Text to Voice for Call Handler Greeting? Unity Connection 10.5
NPT_2
Level 2
Level 2
I know in Unity Connection if you don't record a voice greeting connection will use text to voice to create a generic greeting for the user.
However, what I would like to know is can you take this one step further and setup a call handler for a voicemail tree (I.E. press 1 for Bob, 2 for Larry) that you don't have to record the greeting but type the text for the greeting in and have the Unity Connection system automatically create the greeting using text to voice?
Is this possible?  I know I could use a 3rd party text to speech application to make a recording and then upload it, but it would be much more convenient if I could just type the text directly into the Unity Connection call handler.  What do you think?
Jim
Oh I see, yes, that is not available upto the current release.
However most organizations shun that as soon as possible (machine automated reading / TTS for customers)
6 Replies 6
Jaime Valencia
No, that's not possible, you need to record your greetings directly in CUC, or record and then upload.
java
if this helps, please rate
Hi Jim
Are you trying to achieve Dial by Directory? (e.g "if you want to speak to a person, please spell their first and last name"? kinda thing?
He's asking if you can type somewhere in CUC something like:
Hi, you reached ACME, to reach the roadrunner, press 1, to reach Wile E. Coyote press 2, etc.
And have CUC to translate that to his greeting using some sort of TTS.
java
I already have the dial by name voice recognition setup where you can say a persons name and it works fine.  As Jaime stated I want the opposite.  The capability to type a greeting in Unity Connection and have it converted from text to a speech greeting.
I know Connection has a Text to Speech Engine since it can say people's names when a voicemail box is initially setup and I believe it can also read emails to you over your phone if you have it integrated with exchange (we don't) so I was hoping there was some way to use this engine to create more complex greetings without having to have a real person record the message (which are inconsistent and we don't have a lot of staff that are good at recording these and usually have to record them multiple times before we get them passable.
CUC doesn't have TTS capability to convert customized text to audio greeting. Only 3rd party can do this and yet you neednto upload the file manually
