07-31-2012 12:49 PM - edited 03-16-2019 12:28 PM
I have been pulling documentation together and I know that the earlier versions of IOS 15.x don't have support for 6945s. Since I can't find support for them in any 12.4 SRST documentation, I assume 12.4 doesn't support it either but I thought I would put the question out here before I start upgrading a bunch of 2811s from 12.4 code to 15.x code.
Has anyone gotten 6941s to work (basic functionality) with 12.4 versions of IOS?
EDITED: Changed 6945s to 6941s
Solved! Go to Solution.
07-31-2012 02:00 PM
These appear to be supported since SRST 8.0 which is 15.1.1T
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/requirements/guide/srs80spc.html
HTH, please rate all useful posts!
Chris
07-31-2012 01:27 PM
Looks like it was added in SRST 8.8
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/requirements/guide/srs88spc.html
which is 15.2.1T
Chris
07-31-2012 01:52 PM
I just re-read what I wrote and I apologize but I meant 6941s, not 6945s. These are SCCP.
Kyle
07-31-2012 02:00 PM
Chris
