SRST mode outbound T1 fail, only prefix goes to SRST?
samhopealpha
Level 2
Level 2
Hi everybody,
I have a problem, on the outbound call during SRST mode with T1.
Here is the background
SRST gateway
- image: c2900-universalk9-mz.SPA.154-1.T1
- 4 x FXO (2 x analog circuit is connected to Telco)
- 2 x 2MFT-T1/E1 (all 4 ports are T1, and 2 T1 circuit is connected to Telco)
- IP phone is SCCP phone 7975
dial-peer pots preference are
dial-peer voice 99993 pots
description (T1 #2)
preference 1
destination-pattern 9T
port 0/1/0:23
dial-peer voice 99994 pots
description (T1 #2)
preference 2
port 0/2/0:23
dial-peer voice 99991 pots
description (Analog #1)
preference 3
port 0/0/0
dial-peer voice 99992 pots
description (Analog #2)
preference 4
port 0/0/1
and SRST configure
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 5
ip source-address 10.10.10.3 port 2000
max-ephones 50
max-dn 50
system message primary SRST fallback
keepalive 20
When in normal status (Connected with CUCM), all inbound and outbound calls are working great.
(outbound pots sequence are tested and worked correctly)
When in SRST mode, all inbound calls are OK, except the outbound call
1. if make an outbound call by using IP phone, the T1 seems not work.
- then tried the "csim start <phone_number>" in SRST gateway, the outbound call be made
e.g. csim start 911112222, outbound is ok
- if turned on the debug voice ccapi inout, we found that the IP phone seem pass the prefix to VG only
e.g. if dial 911112222 on IP phone, the SRST VG only see the "dest=9", and then pass the 9 to T1 circuit
2. if unplug all T1 circuit phycially, outbound call can be made via the Analog circuit
Anybody know what mistake do I met? or any missing?
Thanks in advance
Sam
Dennis Mink
Can you include these logs.
also If you create a specific dial-peer for instance:
description (T1 #2)
preference 1
destination-pattern  911112222
port 0/1/0:23
does it work?????
personally,   I dont like the 9T "catch all" pattern and prefer to add the national numbering plan of whatever country you are in using various dial-peers.  but that is my preference.
Please remember to rate useful posts, by clicking on the stars below.
Since the issue is only happened during the SRST mode, and the site is in production.
Sorry that I cannot perform a test currently.
However, when using csim start 911112222, the outbound call can be made
And if using the IP phone to dial 911112222, the phone seems only pass the 9 to SRST gateway, all other rest of digits (11112222) doesn't go to SRST gateway.
Attached the log of debug voice ccapi inout
Nov 12 03:45:57.411: //-1/004DFA47A505/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=599
----- ccCallInfo IE subfields -----
cisco-ani=599
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=9
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Nov 12 03:45:57.415: //-1/004DFA47A505/CCAPI/cc_api_call_setup_ind_common:
Interface=0x2242D644, Call Info(
Calling Number=599,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=9 (TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=111105, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=902
And the Dial-peer 111105 has no translation-profile
