02-27-2017 05:17 AM - edited 03-17-2019 09:39 AM
I have configured SRTS as under:
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 192.168.132.1 port 2000
max-ephones 5
max-dn 5
keepalive 20
CUCM configurations are attached.
issue is that from phone settings "calla manager 1" under 192.168.132.92 active is present.
but SRST IP address is not present.
R1#sh call-manager-fallback
CONFIG (Version=10.5)
Version 10.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
max-ephones 5
max-dn 5
dspfarm units 0
dspfarm transcode sessions 0
huntstop
no huntstop channel
huntstop channel 0
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 20 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
Limit number of DNs per phone:
12SP: 76
7902: 76
7905: 76
7906: 76
7910: 76
7911: 76
7912: 76
7920: 76
7921: 76
7925: 76
7931: 76
7935: 76
7936: 76
7937: 76
7940: 76
7941: 76
7941GE: 76
7942: 76
7945: 76
7960: 76
7961: 76
7961GE: 76
7962: 76
7965: 76
7970: 76
7971: 76
7975: 76
7985: 76
anl: 76
ata: 76
bri: 76
CIPC: 76
vgc-phone: 76
IP-STE: 76
6921: 76
6941: 76
6961: 76
6901: 76
6911: 76
7926: 76
6945: 76
8941: 76
8945: 76
Log (table parameters):
max-size: 150
retain-timer: 15
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Solved! Go to Solution.
02-27-2017 05:26 AM
Did you assign this SRST reference to the proper device pool?
Brandon
02-27-2017 05:26 AM
Brandon
02-27-2017 05:30 AM
Hi Brandon,
Yes I have applied to proper device pool.
BR
Abdul Karim
02-27-2017 05:56 AM
And the device pool is assigned to the phone?
02-27-2017 05:57 AM
Yes Device pool is assigned to phone
02-27-2017 06:00 AM
Did you reset the device pool and phone?
02-27-2017 09:49 PM
Yes I reset device pool and Phone as well
02-27-2017 11:43 PM
02-28-2017 06:12 AM
Can you verify the TFTP server configured on the phone? Is it manually configured or obtained via DHCP? Is it the same on both working and non-working phones?
Brandon
