05-30-2017 07:15 AM - edited 03-17-2019 10:27 AM
I'm getting the following message when I start CUCM:
The system is operating with an insufficient number of licenses. If additional licenses to cover the shortage are not configured in your Cisco Prime License Manager within 59 days, you will no longer be able to provision users and devices.
In the Cisco Prime License Manager, I get the following:
Enhanced Plus (10.x) - Unified CM |
How can I find the device (I'm sure it's a phone) that causing this to happen?
Many thanks!!!
Solved! Go to Solution.
05-31-2017 01:42 PM
Go into system - > licencing - License usage report
On the row with Enhanced Plus it will show "1 User" Click that to find out who is consuming the license. Then click View Details to find which devices are associated to them. Someone has two devices with an owner id mapped to them.
05-30-2017 07:25 AM
See below
https://supportforums.cisco.com/discussion/12470921/license-prime-license-manager
(Rate if it helps)
JB
05-31-2017 12:21 PM
Thank you for your help but unfortunately that doesn't help. I'm still having the issue.
05-31-2017 01:42 PM
06-01-2017 09:51 AM
Thanks justinsanders. That helped!!!
12-03-2019 05:13 AM
12-04-2019 04:25 AM - edited 12-04-2019 04:25 AM
Changing the "Owner" on one phone to either to a different use, or to "Anonymous" if appropriate should fix it. After that change the two phones should each consume one Basic licence, instead of sharing one Enhanced Plus.
You should be able see the change immediately in CUCM by selecting "Update Licence Usage", and in PLM click on "Synchronise Now"
03-02-2025 01:35 PM
En el caso que ya no me permita ni registrar mi eliminar teléfono por falta de licencia, como podría solucionar
03-02-2025 08:35 PM
Why do you post on an older thread? Starting a new thread will ensure that people can reply to your questions.
