ISDN PRI Incomming call not working
Hi Guys, I am a newbie on VOIP deployment and I need help on configuring a UC560 router for PRI lines. I have configured the telephone services through telephony wizard and out going is fine but incoming is not. Could you help me out on what i am missing, please.
Here is my Config:
! Last configuration change at 14:28:39 ZP4 Fri Oct 5 2012 by Nick
! NVRAM config last updated at 14:30:28 ZP4 Fri Oct 5 2012
version 15.1
parser config cache interface
no service pad
service password-encryption
service internal
service compress-config
service sequence-numbers
hostname UC_560
boot-start-marker
boot system flash:uc500-advipservicesk9-mz.151-2.T4
boot-end-marker
card type e1 0 3
logging buffered 4096
enable secret 5 $1$jBkK$MvGRqUJppu0AhLgDlludA.
enable password 7 072E2541470739544541
no aaa new-model
clock timezone ZP4 4 0
network-clock-participate wic 3
network-clock-select 1 E1 0/3/0
crypto pki trustpoint TP-self-signed-2799234853
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2799234853
revocation-check none
crypto pki certificate chain TP-self-signed-2799234853
certificate self-signed 01
  3082023E 308201A7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32373939 32333438 3533301E 170D3132 30393238 31373438
  31345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37393932
  33343835 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009AA9 DE0F74E4 6DD7D616 6119BCF2 B777A37B 39AEF9AE 4A4697B2 B5C8552F
  52C6DB8D 72842308 0C1DD6D9 FD1D0D98 594EAEDE FC8E0790 641BEC77 A2FEB24C
  F56D2E59 A8938AAF EB8F9E5C 3AABBCEF DD9D564E 1F3159DA E6B75180 D520C9A2
  0E7FD0A1 590A7906 C16E2BE2 401F60D3 B1899046 A99A5403 4D31D4E0 F52789EF
  51130203 010001A3 66306430 0F060355 1D130101 FF040530 030101FF 30110603
  551D1104 0A300882 0655435F 35363030 1F060355 1D230418 30168014 6F998CAF
  A54CCFE0 FF267994 608B0479 91B73B1E 301D0603 551D0E04 1604146F 998CAFA5
  4CCFE0FF 26799460 8B047991 B73B1E30 0D06092A 864886F7 0D010104 05000381
  8100002A 177ED9DA BE7469D7 A41F2771 D5FC6912 C0AB8DBD 67F7889A F5ADC36D
  57E8B51F 5656D9B8 7F20B22E EC3DA7BF 6CC466E2 21B3E243 5ED86470 896661F4
  49F510D0 1334862B F3B47E91 A4440D87 1C125643 AB07D20E EBC485E7 B2D3FA9B
  ADAC3B52 35FE771A 23BF8DCB 396840C0 A98CC2B1 1F3C74DE 49262C61 1F615297 4A58
      quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.9
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp pool phone
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   option 150 ip 10.1.1.1
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
isdn switch-type primary-net5
trunk group ALL_T1E1
hunt-scheme longest-idle
translation-profile outgoing PROFILE_ALL_T1E1
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class dualtone-detect-params 1
freq-max-deviation 25
freq-max-power 0
freq-min-power 13
freq-power-twist 4
cadence-variation 4
voice class custom-cptone UAE-CUSTOM-SIEMENS
dualtone disconnect
  frequency 425
  cadence 425 325 250 500
voice class custom-cptone CCAjointone
dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice class custom-cptone CCAleavetone
dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
dualtone disconnect
  frequency 406
  cadence 398 344 237 527 400
voice class cause-code 1
no-circuit
voice register global
voice hunt-group 1 parallel
list 203,204,210
timeout 16
pilot 511
voice translation-rule 4
rule 15 /^...$/ /6979999/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile INCOMING_CallerID_PROFILE
translate calling 3265
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PROFILE_ALL_T1E1
translate calling 4
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
license udi pid UC560-FXO-K9 sn FHK1419F0WY
archive
log config
  logging enable
  logging size 600
  hidekeys
username Nick privilege 15 secret 5 $1$6RyB$7oNX8aEt5tdBTG5tc7lsQ0
controller E1 0/3/0
framing NO-CRC4
pri-group timeslots 1-20
process-max-time 50
ip tftp source-interface Vlan90
gw-accounting aaa
gw-accounting file
primary ftp 192.168.1.250/cdr username oak password 7 01160803520503
acct-template callhistory-detail
maximum buffer-size  25
maximum retry-count 3
maximum fileclose-timer 300
maximum cdrflush-timer 245
interface GigabitEthernet0/0
ip address 192.168.201.2 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description Interface used to manage integrated application modulecue is initialized with default IMAP group
ip unnumbered Vlan90
ip nat inside
shutdown
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1/0
switchport access vlan 100
macro description cisco-switch
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
spanning-tree portfast
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
switchport access vlan 90
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn map address . plan unknown type unknown
isdn supp-service name calling
isdn sending-complete
isdn outgoing ie redirecting-number
trunk-group ALL_T1E1
no cdp enable
interface Vlan1
description $FW_INSIDE$
ip address 10.1.3.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1412
interface Vlan90
ip address 10.1.10.2 255.255.255.252
ip nat inside
interface Vlan100
ip address 10.1.1.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.201.1
logging esm config
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 100 deny   ip 192.168.1.0 0.0.0.255 any
access-list 101 deny   ip 192.168.1.0 0.0.0.255 any
access-list 102 deny   ip 192.168.1.0 0.0.0.255 any
access-list 104 deny   ip 192.168.1.0 0.0.0.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
dialer-list 1 protocol ip permit
snmp-server community public RO
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-4-2.bin alias spa525g-7-4-2.bin
tftp-server flash:/phones/5x5/spa5x5-7-4-2.bin alias spa5x5-7-4-2.bin
tftp-server flash:/phones/7906_7911/apps11.8-5-3TH1-6.sbn alias apps11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-5-3TH1-6.sbn alias cnu11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-5-3TH1-6.sbn alias cvm11sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-5-3TH1-6.sbn alias dsp11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-5-3TH1-6.sbn alias jar11sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-5-3S.loads alias SCCP11.8-5-3S.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7914/S00105000400.sbn alias S00105000400.sbn
tftp-server flash:/phones/7915/B015-1-0-4.SBN alias B015-1-0-4.SBN
tftp-server flash:/phones/7916/B016-1-0-4.SBN alias B016-1-0-4.SBN
tftp-server flash:/phones/7921/APPS-1.3.3.SBN alias APPS-1.3.3.SBN
tftp-server flash:/phones/7921/CP7921G-1.3.3.LOADS alias CP7921G-1.3.3.LOADS
tftp-server flash:/phones/7921/GUI-1.3.3.SBN alias GUI-1.3.3.SBN
tftp-server flash:/phones/7921/MISC-1.3.3.SBN alias MISC-1.3.3.SBN
tftp-server flash:/phones/7921/SYS-1.3.3.SBN alias SYS-1.3.3.SBN
tftp-server flash:/phones/7921/TNUX-1.3.3.SBN alias TNUX-1.3.3.SBN
tftp-server flash:/phones/7921/WLAN-1.3.3.SBN alias WLAN-1.3.3.SBN
tftp-server flash:/phones/7925/APPSH-1.3.3.SBN alias APPSH-1.3.3.SBN
tftp-server flash:/phones/7925/CP7925G-1.3.3.LOADS alias CP7925G-1.3.3.LOADS
tftp-server flash:/phones/7925/GUIH-1.3.3.SBN alias GUIH-1.3.3.SBN
tftp-server flash:/phones/7925/MISCH-1.3.3.SBN alias MISCH-1.3.3.SBN
tftp-server flash:/phones/7925/SYSH-1.3.3.SBN alias SYSH-1.3.3.SBN
tftp-server flash:/phones/7925/TNUXH-1.3.3.SBN alias TNUXH-1.3.3.SBN
tftp-server flash:/phones/7925/WLANH-1.3.3.SBN alias WLANH-1.3.3.SBN
tftp-server flash:/phones/7931/apps31.8-5-3TH1-6.sbn alias apps31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/cnu31.8-5-3TH1-6.sbn alias cnu31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/cvm31sccp.8-5-3TH1-6.sbn alias cvm31sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/dsp31.8-5-3TH1-6.sbn alias dsp31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/jar31sccp.8-5-3TH1-6.sbn alias jar31sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/SCCP31.8-5-3S.loads alias SCCP31.8-5-3S.loads
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/phones/7936/cmterm_7936.3-3-20-0.bin alias cmterm_7936.3-3-20-0.bin
tftp-server flash:/phones/7937/apps37sccp.1-3-4-0.bin alias apps37sccp.1-3-4-0.bin
tftp-server flash:/phones/7940_7960/P00308010200.bin alias P00308010200.bin
tftp-server flash:/phones/7940_7960/P00308010200.loads alias P00308010200.loads
tftp-server flash:/phones/7940_7960/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:/phones/7940_7960/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:/phones/7941_7961/apps41.8-5-3TH1-6.sbn alias apps41.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/cnu41.8-5-3TH1-6.sbn alias cnu41.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.8-5-3TH1-6.sbn alias cvm41sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/dsp41.8-5-3TH1-6.sbn alias dsp41.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.8-5-3TH1-6.sbn alias jar41sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/SCCP41.8-5-3S.loads alias SCCP41.8-5-3S.loads
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
tftp-server flash:/phones/7942_7962/apps42.8-5-3TH1-6.sbn alias apps42.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/cnu42.8-5-3TH1-6.sbn alias cnu42.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.8-5-3TH1-6.sbn alias cvm42sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/dsp42.8-5-3TH1-6.sbn alias dsp42.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/jar42sccp.8-5-3TH1-6.sbn alias jar42sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/SCCP42.8-5-3S.loads alias SCCP42.8-5-3S.loads
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/phones/7945_7965/apps45.8-5-3TH1-6.sbn alias apps45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-5-3TH1-6.sbn alias cnu45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-5-3TH1-6.sbn alias cvm45sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-5-3TH1-6.sbn alias dsp45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-5-3TH1-6.sbn alias jar45sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-5-3S.loads alias SCCP45.8-5-3S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/phones/7970_7971/apps70.8-5-3TH1-6.sbn alias apps70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/cnu70.8-5-3TH1-6.sbn alias cnu70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-5-3TH1-6.sbn alias cvm70sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-5-3TH1-6.sbn alias dsp70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-5-3TH1-6.sbn alias jar70sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-5-3S.loads alias SCCP70.8-5-3S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/phones/7975/apps75.8-5-3TH1-6.sbn alias apps75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/cnu75.8-5-3TH1-6.sbn alias cnu75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/cvm75sccp.8-5-3TH1-6.sbn alias cvm75sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/dsp75.8-5-3TH1-6.sbn alias dsp75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/jar75sccp.8-5-3TH1-6.sbn alias jar75sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/SCCP75.8-5-3S.loads alias SCCP75.8-5-3S.loads
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
control-plane
voice-port 0/0/0
cptone AE
shutdown
station-id number 401
caller-id enable
voice-port 0/0/1
cptone AE
shutdown
station-id number 402
caller-id enable
voice-port 0/0/2
cptone AE
shutdown
station-id number 403
caller-id enable
voice-port 0/0/3
cptone AE
shutdown
station-id number 404
caller-id enable
voice-port 0/3/0:15
cptone AE
bearer-cap Speech
voice-port 0/1/0
translation-profile incoming INCOMING_CallerID_PROFILE
supervisory disconnect dualtone mid-call
supervisory custom-cptone UAE-CUSTOM-SIEMENS
supervisory dualtone-detect-params 1
no battery-reversal
input gain 14
cptone AE
connection plar opx 511
shutdown
description Configured by CCA 4 FXO-0/1/0-Custom-BG
caller-id enable
voice-port 0/1/1
no battery-reversal
input gain 14
cptone AE
shutdown
description Configured by CCA 4 FXO-0/1/1-Custom-BG
caller-id enable
voice-port 0/1/2
no battery-reversal
input gain 14
cptone AE
shutdown
description Configured by CCA 4 FXO-0/1/2-Custom-BG
caller-id enable
voice-port 0/1/3
no battery-reversal
input gain 14
cptone AE
shutdown
description Configured by CCA 4 FXO-0/1/3-Custom-BG
caller-id enable
voice-port 0/2/0
no battery-reversal
input gain 14
cptone AE
shutdown
description Configured by CCA 2FXO-0/2/0-Custom-BG
caller-id enable
voice-port 0/2/1
no battery-reversal
input gain 14
cptone AE
timeouts call-disconnect 1
timeouts wait-release 2
shutdown
description Configured by CCA 2 FXO-0/2/1-Custom-BG
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Vlan90
sccp ccm 10.1.1.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register confprof1
dspfarm profile 1 conference
description DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
codec g711ulaw
codec g711alaw
maximum sessions 6
conference-join custom-cptone CCAjointone
associate application SCCP
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 401
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 402
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 403
port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 404
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
shutdown
destination-pattern 299
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 6 pots
description "catch all dial peer for BRI/PRI"
translation-profile incoming nondialable
incoming called-number 6979
direct-inward-dial
dial-peer voice 67 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*UAE-DIALPLAN*Emergency call**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9999
forward-digits all
no sip-register
dial-peer voice 100 pots
port 0/2/0
dial-peer voice 101 pots
port 0/2/1
dial-peer voice 300 voip
destination-pattern 3[0-5].
session target ipv4:192.168.101.2
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 150 pots
direct-inward-dial
port 0/3/0:15
no dial-peer outbound status-check pots
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm tag 1 confprof1
conference hardware
video
fxo hook-flash
max-ephones 114
max-dn 600
ip source-address 10.1.1.1 port 2000
max-redirect 20
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service phone webAccess 0
service dnis overlay
service dnis dir-lookup
timeouts interdigit 4
system message American Center
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
load 7914 S00105000400
load 7915-12 B015-1-0-4
load 7915-24 B015-1-0-4
load 7916-12 B016-1-0-4
load 7916-24 B016-1-0-4
load 7906 SCCP11.8-5-3S
load 7911 SCCP11.8-5-3S
load 7921 CP7921G-1.3.3
load 7925 CP7925G-1.3.3
load 7931 SCCP31.8-5-3S
load 7936 cmterm_7936.3-3-20-0
load 7937 apps37sccp.1-3-4-0
load 7960-7940 P00308010200
load 7941 SCCP41.8-5-3S
load 7941GE SCCP41.8-5-3S
load 7942 SCCP42.8-5-3S
load 7945 SCCP45.8-5-3S
load 7961 SCCP41.8-5-3S
load 7961GE SCCP41.8-5-3S
load 7962 SCCP42.8-5-3S
load 7965 SCCP45.8-5-3S
load 7970 SCCP70.8-5-3S
load 7971 SCCP70.8-5-3S
load 7975 SCCP75.8-5-3S
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-2
load 501G spa5x5-7-4-2
load 502G spa5x5-7-4-2
load 504G spa5x5-7-4-2
load 508G spa5x5-7-4-2
load 509G spa5x5-7-4-2
time-zone 35
voicemail 299
max-conferences 8 gain -6
call-forward pattern .T
hunt-group logout HLog
moh MOH2.wav
multicast moh 239.10.16.16 port 2000
web admin system name adminac secret 5 $1$BoxD$Po7msaWxNq65xO9uptLL71
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp 7960 Aug 08 2012 17:48:02
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd HLog Login
softkeys seized  Cfwdall Endcall Redial Pickup Meetme Gpickup Callback
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn ConfList RmLstC Acct Park Select Join
button-layout 7931 2
ephone-template  16
softkeys remote-in-use  CBarge Newcall
softkeys idle  Redial Newcall Cfwdall Dnd HLog
softkeys seized  Cfwdall Endcall Redial Callback
softkeys connected  Hold Endcall Trnsfer Confrn
ephone-template  17
ephone-template  18
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  16  dual-line
number 201 no-reg primary
label 201
description Ahmed Mostafa
name Ahmed Mostafa
call-forward busy 299
call-forward noan 299 timeout 20
ephone-dn  17  dual-line
number 206 no-reg primary
label 206
description Second
name Hatem CC
ephone-dn  18  dual-line
number 204 no-reg primary
label 204
description Hatem-CC
name Hatem CC
ephone-dn  24  dual-line
number 202 no-reg primary
label 202
description Wael Mahdi
name Wael Mahdi
ephone-dn  35
number 235
label 235
description Executive Secretary
name Manaa Aswad
ephone-dn  37  dual-line
number 228 no-reg primary
label 228
description 228
name 228
ephone-dn  38  dual-line
number 229 no-reg primary
label 229
description 229
name 229
ephone-dn  45  dual-line
number 236 no-reg primary
label 236
description Dr. Imad Yassin
name Dr. Imad Yassin
ephone-dn  46  dual-line
number 237 no-reg primary
label 237
description 237
name 237
ephone-dn  47  dual-line
number 238 no-reg primary
label 238
description 238
name 238
ephone-dn  48  dual-line
number 239 no-reg primary
label 239
description 239
name 239
ephone-dn  49  dual-line
number 240 no-reg primary
label 240
description 240
name 240
ephone-dn  50  dual-line
number 241 no-reg primary
label 241
description Aliya Sardar
name Aliya Sardar
ephone-dn  52  dual-line
number 243 no-reg primary
label 243
description Consultation-five
name ConsultationFive
ephone-dn  53  dual-line
number 244 no-reg primary
label 244
description Medical Director
name Medical Director
ephone-dn  54  dual-line
number 245 no-reg primary
label 245
description Consult Seven
name Consult Seven
ephone-dn  55  dual-line
number 246 no-reg primary
label 246
description Aida Qasim
name Aida Qasim
ephone-dn  56  dual-line
number 247 no-reg primary
label 247
description Azhar Iman
name Azhar Iman
ephone-dn  57  dual-line
number 248 no-reg primary
label 248
description 248
name 248
ephone-dn  58  dual-line
number 249 no-reg primary
label 249
description 249
name 249
ephone-dn  59  dual-line
number 250 no-reg primary
label 250
description 250
name 250
ephone-dn  60  dual-line
number 251 no-reg primary
label 251
description 251
name 251
ephone-dn  61  dual-line
number 252 no-reg primary
label 252
description 252
name 252
ephone-dn  62  dual-line
number 253 no-reg primary
label 253
description 253
name 253
ephone-dn  63  dual-line
number 254 no-reg primary
label 254
description 254
name 254
ephone-dn  64  dual-line
number 255 no-reg primary
label 255
description 255
name 255
ephone-dn  65  dual-line
number 256 no-reg primary
label 256
description 256
name 256
ephone-dn  66  dual-line
number 257 no-reg primary
label 257
description 257
name 257
ephone-dn  67  dual-line
number 258 no-reg primary
label 258
description 258
name 258
ephone-dn  68  dual-line
number 259 no-reg primary
label 259
description 259
name 259
ephone-dn  69  dual-line
number 260 no-reg primary
label 260
description 260
name 260
ephone-dn  70  dual-line
number 261 no-reg primary
label 261
description 261
name 261
ephone-dn  71  dual-line
number 262 no-reg primary
label 262
description 262
name 262
ephone-dn  79  dual-line
number 270 no-reg primary
label 270
description 270
name 270
ephone-dn  80  dual-line
number 271 no-reg primary
label 271
description 271
name 271
ephone-dn  81  dual-line
number 272 no-reg primary
label 272
description 272
name 272
ephone-dn  82  dual-line
number 273 no-reg primary
label 273
description 273
name 273
ephone-dn  83  dual-line
number 274 no-reg primary
label 274
description 274
name 274
ephone-dn  84  dual-line
number 275 no-reg primary
label 275
description 275
name 275
ephone-dn  85  dual-line
number 276 no-reg primary
label 276
description 276
name 276
ephone-dn  86  dual-line
number 277 no-reg primary
label 277
description 277
name 277
ephone-dn  87  dual-line
number 278 no-reg primary
label 278
description 278
name 278
ephone-dn  88  dual-line
number 279 no-reg primary
label 279
description 279
name 279
ephone-dn  89  dual-line
number 280 no-reg primary
label 280
description 280
name 280
ephone-dn  90  dual-line
number 281 no-reg primary
label 281
description 281
name 281
ephone-dn  91  dual-line
number 282 no-reg primary
label 282
description 282
name 282
ephone-dn  92  dual-line
number 283 no-reg primary
label 283
description 283
name 283
ephone-dn  93  dual-line
number 284 no-reg primary
label 284
description 284
name 284
ephone-dn  94  dual-line
number 285 no-reg primary
label 285
description 285
name 285
ephone-dn  95  dual-line
number 286 no-reg primary
label 286
description 286
name 286
ephone-dn  96  dual-line
number 287 no-reg primary
label 287
description 287
name 287
ephone-dn  98  dual-line
number 289 no-reg primary
label 289
description 289
name 289
ephone-dn  99  dual-line
number 290 no-reg primary
label 290
description 290
name 290
ephone-dn  100  dual-line
number 291 no-reg primary
label 291
description 291
name 291
ephone-dn  101  dual-line
number 292 no-reg primary
label 292
description 292
name 292
ephone-dn  102  dual-line
number 293 no-reg primary
label 293
description 293
name 293
ephone-dn  103  dual-line
number 294 no-reg primary
label 294
description 294
name 294
ephone-dn  104  dual-line
number 295 no-reg primary
label 295
description 295
name 295
ephone-dn  105  dual-line
number 296 no-reg primary
label 296
description 296
name 296
ephone-dn  106  dual-line
number 297 no-reg primary
label 297
description 297
name 297
ephone-dn  107  dual-line
number 298 no-reg primary
label 298
description 298
name 298
ephone-dn  551  octo-line
number 773 no-reg primary
conference meetme
ephone-dn  552  octo-line
number 772 no-reg primary
conference meetme
ephone-dn  553  octo-line
number 771 no-reg primary
conference meetme
ephone-dn  554  octo-line
number C003 no-reg primary
conference ad-hoc
ephone-dn  555  octo-line
number C002 no-reg primary
conference ad-hoc
ephone-dn  556  octo-line
number C001 no-reg primary
conference ad-hoc
ephone-dn  559  dual-line
number 218 no-reg primary
label 218
description RCPT 1FL. BlockA
name RCPT 1FL. BlockA
ephone-dn  570  dual-line
number 234 no-reg primary
label 234
description Pharmacy
name Pharmacy
ephone-dn  572  dual-line
number 217 no-reg primary
label 217
description Adel
name Adel
ephone-dn  573  dual-line
number 200 no-reg primary
label 200
description Ferie Abellana
name Ferie Abellana
ephone-dn  574  dual-line
number 213 no-reg primary
label 213
description Cashier AC
name Cashier AC
ephone-dn  575  dual-line
number 215 no-reg primary
label 215
description Consultation AC
name Consultation AC
ephone-dn  576  dual-line
number 214 no-reg primary
label 214
description Nursing AC
name Nursing AC
ephone-dn  577  dual-line
number 207 no-reg primary
label 207
description Records AC
name Records AC
ephone-dn  578  dual-line
number 221 no-reg primary
label 221
description Reception FirstF
name Reception FirstFlore
ephone-dn  579  dual-line
number 209 no-reg primary
label 209
description Yasmin Belal
name Yasmin Belal
ephone-dn  580  dual-line
number 211 no-reg primary
label 211
description Reception GroundF
name Reception Ground
ephone-dn  581
number A579 no-reg primary
name Yousef Abulaban
intercom A776 label "RECEPTION"
ephone-dn  582
number A776 no-reg primary
name Reception SecondF
intercom A579 label "Dr.YOUSEF"
ephone-dn  583  dual-line
number 231 no-reg primary
label 231
description Reception SecondF
ephone-dn  584  dual-line
number 208 no-reg primary
label 208
description Nadia Khatib
name Nadia Khatib
ephone-dn  585  dual-line
number 233 no-reg primary
label 233
description Yousef Abulaban
ephone-dn  586  dual-line
number 212 no-reg primary
label 212
description Khaldoun Mozahem
name Khaldoun Mozahem
ephone-dn  587  dual-line
number 225 no-reg primary
label 225
description Salwa Hanna
name Salwa Hanna
ephone-dn  588  dual-line
number 224 no-reg primary
label 224
description Asma Nahed
name Asma Nahed
ephone-dn  589  dual-line
number 223 no-reg primary
label 223
description Ingrid Krynauw
name Ingrid Krynauw
ephone-dn  590  dual-line
number 222 no-reg primary
label 222
description Sue Partridge
name Sue Partridge
ephone-dn  591  dual-line
number 205 no-reg primary
label 205
description Secondline
name Lalaine CC
ephone-dn  592  dual-line
number 232 no-reg primary
label 232
description Atif Mustafa
name Atif Mustafa
ephone-dn  593  dual-line
number 210 no-reg primary
label 210
description Zahra CC
name Zahra CC
ephone-dn  594  dual-line
ephone-dn  595  dual-line
number 203 no-reg primary
label 203
description Lalaine-CC
name Lalaine CC
ephone-dn  596  dual-line
number 216 no-reg primary
label 216
description Sally Alhasan
name Sally Alhasan
ephone-dn  597  dual-line
number 226 no-reg primary
label 226
description Eva Jajonie
name Eva Jajonie
ephone-dn  598
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 399
ephone-dn  599
number A801... no-reg primary
mwi off
ephone-dn  600
number A800... no-reg primary
mwi on
ephone  1
device-security-mode none
mac-address 30E4.DB80.B4C0
max-calls-per-button 2
type 502G
button  1:35
ephone  2
mac-address 7081.05B3.4FDE
ephone-template 16
username "cashierac" password 123456
type 525G2 addon 1 500S
button  1:574 6m16 7m24 8m577
button  9m584 10m579 11m586 12m575
button  13m596 14m590 15m589 16m588
button  17m587 18m597 19m592 20m585
ephone  3
mac-address 30E4.DB80.B3EB
ephone-template 16
username "amustafa" password 123456
type 502G
button  1:592
ephone  4
mac-address 7081.05B3.4FE8
ephone-template 16
username "rground" password 123456
button  1:580 6m16 7m24 8m577
button  9m584 10m579 11m586 12m574
button  13m576 14m575 15m596 16m590
button  17m589 18m588 19m587 20m597
button  21m592 22m585
ephone  5
mac-address 30E4.DB80.B612
ephone-template 16
username "spartridge" password 123456
type 502G
button  1:590
ephone  6
mac-address 30E4.DB80.B615
ephone-template 16
username "asardar" password 123456
type 502G
button  1:588
ephone  7
mac-address 30E4.DB80.B606
ephone-template 16
username "ikrynauw" password 123456
type 502G
button  1:589
ephone  8
mac-address 30E4.DB80.B5FD
ephone-template 16
username "kmozahem" password 123456
type 502G
button  1:586
ephone  9
mac-address 30E4.DB80.B5E8
ephone-template 16
username "Amostafa" password 123456
type 502G
button  1:16
ephone  10
mac-address 7081.05B3.508E
ephone-template 16
username "hatemcc" password 123456
button  1:18 2:17 6m16 7m24
button  8m577 9m584 10m579 11m586
button  12m574 13m576 14m575 15m596
button  16m590 17m589 18m588 19m587
button  20m597 21m592 22m585 23m570
button  25m572 26m559 27m50
ephone  11
mac-address 30E4.DB80.B5F6
ephone-template 16
username "zhashim" password 123456
type 502G
button  1:24
ephone  12
mac-address 30E4.DB80.8E88
ephone-template 16
username "ejajonie" password 123456
fastdial 1 9043708091 name test
type 502G
button  1:597
ephone  13
mac-address 7081.05B3.508A
ephone-template 16
username "cclalaine" password 123456
button  1:595 2:591 6m16 7m24
ephone  14
mac-address 30E4.DB80.B616
ephone-template 16
username "shanna" password 123456
type 502G
button  1:587
ephone  15
mac-address 7081.053D.5D10
ephone-template 16
username "aradwan" password 123456
type 502G
button  1:584
ephone  16
mac-address 7081.05B3.530E
ephone-template 16
username "rfirstflore" password 123456
button  1:578 6m16 7m24 8m577
ephone  17
mac-address 7081.05B3.5026
ephone-template 16
username "rsecondf" password 123456
button  1:583 5:582 6m16 7m24
ephone  18
mac-address 7081.053D.5D0D
ephone-template 16
username "ybelal" password 123456
type 502G
button  1:579
ephone  19
mac-address 7081.053D.300D
ephone-template 16
username "recordsac" password 123456
type 502G
button  1:577
ephone  20
mac-address 30E4.DB2A.3E05
ephone-template 16
username "nursingac" password 123456
type 502G
button  1:576
ephone  21
mac-address 7081.053D.5CB3
ephone-template 16
username "consultation" password 123456
type 502G
button  1:575
ephone  22
mac-address CCEF.485D.8F2C
ephone-template 16
username "yabulaban" password 123456
type 504G
button  1:585 2:581
ephone  23
mac-address 1CDF.0F4A.F844
ephone-template 16
username "fabellana" password 123456
type 502G
button  1:573
ephone  24
mac-address 1CDF.0F4A.F914
ephone-template 16
username "ConsultationGone" password 123456
type 502G
button  1:572
ephone  25
mac-address 1CDF.0F4A.F84A
ephone-template 16
username "ConsultationGtwo" password 123456
type 502G
button  1:559
ephone  26
mac-address 1CDF.0F4A.F856
type 502G
ephone  27
mac-address E05F.B981.9034
type 502G
button  1:45
ephone  28
mac-address 1CDF.0F4A.F8BB
ephone-template 16
username "ConsultationGfour" password 123456
type 502G
button  1:50
ephone  29
mac-address 7081.05B3.527C
ephone-template 16
button  1:593 2:52 6m16 7m24
ephone  30
mac-address 1CDF.0F4A.F8B9
ephone-template 16
username "receptionsectwo" password 123456
type 502G
button  1:570
ephone  31
mac-address E05F.B981.90EE
type 502G
button  1:56
ephone  32
ephone  33
mac-address 1CDF.0F4A.F7DC
ephone-template 16
type 502G
button  1:53
ephone  35
mac-address 1CDF.0F4A.F8B7
ephone-template 16
type 502G
button  1:55
alias exec cca_voice_mode PBX
banner login  banner login ^Cisco Configuration Assistant. Version: 3.2. Tue Mar 20 16:07:37 GST 2012^
line con 0
exec-timeout 0 0
logging synchronous
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
speed 115200
line vty 0 4
exec-timeout 0 0
login local
transport input all
line vty 5 100
login local
transport input all
ntp master
end
That's one big output of a config.
I have looked through it but can't find that any translation for called number incoming from the PRI is done anywhere. I might have overlooked it based on that I used my phone to look at the config.
Do a debug isdn q931 to see what you receive from the Telco and then create the voice translation rule and profile from that. You can attach the profile incoming to one of these, voice port, trunk group, controller E1/T1 or incoming dial peer. Based on your config I would recommend you to use it on the trunk group.
Please rate all useful posts.
Response Signature
6 Replies 6
jbroderick
Level 5
Level 5
You are going to want to see if the ISDN channel is up.
debug isdn q921
If the channel is up, you can watch call flow
debug isdn q931
It isn't much. I haven't had to fight ISDN channels for awhile.
Response Signature
Thanks Roger, you're right when i run the debug for isdn q931 I was able to create the right translation for the incoming calls.
Glad to hear that you got it running. Thanks for the nice rating.
Response Signature
I understand that the Telco  sends DNIS which differ than the configured dial-peers. Hence, we needed to do translation.
Is it correct?
Shakir Manaam
Wow.. Thank you guys...
This post was very helpful. I used the debug q31 command and found that the DID to be used is 3 digit.
I was using 4 digit translation.
Once again thank you very much...
