02-20-2013 07:54 AM - edited 03-16-2019 03:50 PM
Our customer needs the possibility to play recordings, for example when the line is busy or after closing hours. Is this function integrated in CUCM9.0? I was thinking of Customer Response Application which I know from our CallManager4.2.
Thank you very much in advance for your help.
Kindest regards,
Natalie Thomas
Solved! Go to Solution.
02-20-2013 08:20 AM
Hi Natalie
CRA (which later morphed into the Contact Center suite I believe) was always delivered on a separate server to CUCM.
This is still true in version 9.x and CUCM doesn't do this natively. However a much more cost effective way to do this would be to use Cisco Unity Connection voicemail. You can write your own call handlers which can be driven based on schedules.
HTH.
Barry Hesk
Intrinsic Network Solutions
02-20-2013 09:04 AM
Hi Natalie,
I'll just add another option to the great tips from Barry (+5 "B" )
With the release of CUCM 9.x there is native Call Queuing (with message
recordings) which might be used for your busy situations.
The "co-resident" install capabilities with CRA/IPCC & CUCM was
deprecated with the release of CUCM 5.x I believe;
here's some "old" info just as an FYI;
You can install Cisco CRA 3.1 in either of these basic server configurations:
Cheers!
Rob
"What you don't have you don't need it now"
- U2
02-20-2013 08:20 AM
Hi Natalie
HTH.
Barry Hesk
02-20-2013 09:04 AM
Hi Natalie,
Cheers!
Rob
- U2
02-22-2013 02:21 AM
Great, that was more than helpful!
Thanks a lot,
Natalie
