Time Schedule: don't let me change order of Time Period
I'm tryng to setup a Time Scheduling condition for incoming calls but at the process to select the different Time Period on the Time Schedule option I'm not able to reorder the time period as I want. At the top (first option) it always remain the "Inservice" time period so calls are never block because the "Outservice" time period are second and third option and it have to be backward.
I have created 2 Time Period:
Office_Working: 8AM-17PM
Christmas: NO OFFICE HOURS,DIC25-DIC31
Time Schedule:
Christmas: DIC25-DIC31
Time Schedule no matter what I do it does't let me to change the order for the Christmas Time Period be the first option not the second.
Sorry for my poor english
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
5 Replies 5
Chris Deren
Is 8-17 period supposed to behave the same way as when there is Christmas? I.e. are these closed hours?
The order in schedule is irrelevant, if one period needs to allow routing and other does not then you need to assign them to different time schedules and use different partitions.
HTH,
Chris
8-17 period should be a opened hours and Christmas should be a closed hours, that's why Christmas should be the firt option to block call for day DIC25-DIC31 otherwise calls will be always route using the Office_Working Time Period.
What about between 17-7? I take it, it should be closed too, right?
If so do this:
build the following time periods
holiday
weekend (assuming 8-17 was only Mon-Friday)
17-24
00-08
build new time schedule "Closed" using the above periods
Assign this schedule to Partition_Closed
Ensure this PT is listed above other partitions in appropriate CSS (i.e. GW CSS)
This way when call arrives afterhours, during weekend and holiday it will match the closed partition and route to whatever DN is assigned to this PT, i.e. routing to voicemail, etc.
HTH,
Chris
Ok, logically you setup will work but still I have the doubt about Jeremy Ciora said about assigning the time period.
He said that Time Scheduling works like a Access List because match the time period from the first Time Period to the last one selected so it match depending the order but I don't know why it doesn't let me to reorder the Time Period.
I am sorry, who is Jeremy Ciora?
You would never want to assign contradicting periods in the same schedule as it would always follow the route, remember it is still driven my partition.
Have you read this:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_2/ccmsys/a03tod.html
another good one:
https://supportforums.cisco.com/docs/DOC-14249
HTH, please rate all useful posts!
Chris
