SRST only allowing for digits to be dialed
jakins12
I have a site with an H323 gateway that when phones are registered SRST,  will only allow the phones to dial 4 digits.  Incoming calls work and internal extension dialing work as well.
Here is the runing confige on the router
interface Loopback0
description Must use loopback for H323
ip address 10.1.117.1 255.255.255.255
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.1.117.1
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
no ip address
speed auto
full-duplex
no mop enabled
interface FastEthernet0/0.1
description DataVlan
encapsulation dot1Q 1 native
ip address 192.168.17.6 255.255.255.0
interface FastEthernet0/0.10
description VoiceVlan
encapsulation dot1Q 10
ip address 192.168.117.254 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
router rip
redistribute connected
network 192.168.17.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.17.252
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
logging facility local1
logging source-interface Loopback0
logging 192.168.117.1
logging 192.168.117.254
dialer-list 1 protocol ip permit
snmp-server community Kemper RW
snmp-server enable traps tty
control-plane
voice-port 0/0/0
supervisory disconnect dualtone mid-call
input gain 3
output attenuation 0
timeouts wait-release 2
timing min-ring 62
connection plar 1700
description Need Phone Number
caller-id enable
voice-port 0/0/1
input gain 3
timing min-ring 62
caller-id enable
voice-port 0/0/2
input gain 3
timing min-ring 62
caller-id enable
voice-port 0/0/3
input gain 3
timing min-ring 62
caller-id enable
dial-peer voice 2 pots
incoming called-number .
dial-peer voice 7000 voip
destination-pattern 7...
voice-class codec 1
session target ipv4:192.168.151.10
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 14 pots
destination-pattern 8T
port 0/0/0
dial-peer voice 15 pots
port 0/0/1
dial-peer voice 16 pots
preference 10
port 0/0/2
dial-peer voice 17 pots
preference 9
port 0/0/3
dial-peer voice 921 pots
preference 5
destination-pattern 911
prefix 911
dial-peer voice 911 pots
port 0/0/0
prefix 911
dial-peer voice 912 pots
port 0/0/1
prefix 911
dial-peer voice 913 pots
preference 10
port 0/0/2
prefix 911
dial-peer voice 914 pots
preference 9
port 0/0/3
prefix 911
dial-peer voice 1000 voip
destination-pattern 1...
voice-class codec 1
no vad
call-manager-fallback
max-conferences 4 gain -6
transfer-system full-consult
ip source-address 10.1.117.1 port 2000
max-ephones 30
max-dn 150
system message primary SRST Mode
system message secondary SRST Mode
default-destination 1710
alias 1 1700 to 1710
line con 0
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
password !Cs!^)@kcpag
transport input none
line vty 5 15
privilege level 15
password !Cs!&)@kcpag
transport input telnet ssh
scheduler allocate 20000 1000
ntp clock-period 17207731
ntp server 130.126.24.53
end
interface Loopback0
no ip address
speed auto
full-duplex
no mop enabled
no ip address
shutdown
duplex auto
speed auto
router rip
ip http server
control-plane
voice-port 0/0/0
input gain 3
timing min-ring 62
caller-id enable
voice-port 0/0/1
input gain 3
timing min-ring 62
caller-id enable
voice-port 0/0/2
input gain 3
timing min-ring 62
caller-id enable
voice-port 0/0/3
input gain 3
timing min-ring 62
caller-id enable
voice-class codec 1
no vad
port 0/0/0
port 0/0/1
preference 10
port 0/0/2
preference 9
port 0/0/3
preference 5
prefix 911
port 0/0/0
prefix 911
port 0/0/1
prefix 911
preference 10
port 0/0/2
prefix 911
preference 9
port 0/0/3
prefix 911
voice-class codec 1
no vad
max-ephones 30
max-dn 150
line con 0
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
line vty 5 15
privilege level 15
end
Ayodeji Okanlawon
Are you saying you are unable to dial externally then?
Can you send us a debug voip ccapi inout and a debug vpm signal
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
