third party billing system
Deer all,
what is the best third party billing system give me more than 100 record on web search and integrate with CUCM 7.1\
or if there are tools give me more then 100 record from CDR.
Ibrahim
Best regards
David Hailey
Take a look at Metropolis.
jking2685
There are many call accounting and call logging products listed on the Cisco developer website http://developer.cisco.com/web/partner/search?text=call+logging&technologyIds=&subTechnologyIds=&technologyProductIds=&technologyProductVersionIds=&partnerProductFamilies=&verticalIndustryCategoryId=&availableVerticalIndustryCategories=&_regions=on&_...
Our TIM Plus and TIM Enterprise products have AXL integration so they auto configure the directory based on your UCM configuration.
No cluster licenses and display boards are included free of charge.
Both are Cisco IVT tested so you can be sure that it is compatible, to arrange a free trial go to our Cisco microsite www.tri-line.com/cisco
Directory integration:
TIM Enterprise overview:
JiriPrinc
that is very complex question - the best system can be different for each customer.
You can look here for call accounting systems, but that is not all:
http://developer.cisco.com/web/partner/search?text=call+accounting&technologyIds=&subTechnologyIds=&technologyProductIds=&technologyProductVersionIds=&partnerProductFamilies=&verticalIndustryCategoryId=&availableVerticalIndustryCategories=&_regions=o...
I am available to discuss your needs and show you how you can solve them within our solution (http://www.2ring.com/tas) - I am leading the devolopment team right now, so you have great chance tha I will be able to answer all your questions
Just let me know.
jiri.princ@2ring.com
