12-11-2024 11:01 PM
Re: CUCM 12.5
Looking to use TOD to control call routing based on schedules and calling source (external vs internal). Is this possible and if so, is TOD the best way to accomplish? I have configured time of day routing using cisco doc below, however, seems that I am missing more. Currently all phones use one css and partition. Below is what I am looking to accomplish.
1. For a subset of internal classroom phones, route inbound (external) calls directly to the phone's voicemail during teaching hours and directly to the phone during non-teaching hours.
2. For the same subset of internal phones, allow routing of all internal calls directly to the phone, all day.
12-12-2024 02:01 AM
The best way is to create three similar Directory Numbers and assign one to the On_Shift_Partition, another to the Off_Shift_Partition, and the third to the Partition_Internal_Special.
Keep the actual subnet of numbers in a different partition (let's assume Partition_Internal_Special) that can be accessed from the internal extensions. During the on-shift period, when the call needs to ring on the phone for external calls, enable call forwarding to the DN in the internal partition.
During the off-shift period, set the call forwarding to voicemail.
For example, if you have extension 30001 that must be routed to voicemail during class hours and should ring on the phone during the rest of the time for calls from outside, and the same number should ring when someone calls from inside:
I assume the following should work, although I haven't tested this in my lab. Please try it and let me know if you face any challenges.
12-12-2024 09:02 AM
Thank you. I will setup and test following your example.
