01-05-2015 06:21 AM - edited 03-17-2019 01:28 AM
We are having cisco ip phones & third party sip phones in our company. both are registered to same cucm 9.X.
Now when cisco phones calls sip Phones. we are able to see the alerting name on cisco phone.
Say, Cisco Phone "Phone-A" calls Third Party Sip phone "Phone-B". So, on cisco ip Phone display we are able to see "Phone-B".
But same when we try from SIP phones to Cisco phones, we are unable to see the Alert name on the Sip Phone. only the Number we can see on the Sip phone.
Any help will be highly appriciated.
01-05-2015 07:07 AM
Hi Amod.
Did you check on directory number configuration of third party SIP Phone that Alerting name and display internal fields are correctly filled out?
Let me know
Carlo
01-05-2015 07:45 AM
hello Carlo,
Yes, everthing is configured correctly. even i have tried on XLite softphone.. Same problem.
01-05-2015 11:49 AM
Hi Amod.
Can you please specify your CUCM version?
Can you also please upload a screenshot of directory number configuration page?
Many thanks
Carlo
01-05-2015 12:40 PM
CUCM version 9.2
01-05-2015 01:06 PM
Hi.
I think you sent me a screenshot regarding Cisco phone not sip phone .
No matter which kind of sip client you are using CUCM will take care of calling name or number to send to the called party.
Please double check line config of SIP phone
REGARDS
Carlo
01-05-2015 11:50 PM
Hi Carlo,
The above screen shot is of Sip phone Line configuraton only.
Its a thrid party sip phone (Deskphone) not the third party sip softphone.
For testing porpose i used Xlite, but the same issue i am facing with Xlite also.
AMOD
01-06-2015 01:51 PM
Hi Amod.
I'm terribly sorry cause I got what you are asking only now :(
This behaviour depends on client capability.
CUCM always send RPID ( remote-party ID) to the third party SIP client/phone on ring.
If the client is capable to update the calling number into what it receives as RPID, than you'll be able to see calling name.
I've read some release notes of XLITE and other SIP Desk phone and it seems to be not mentioned.
Sorry again
Carlo
