Support Ip phone 8845 with cucm 10.5.1
I have new 8845 video phone connected to BE6000 ver 10.5.1
have uploaded required firmware.
I can see the file in tftp server , but does not show under firmware tab on CUCM
rebooted the server, Phones gets IP info , TFTP info properly but does not load
any Idea to integrate 8845 to this version?
7 Replies 7
Jaime Valencia
Does it show under device -> phone??? If not
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix_chapter_00.html#CMDP_RF_C8E075E1_00
java
if this helps, please rate
You need to be on CUCM 10.5.2 for compatibility, see 8845 data sheet:
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/datasheet-c78-734730.html
Cisco Unified Communications Manager
  8.5.1 (non-secured mode only)
  8.6.2
  9.1.2
  10.5.2
  11.0 and later
Thanks guys, let me try
Pakirathan,
Let us know if you are good to go by marking this thread as closed.
Because there is a bug
https://tools.cisco.com/bugsearch/bug/CSCuu49879
I was required to perform an upgrade to CallManager release 10.5(2)  (to upgrade to the latest release available, which is 10.5.2.12901-1). On all nodes
after
I have to upload cmterm-devicepack10.5.2.13029-1.cop.sgn.
Then have to reboot pub and IM&prec. Then 8845 and 8865 options became available.
But could not register until  restarted tftp and cucm services on pub one more time
Thanks guys
Exactly, as I pointed out 10.5.2 is the minimum version required on the 10.5 train to support these models.
Thanks, let me try
