06-12-2015 10:53 AM - edited 03-17-2019 03:20 AM
Does anyone happen to know a query which can be run on CUCM for license count total installed?
I was able to dig out one for license count in use btw in case anyone needs it. But need it for monitoring purposes can't use license report via gui.
admin:run sql SELECT name,value FROM TABLE (FUNCTION LicenseTotals()) (pkid,name,value,UserValue,DeviceValue)
06-12-2015 12:26 PM
Hello Jay,
Does the CUCM Report does not fit to you?Only thourgh CLI?
Leonardo Santana
06-12-2015 02:43 PM
Hey Leo,
Well it would be good if I just had to do it one time. But this is for one of our polling tools. So have to find a way where I can do it via ssh(i.e. cli). It's really difficult to cut stuff up from http.
J
11-09-2015 05:04 PM
Same problem here.
The ELM web interface can produce the info so there must be a way. Anyone?
11-10-2015 12:20 AM
Refer to below link in order to understand License Calculation in CUCM 9.x and above:
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/117600-technote-cucm-00.html#anc6
Deepak
