08-09-2024 12:17 AM
I want to configure text and the audio alert to the IP phone which are registered on Webex. Also do I need to set up any server/system to have this working.
08-09-2024 02:29 AM
Paging groups are supported natively but do not support text notifications and are capped at 75 recipients. Singlewire Infornacast Fusion is capable of text notifications on IP Phones, larger groups, and more.
08-09-2024 02:58 AM
Is there any configuration which can be done at webex or ip phone end instead for using third party application
08-09-2024 03:38 AM
I just told you what is possible without an add-on. I even looked up and linked the relevant the help article for you.
08-09-2024 06:48 AM
Are the phones registered on Webex Calling? if yes, you can use the following feature:
