02-24-2016 12:29 AM - edited 03-17-2019 05:59 AM
I’m trying Jabber MRA, User can login internally without any issue. I have setup the Expressway C and E. traversal zone is active. And everything look OK as per the guide.
The only thing that I have is my customer did not create the SRV records till now. So I used advanced settings and I put the IP address of my Expressway-E. When I tried to log in I got the following error:
Cannot communicate with the server
Any help
02-24-2016 03:45 AM
I think MRA needs the SRV records, I have tried using the IP or Hostname of the Exp-E box within Jabber and got the same error.
Does it work with the SRV?
02-24-2016 04:51 AM
Thank you for your reply,
I'm trying to use the IP address because the SRV records are not configured. I'm waiting my customer to create the records.
Do I need to create the following SRV records:
h323cs
h323ls
sip
sip
sips
turn
or collab-edge is enough?
02-24-2016 05:37 AM
For the service records.please see here .You can select the service records according to the services that you'll be publishing.Edited my reply as i noted that you already got it going internally.Is it through the IP or the service discovery?
03-23-2016 02:28 AM
What is the status of the zones to the Call Manager from Expressway C?
You can also try collecting Call Manager Service RTMT logs while logging in to Jabber MRA and check if you can see the SIP requests from your Jabber
03-07-2016 01:24 AM
After creating the SRV, I can login but the phone is not registered.
Form the client: Help>> show connection status:
Softphone: Not Connected.
Reason: Connection error. Ensure the server information in the Phone Services tab on the Options window is correct. Contact your system administrator for assistance.
From Inside phone registers.
03-22-2016 08:52 PM
I have the same problem. My MRA works (even with SSO) but Phone Services won't connect. Everything else - voicemail, UDS, etc., is green across the board. Any suggestions?
03-23-2016 06:33 AM
TAC found the following warning in my logs. In response my engineer told me to create a new SIP Trunk Security Profile on the SIP Trunk pointing to Expressway using port 5065 for SIP instead of 5060. After resetting all the Jabber devices (TAB,TCT,CSF,BOT) everything seems to be working as expected!
2016-03-23T00:28:20-04:00 collabedge tvcs: UTCTime="2016-03-23 04:28:20,176" Module="network.sip" Level="INFO": Action="Received" Local-ip="x.x.x.x" Local-port="7001" Src-ip="y.y.y.y" Src-port="25010" Detail="Receive Response Code=405, Method=REGISTER, CSeq=102, To=sip:+15555555555@FQDN.com, Call-ID=5ce0c5ce-61d50003-0000594d-00000721@z.z.z.z, From-Tag=5ce0c5ce61d5000200001b72-00007c5a, To-Tag=848151973, Msg-Hash=13989714286384994303"
2016-03-23T00:28:20-04:00 collabedge tvcs: UTCTime="2016-03-23 04:28:20,176" Module="network.sip" Level="DEBUG": Action="Received" Local-ip="x.x.x.x" Local-port="7001" Src-ip="y.y.y.y" Src-port="25010" Msg-Hash="13989714286384994303"
SIPMSG:
|SIP/2.0 405 Method Not Allowed
Via: SIP/2.0/TLS 10.1.199.15:7001;egress-zone=TraversalZone;branch=z9hG4bK236c9bc40d19f0708991e0b0eab0af05130.7eefa7d35f994f3a27d4260a70f2e44c;proxy-call-id=56cd741a-2fff-4c67-abe9-7e41a4b1c4dd;received=10.1.199.15;rport=7001;ingress-zone=TraversalZone,SIP/2.0/TLS z.z.z.z:53714;branch=z9hG4bK00006505;received=w.w.w.w;rport=23473;ingress-zone=CollaborationEdgeZone
Call-ID: 5ce0c5ce-61d50003-0000594d-00000721@w.w.w.w
CSeq: 102 REGISTER
From: <sip:+15555555555@FQDN.com>;tag=5ce0c5ce61d5000200001b72-00007c5a
To: <sip:+15555555555@FQDN.com>;tag=848151973
Allow: INVITE,OPTIONS,INFO,BYE,CANCEL,ACK,PRACK,UPDATE,REFER,SUBSCRIBE,NOTIFY
Server: Cisco-CUCM10.5
Date: Wed, 23 Mar 2016 04:28:20 GMT
Warning: 399 cucm01 "SIP trunk disallows REGISTER"
Content-Length: 0
09-25-2016 02:27 PM
I had the same problem with windows jabber phones
My MRA worked but Phone Services were not connected.
I had warning message "SIP trunk disallows REGISTER" on Expressway C log
I found mistake, it was sip trunk beetwen CUCM and Expresway C, because it status was Failed. I deleted it and jabber phone services started to work
Cisco MRA doesn't require sip trunk for local phone
03-08-2016 06:23 AM
I’m using single NIC deployment. Is there any special configuration that I should consider?
