Takes 3 calls to connect
Nathan Hardman
Hi Cisco Community,
Its me again
We have a customer who is saying that it is taking 3 times for someone to make a call and the first 3 times the phones keep beeping, similar to engaged tone, straight after dialling number.
Any Idea's
Nathan
This is a CME installation
7 Replies 7
paolo bevilacqua
Suppose that you are asked this same question, without any additonal detail like "who calls who ?" "what type of lines", "when it started happening". And of course, no debugs of any kind.
Would you be able to help ? Or you think in CME there's a command like "fix-one-third-calls-failure" ?
Hi Paolo,
Your sarcasam is not need in my discussions as im looking for some help and guidence to resolve and issue, If only there was a command on the CME.
I understand that i should of provided more information but regarding debugs i don't know what debugs people require.
The phones use ISDN.
It is an issue for all phones
Internal/Inbound no issues what so ever
Outbound this happens all the time i.e every number.
It started happening recently
i have found this error in the logs but could be something seperate.
8132977: Jun  7 2011 14:41:57: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/07/2011 14:41:33.185,cgn:5607,cdn:,frs:0,fid:224675,fcid:12B42AF3904B11E08181F47ED6CE3077,legID:35687,bguid:12B42AF3904B11E08181F47ED6CE3077
8132978: Jun  7 14:41:57.017: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
8132979: Jun  7 14:41:57.017:  Use file-acct reset when the problem is recovered
What you call sarcasm is due to the totally incomplete and unprofessional manner in which have presented the problem in your first post and seems just natural - try reading you post again and honestly answer my question instead of pointing to the way it's written ?
Now regarding your case. Still insufficient information. ISDN PRI/BRI, or what ? Need to see "debug isdn q931" for failed calls. Has anybody touched configuration ? Has a reload been tried?
Hi Paolo,
Its ISDN PRI
I don't believe anybody has touched the config.
No a reload hasn't been tried (Would you advise this first?)
Here is the Debug;
YSP-CCB-CME01#sho log
Syslog logging: enabled (0 messages dropped, 4 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 5825732 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: disabled
    Buffer logging:  level debugging, 7038143 messages logged, xml disabled,
                     filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
    Trap logging: level notifications, 318813 message lines logged
        Logging to 10.17.11.10  (udp port 514,  audit disabled,
              authentication disabled, encryption disabled, link up),
              318813 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
Log Buffer (4096 bytes):
smitBytes 0, ReceivePackets 0, ReceiveBytes 0
8137207: Jun  7 2011 15:34:41: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/07/2011 15:34:34.825,cgn:5619,cdn:,frs:0,fid:225170,fcid:7B1BDDCA905211E0867AF47ED6CE3077,legID:35869,bguid:7B1BDDCA905211E0867AF47ED6CE3077
8137208: Jun  7 15:34:41.345: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
8137209: Jun  7 15:34:41.345:  Use file-acct reset when the problem is recovered
8137210: Jun  7 15:34:53.337: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 01212135619
8137211: Jun  7 15:34:53.337: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x6CEA callID = 0x8670 switch = primary-net5 interface = User
8137212: Jun  7 15:34:53.337: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x6CEA
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9838A
                Exclusive, Channel 10
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0180, '01212135619'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '01495764009'
8137213: Jun  7 15:34:53.481: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xECEA
8137214: Jun  7 15:34:55.681: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0xECE7
8137215: Jun  7 2011 15:34:55: %ISDN-6-CONNECT: Interface Serial0/0/0:7 is now connected to 01291431606 N/A
8137216: Jun  7 15:34:55.681: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x6CE7
8137217: Jun  7 15:34:55.829: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xECEA
        Progress Ind i = 0x8482 - Destination address is non-ISDN
8137218: Jun  7 2011 15:34:57: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 77806791905211E08674F47ED6CE3077, SetupTime 15:34:28.779 GMT Tue Jun 7 2011, PeerAddress 5616, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 15:34:55.689 GMT Tue Jun 7 2011, DisconnectTime 15:34:57.269 GMT Tue Jun 7 2011, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 1078, TransmitBytes 172480, ReceivePackets 0, ReceiveBytes 0
8137219: Jun  7 2011 15:34:57: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/07/2011 15:34:28.773,cgn:5616,cdn:,frs:0,fid:225167,fcid:77806791905211E08674F47ED6CE3077,legID:35866,bguid:77806791905211E08674F47ED6CE3077
8137220: Jun  7 15:34:57.269: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
8137221: Jun  7 15:34:57.269:  Use file-acct reset when the problem is recovered
8137222: Jun  7 2011 15:34:57: %ISDN-6-DISCONNECT: Interface Serial0/0/0:7  disconnected from 01291431606 , call lasted 1 seconds
8137223: Jun  7 15:34:57.285: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x6CE7
        Cause i = 0x8090 - Normal call clearing
8137224: Jun  7 15:34:57.581: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0xECE7
8137225: Jun  7 15:34:57.581: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x6CE7
8137226: Jun  7 2011 15:34:57: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 77806791905211E08674F47ED6CE3077, SetupTime 15:34:33.631 GMT Tue Jun 7 2011, PeerAddress 901291431606, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 15:34:55.681 GMT Tue Jun 7 2011, DisconnectTime 15:34:57.581 GMT Tue Jun 7 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 1081, TransmitBytes 172960, ReceivePackets 1078, ReceiveBytes 181104
8137227: Jun  7 2011 15:34:57: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/07/2011 15:34:33.477,cgn:01212135616,cdn:901291431606,frs:0,fid:225169,fcid:77806791905211E08674F47ED6CE3077,legID:35868,bguid:77806791905211E08674F47ED6CE3077
8137228: Jun  7 15:34:57.581: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
8137229: Jun  7 15:34:57.581:  Use file-acct reset when the problem is recovered
Would you require anything else?
The debug shows the call goes through when sent to ISDN but doesn't show where the failed calls go.
You need to look at debug voip dialpeer to see what DPs are hit when calling. You may find misconfiguration.
A reload is unlikely to fix this particular problem, altough I cannot exclude it.
Hi Paolo,
Ive just spoke to the customer and this isn't happening all the time she says that it pehaps happens once in every 5 calls, does this change anything?
When we just tested this she phoned me 3 times and all 3 connected first attempt. She has assured me that this is not a user error as it happens for all the phones.
Ok I'd try a reload then. Then if you can load 15.0(1)M5, that is very stable.
And check show controller T1 for any error.
