SRST
gksi-chr-rus
Hi all,
I have a problem, on the inbound call during SRST mode with E1.
Here is the background
SRST gateway
- image: c2900-universalk9-mz.SPA.154-3.M8.bin
- 1 E1 port (VWIC3-2MFT-T1/E1)
- IP phone is SCCP phone CIPS
- IP phone is SIP phone 7861
ccm-manager fallback-mgcp
call-manager-fallback
alias 1 368004 to 1094 cfw 368004 timeout 20
alias 2 368004 to 1006 cfw 368004 timeout 20
alias 3 368004 to 1007 cfw 368004 timeout 20
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.58.103.2 port 2000
max-ephones 200
max-dn 200 dual-line
system message primary SRST
time-zone 32
time-format 24
date-format dd-mm-yy
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
sip-ua
registrar ipv4:10.58.205.2 expires 600
voice register global
mode esrst
system message SIP SRST
max-dn 200
max-pool 1
voice register pool 1
id network 10.58.0.0 mask 255.255.0.0
no digit collect kpml
dtmf-relay rtp-nte cisco-rtp sip-notify
voice-class codec 1
dial-peer voice 9 pots
translation-profile outgoing 9
max-conn 20
destination-pattern 9T
incoming called-number 368004
direct-inward-dial
port 0/0/0:15
forward-digits all
voice translation-rule 9
rule 1 /..../ /368004/
voice translation-rule 10
rule 1 /^9/ //
voice translation-profile 9
translate calling 9
translate called 10
When in normal status (Connected with CUCM), all inbound and outbound calls are working great.
When in SRST mode, all outbound calls are OK, except the inbound call
- if make an inbound call by using alias 1 and DN 1094 in phone CIPS (SCCP), calls are working.
- if make an inbound call by using alias 1 and DN 1094 in phone 7861 (SIP), call not work (Cause i = 0x8081 - Unallocated/unassigned number). Нowever, local call from 1XXX to 1094 in phone 7861 (SIP) is ok.
9 Replies 9
R0g22
I don't see your voice register global config for SIP SRST. For SIP SRST alias to work you would need a outgoing translation profile as well. Alias does not work the same way it does for SCCP.
Sorry, not fully copied configuration. My voice register global config below:
 mode esrst
 system message SIP SRST Batyr
 max-dn 100
 max-pool 1
Tell me how to configure SIP SRST alias.
You need to have something like the following -
voice register pool X
alias 1 12345 to 6789
translation-profile outgoing to-sip-phone
Voice translation-rule 1
rule 1 /12345/ /6789/
Voice translation-profile alias-srst
translate called 1
In my case is missing translation-profile outgoing to-sip-phone:
r2921-bat(config-register-pool)#trans?
transfer transfer-pattern
and command alias return an error:
r2921-bat(config-register-pool)#alias 1 61400 to 2304
Failed: CME mode!
When you do a show run | s voice register global, what do you see as the mode ? You cannot have translations in ESRST. You will need mode srst for alias and translation config.
I don't have a mode srst :(
r2921-bat(config-register-global)#mode ?
 cme CME mode
 esrst ESRST mode
That's because its the default. You already have srst enabled. The other two options that you can now have are either CME or ESRST.
When the phones are in SRST mode get the following output.
show voice register poo all br
show dial-p vo su
R3925#show voice register poo all br
Pool ID IP Address Ln DN Number State
1       10.58.0.0        UNREGISTERED
R3925#show dial-p vo su
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT
20859 pots up down 0 50/0/9
20860 pots up down 0 50/0/10
skippied pots.......................................................................
40006 voip up up 1093$ 0 syst ipv4:10.58.7.173:506
40008 voip up up 1071$ 0 syst ipv4:10.58.7.160:506
40005 voip up up 1099$ 0 syst ipv4:10.58.7.122:506
40009 voip up up 1090$ 0 syst ipv4:10.58.7.168:506
40007 voip up up 1067$ 0 syst ipv4:10.58.7.94:5060
40010 voip up up 1075$ 0 syst ipv4:10.58.7.67:5060
40011 voip up up 1018$ 0 syst ipv4:10.58.7.154:506
40013 voip up up 1045$ 0 syst ipv4:10.58.7.213:506
40014 voip up up 1088$ 0 syst ipv4:10.58.7.156:506
40020 voip up up 1057$ 0 syst ipv4:10.58.7.243:506
40017 voip up up 1044$ 0 syst ipv4:10.58.7.142:506
40018 voip up up 1106$ 0 syst ipv4:10.58.7.54:5060
40015 voip up up 1061$ 0 syst ipv4:10.58.7.179:506
40021 voip up up 1085$ 0 syst ipv4:10.58.7.148:506
40016 voip up up 1042$ 0 syst ipv4:10.58.7.234:506
40029 voip up up 1005$ 0 syst ipv4:10.58.7.230:506
40019 voip up up 1032$ 0 syst ipv4:10.58.7.82:5060
40023 voip up up 1025$ 0 syst ipv4:10.58.7.75:5060
40026 voip up up 1066$ 0 syst ipv4:10.58.7.186:506
40025 voip up up 1053$ 0 syst ipv4:10.58.7.102:506
40027 voip up up 1063$ 0 syst ipv4:10.58.7.147:506
40028 voip up up 1006$ 0 syst ipv4:10.58.7.64:5060
40030 voip up up 1056$ 0 syst ipv4:10.58.7.185:506
40031 voip up up 1046$ 0 syst ipv4:10.58.7.236:506
40032 voip up up 1040$ 0 syst ipv4:10.58.7.130:506
40024 voip up up 1037$ 0 syst ipv4:10.58.7.76:5060
40100 voip up up 1017$ 0 syst ipv4:10.58.7.151:506
40033 voip up up 1103$ 0 syst ipv4:10.58.7.144:506
40034 voip up up 1065$ 0 syst ipv4:10.58.7.233:506
40037 voip up up 1026$ 0 syst ipv4:10.58.7.178:506
40035 voip up up 1021$ 0 syst ipv4:10.58.7.69:5060
40036 voip up up 1016$ 0 syst ipv4:10.58.7.180:506
40039 voip up up 1030$ 0 syst ipv4:10.58.7.83:5060
40045 voip up up 1023$ 0 syst ipv4:10.58.7.136:506
40038 voip up up 1069$ 0 syst ipv4:10.58.7.155:506
40040 voip up up 1113$ 0 syst ipv4:10.58.7.158:506
40041 voip up up 1086$ 0 syst ipv4:10.58.7.249:506
40044 voip up up 1115$ 0 syst ipv4:10.58.7.149:506
40042 voip up up 1105$ 0 syst ipv4:10.58.7.207:506
40048 voip up up 1004$ 0 syst ipv4:10.58.7.157:506
40046 voip up up 1059$ 0 syst ipv4:10.58.7.239:506
40047 voip up up 1050$ 0 syst ipv4:10.58.7.79:5060
40071 voip up up 1048$ 0 syst ipv4:10.58.7.109:506
40073 voip up up 1119$ 0 syst ipv4:10.58.7.66:5060
40050 voip up up 1097$ 0 syst ipv4:10.58.7.117:506
40022 voip up up 1072$ 0 syst ipv4:10.58.7.214:506
40052 voip up up 1039$ 0 syst ipv4:10.58.7.123:506
40055 voip up up 1038$ 0 syst ipv4:10.58.7.196:506
40053 voip up up 1077$ 0 syst ipv4:10.58.7.254:506
40051 voip up up 1036$ 0 syst ipv4:10.58.7.162:506
40054 voip up up 1055$ 0 syst ipv4:10.58.7.188:506
40003 voip up up 1027$ 0 syst ipv4:10.58.7.152:506
40058 voip up up 1095$ 0 syst ipv4:10.58.7.217:506
40056 voip up up 1078$ 0 syst ipv4:10.58.7.231:506
40059 voip up up 1110$ 0 syst ipv4:10.58.7.222:506
40057 voip up up 1096$ 0 syst ipv4:10.58.7.224:506
40062 voip up up 1081$ 0 syst ipv4:10.58.7.183:506
40087 voip up up 1116$ 0 syst ipv4:10.58.7.74:5060
40101 voip up up 1003$ 0 syst ipv4:10.58.7.193:506
40086 voip up up 1034$ 0 syst ipv4:10.58.7.197:506
40085 voip up up 1098$ 0 syst ipv4:10.58.7.223:506
40102 voip up up 1020$ 0 syst ipv4:10.58.7.172:506
40068 voip up up 1064$ 0 syst ipv4:10.58.7.55:5060
40063 voip up up 1087$ 0 syst ipv4:10.58.7.228:506
40061 voip up up 1084$ 0 syst ipv4:10.58.7.252:506
40060 voip up up 1108$ 0 syst ipv4:10.58.7.203:506
40064 voip up up 1058$ 0 syst ipv4:10.58.7.194:506
40067 voip up up 1043$ 0 syst ipv4:10.58.7.244:506
40065 voip up up 1091$ 0 syst ipv4:10.58.7.167:506
40074 voip up up 1012$ 0 syst ipv4:10.58.7.165:506
40072 voip up up 1060$ 0 syst ipv4:10.58.7.146:506
40066 voip up up 1047$ 0 syst ipv4:10.58.7.174:506
40069 voip up up 1024$ 0 syst ipv4:10.58.7.219:506
40076 voip up up 1062$ 0 syst ipv4:10.58.7.200:506
40080 voip up up 1094$ 0 syst ipv4:10.58.7.205:506
40070 voip up up 1102$ 0 syst ipv4:10.58.7.176:506
40079 voip up up 1019$ 0 syst ipv4:10.58.7.226:506
40075 voip up up 1114$ 0 syst ipv4:10.58.7.237:506
40077 voip up up 1002$ 0 syst ipv4:10.58.7.153:506
40081 voip up up 1022$ 0 syst ipv4:10.58.7.161:506
40084 voip up up 1029$ 0 syst ipv4:10.58.7.246:506
40078 voip up up 1074$ 0 syst ipv4:10.58.7.192:506
40083 voip up up 1107$ 0 syst ipv4:10.58.7.209:506
40082 voip up up 1007$ 0 syst ipv4:10.58.7.202:506
40088 voip up up 1013$ 0 syst ipv4:10.58.7.191:506
40090 voip up up 1104$ 0 syst ipv4:10.58.7.211:506
40089 voip up up 1080$ 0 syst ipv4:10.58.7.198:506
40091 voip up up 1008$ 0 syst ipv4:10.58.7.210:506
40094 voip up up 1009$ 0 syst ipv4:10.58.7.164:506
40093 voip up up 1070$ 0 syst ipv4:10.58.7.182:506
40097 voip up up 1079$ 0 syst ipv4:10.58.7.169:506
40092 voip up up 1083$ 0 syst ipv4:10.58.7.34:5060
40049 voip up up 1031$ 0 syst ipv4:10.58.7.250:506
40012 voip up up 1073$ 0 syst ipv4:10.58.7.88:5060
40095 voip up up 1033$ 0 syst ipv4:10.58.7.221:506
40098 voip up up 1109$ 0 syst ipv4:10.58.7.201:506
40096 voip up up 1101$ 0 syst ipv4:10.58.7.187:506
40043 voip up up 1035$ 0 syst ipv4:10.58.7.143:506
40002 voip up up 1111$ 0 syst ipv4:10.58.7.170:506
