SRST 8.1 Phones not registering
aman.kapuria
Level 4
Level 4
c2900-universalk9-mz.SPA.151-2.T1.bin
CONFIG (Version=8.1)
Version 8.1
Pure H323 setup. Reference set in call manager. Phones just go in loop saying registering. I can see that default gateway is the router itself in phone. All 7942 phones with firmware sccp 42.8-5-3s
Any ideas/suggestions/bug reports appreciated
Aaron Harrison
Perhaps start by posting your configuration.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
call-manager-fallback
secondary-dialtone 0
max-conferences 4 gain -6
transfer-system full-consult
timeouts interdigit 3
ip source-address 192.168.255.25 port 2000
max-ephones 24
max-dn 50 dual-line
system message primary SRST
default-destination 298
voicemail 6148
moh ivision_new.wav
multicast moh x.x.x.x port 16384 route 192.168.255.25 192.168.60.1
time-zone 48
time-format 24
date-format dd-mm-yy
Hi Aman!
  I'm running into this same exact issue, TAC doesn't seem to have an answer for it.  Were you able to determine the issue and did you find a work around?
Thank you...
Hi Mate
As far as i remember, i had a wrong srst reference set in the call manager device pool. was a silly mistake. You might want to post your configuration and check the srst reference.
Cheers
Aman
