Time on phones still showing UTC - CUCM
davetechfreak
Hi Everyone,
Hope this is not a silly question.
The time on our phones does not seem to have moved forward to summertime. My NTP on CUCM is showing the correct UTC and timezone, but it does not seem to have taken effect on the phones.
Have I missed something?
This is my NTP output on CUCM:
utils ntp status
no parameters are required
admin:utils ntp status
ntpd (pid 22843) is running...
     remote           refid      st t when poll reach   delay   offset  jitter
78.46.108.116   .RATE.          16 u  908 1024   40   52.185  248.075   0.001
172.16.111.81   .INIT.          16 u    - 1024    0    0.000    0.000   0.000
synchronised to unspecified at stratum 3
accuracy unreadable
   polling server every 1024 s
Current time in UTC is : Mon Apr  1 08:49:07 UTC 2013
Current time in Europe/London is : Mon Apr  1 09:49:07 BST 2013
admin:
6 Replies 6
ronpatel
Level 8
Level 8
HI
what is the version of the CUCM. Also Is it happneing to all the phones or only with perticular model of the phone.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Aman Soi
Hi David,
Did u make any changes in call manager related to NTP ?
If u add, delete or modify NTP server, u must restart the other nodes in cluster.
regds,
aman
Anas Abueideh
Level 9
Level 9
Hi David,
make sure you assign the correct time zone under the device pool. kindly find the below link https://supportforums.cisco.com/message/3891831#3891831
Anas
please rate if it is helpful
Hi Anas,
I think by mistake u have shared the different Bug ID.
CSCth87452 - DB service is down, after changing the security password.
Please share the correct one.
regds,
aman
Hi aman,
you are right. it is a mistake
regards
Anas
davetechfreak
I have got a CUCM 8.6. NTP has been initially configured when the server was installed (a month ago). Yes, all phones are affected. Under Device Pool I have "CMLocal" which is ETC/GMT.
Should this be "Europe/London"? Quite confusing...
David
