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729r8
 codec preference 4 g729br8
 codec preference 5 g728
 description *** Outgoing Local calls,HLatta ***
 translation-profile outgoing OUT-SIP
 destination-pattern 9[1245678]......
 session protocol sipv2
 session target ipv4:10.200.7.157
 voice-class codec 1
 dtmf-relay rtp-nte
but in sip invite only one codec  g711ulaw
000606: Jul 27 16:37:55.208: //155970/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4646677@10.200.7.157:5060 SIP/2.0
From: "reda tvtc" <sip:2504552@10.68.12.194>;tag=B2522D20-598
v=0
m=audio 30138 RTP/AVP 0 101 19
only one codec  g711ulaw in invite from cucm to cube
make another good call and share log
and ask provider what codecs supported
