SQL Query Assistance
chuck47172
Looking for the command line to run a query that will return the MAC adddress, DN and number mask.
Ritesh Desai
Hi @chuck47172  Check if this helps you.
https://community.cisco.com/t5/collaboration-voice-and-video/useful-sql-queries-in-cucm/ta-p/3773875
Please rate helpful post
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
Thanks for the info however this is not what I trying to query. I should have been more detailed in my request, sorry.
the mask I'm referring to is the e164mask.
The following command shows what I am after but it does not show the MAC address of the phone that is using the e164mask.
run sql select dnorpattern, d.description, e164mask, tkpatternusage from devicenumplanmap inner join numplan on fknumplan=numplan.pkid join device d on fkdevice = d.pkid
