Showing results forĀ
Search instead forĀ
Did you mean:Ā
Time Difference In Between Call Manager & IP Phone
jahanzaib amin
We remove the NTP server from the Call Manager 6.5 and configure manual  TIME setup on the CUCM but the IP Phone showing 7 minutes difference.
We reset and restart the Phones not no effect. What other thing we can do to accomplish this issue.
7 Replies 7
Aman Soi
Hi Amin,
Can u share the output of command utils ntp status from CLI?
Secondly, how did u remove ntp from CUCM?
regds,
aman
I remove the NTP Server IP Address information from the OS Administration NTP configuration.
Output for the Command
admin:utils ntp status
ntpd (pid 32278) is running...
     remote           refid     st t when poll reach   delay   offset jitter
*127.127.1.0     127.127.1.0     10 l   54   64 377   0.000   0.000   0.015
172.16.1.51     0.0.0.0         16 u   - 1024   0   0.000   0.000 4000.00
synchronised to local net at stratum 11
   time correct to within 11 ms
   polling server every 64 s
Current time in UTC is : Mon Nov 4 07:23:48 UTC 2013 Current time in Mideast/Riyadh89 is : Mon Nov 4 10:30:52 zzz 2013
Hi amin,
Did u ever restart Pub after removing NTPs?
regds,
aman
We did not restart .
Hi Amin,
I was just goig through troubleshooting DOC .the problem which u are facing is may be because of BIOS which has wrong time and phones are picking that time after NTP has been removed.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080b2cd0e.shtml
Can u cross-check BIOS settings during maintenance hours ?
regds,
aman
We did'nt cross check at the time we remove.
So we need to restart the Publisher so the Local Time setting will be update on the Server BIOS?
Hi Amin,
this is what I am suspecting.
If it is not that critical, wait and let others revert.
regds,
aman
