SRST Compatibility for Different Phone Loads.
Joey De Wiele
Is there some way to determine SRST compatibility with different phone loads? For example, I can see that SRST 8.0 works fine with SCCP45.8-5-3S but when I try  the default 9.1.2 phone load SCCP45.9-3-1SR2-1S I see that SRST 8.0 doesn't work so well. Is there somewhere I can look up a phone load and see what versions of SRST that load is compatible with?
Joey
7 Replies 7
V.Naveen Kumar
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/requirements/guide/srs80spc.html
Check this matrix
Thanks for the reply.
Unfortunately that document shows me a single load that's compatible with SRST version 8.0. What I need is a document that says "for this phone load here are all the compatible versions of SRST".
There's no such doc, it's unrealistic to expect testing for every single FW release, Vs. Every single SRST versions.
java
if this helps, please rate
Java is right but there´s a bug on firmware 9.x that is affecting SRST on V.8, That´s why I was asking for the IOS version of the router.
Take a look of this bug CSCte08121   as well as this link
https://supportforums.cisco.com/discussion/11172581/srst-terminals-register-no-ephone-dn-sccp-firmware-higher-84
Thanks for that link, it was useful.
It seems from above that if I'm upgrading CUCM, particularly for a "big jump", like 7.1.3 to 9.1.2:
  1. It's "unreasonable" for me to ask what SRST versions are compatible with the new phone loads. I'm OK with this I guess.
  2. Unless I'm using one of the few explicitly supported combinations of SRST and phone loads that I better test things first.
thanks for sharing the bug[+5]
regds,
aman
vhilario
What´s your router´s IOS version?
