Teleprsence srver 4.1 to 4.3 upgrade
Suchi
I need to upgrade vertual Telepresence server 4.1 to 4.3 , what is the procedure for upgrading?
2 Accepted Solutions
Aseem Anand
Suchi,
You may refer to the link below:
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/ts/install_guide/vTS-upgrade-redeployment-tool.pdf
Aseem
(Please rate if useful)
Jaime Valencia
You do not upgrade to 4.3, you migrate to it. Reviewing the documentation for the product on CCO, should always be your first step. It always contains the install/upgrade guides with all the info.
https://youtu.be/M6Fsq_FICac
java
if this helps, please rate
Aseem Anand
Suchi,
Aseem
Jaime Valencia
java
