SRST-SCCP-PHONE-7905
abdulkarim041
Level 2
Level 2
I have configured SRTS as under:
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 192.168.132.1 port 2000
max-ephones 5
max-dn 5
keepalive 20
CUCM configurations are attached.
issue is that from phone settings  "calla manager 1" under 192.168.132.92 active is present.
but SRST IP address is not present.
R1#sh call-manager-fallback
CONFIG (Version=10.5)
Version 10.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
max-ephones 5
max-dn 5
dspfarm units 0
dspfarm transcode sessions 0
huntstop
no huntstop channel
huntstop channel 0
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 20 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
Limit number of DNs per phone:
12SP: 76
7902: 76
7905: 76
7906: 76
7910: 76
7911: 76
7912: 76
7920: 76
7921: 76
7925: 76
7931: 76
7935: 76
7936: 76
7937: 76
7940: 76
7941: 76
7941GE: 76
7942: 76
7945: 76
7960: 76
7961: 76
7961GE: 76
7962: 76
7965: 76
7970: 76
7971: 76
7975: 76
7985: 76
anl: 76
ata: 76
bri: 76
CIPC: 76
vgc-phone: 76
IP-STE: 76
6921: 76
6941: 76
6961: 76
6901: 76
6911: 76
7926: 76
6945: 76
8941: 76
8945: 76
Log (table parameters):
max-size: 150
retain-timer: 15
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Brandon Buffin
Did you assign this SRST reference to the proper device pool?
Brandon
8 Replies 8
Brandon Buffin
Brandon
Hi Brandon,
Yes I have applied to proper device pool.
BR
Abdul Karim
And the device pool is assigned to the phone?
Yes Device pool is assigned to phone
Did you reset the device pool and phone?
Yes I reset device pool and Phone as well
I have connected 7965 to network SRST was working normal for it.
But 7912 or 7905 it is not working. for your reference one image is attached.
Can you verify the TFTP server configured on the phone? Is it manually configured or obtained via DHCP? Is it the same on both working and non-working phones?
Brandon
