02-01-2022 11:53 AM
Hai Guys
I just installed Voice Gateway Router with the version 17.5 (SLUP), but I haven't registered to the CSSM Server.
Is this the factor why my VG Router can't SRST ?
Here's the SRST configuration that i configured on VG.
Please Advise
Thank You
Solved! Go to Solution.
02-14-2022 10:22 PM - edited 02-14-2022 10:26 PM
Word of notice, I have not looked at the last configuration, or whatever you shared.
What I shared earlier is for both SIP and SCCP SRST. This should cover what you need.
02-01-2022 10:51 PM
Are you using SRST on a CUBE with a SIP trunk to the provider?
If yes, it is mandatory to use a tenant configuration
There were also some other posts about tenants the last weeks, you might also wanna check them out
What you are definitely missing:
voice service voip sip registrar server expires max 240 min 60 bind all source-interface <internal interface>
voice register global
default mode (is srst)
dialplan-pattern 1 .... (4-digit-dn)
call-manager-fallback
no sip-ua
--- Please rate this post as "Helpful" or accept as a solution, if your question has been answered ---
02-02-2022 01:09 AM - edited 02-14-2022 10:28 PM
For reference this is from our configuration template for voice gateways.
[A.A.A.A] = LAN Interface IP Address (Voice Vlan) SRST configuration The below is functions in SRST configuration that are shared between SCCP and SCCP. • MOH configuration, file(s) and multicast. • Alias configuration. • Default destination. • Date and time format. • Conference settings. • Transfer settings. • Secondary dial tone. voice translation-rule 50 rule 1 /^466xxxx$/ /00046xxxxxxxx/ rule 2 /^466xxxx$/ /00046xxxxxxxx/ rule 3 /^632\(....\)$/ /+632xxx\1/ rule 4 /^\+632\(.*\)/ /0\1/ rule 5 /^\+63\(.*\)/ /00\1/ rule 6 /^\+\(.*\)/ /000\1/ ! voice translation-profile SRST-IN translate called 50 SCCP SRST configuration ccm-manager music-on-hold call-manager-fallback translation-profile incoming SRST-IN secondary-dialtone 0 max-conferences 8 gain -6 transfer-system full-consult timeouts interdigit 5 ip source-address [A.A.A.A] port 2000 max-ephones 128 ;set max-ephones to the maximum that router model can support max-dn 256 dual ;max-dn should be set to double amount of max-ephones system message primary SRST Failover default-destination +632xxxxxx moh SampleMOH.wav multicast moh 239.10.138.16 port 16384 route [A.A.A.A] 192.168.255.10 time-zone 41 time-format 24 date-format dd-mm-yy Note: If the site has FXS ports that are controlled via SCCP this is needed for them to operate in SRST as they will not use the normal SRST reference setup in CUCM. sccp ccm [A.A.A.A] identifier 1 version 7.0 ! sccp ccm group 10 associate ccm 1 priority 4 SIP SRST configuration voice service voip allow-connections sip to sip sip registrar server ! voice register global default mode system message SRST Failover max-dn 256 ;max-dn should be set to double amount of max-pool max-pool 128 ;set max-pool to the maximum that router model can support timezone 41 phone-mode phone-only ! voice register pool 1 id network x.x.x.x mask y.y.y.y ;x.x.x.x,/y.y.y.y refer to network range assigned to entire site, not just the voice vlan translation-profile incoming SRST-IN dtmf-relay rtp-nte voice-class codec 1 no vad ! sip-ua registrar ipv4:[A.A.A.A] expires 3600
Hopefully that could be of help to you.
02-14-2022 09:28 AM
Hai @Roger Kallberg
Sorry for the late reply.
Whether the above configuration is different if using SIP between SIP?
Thank You
02-14-2022 10:22 AM
What do you mean by “using SIP between SIP”?
02-14-2022 09:51 PM
Hai @Roger Kallberg
I have an IP Phone with SIP Protocol, can this configuration also be used ?
Thank You
