timeout upgrading ip phones firmware because slow links
andres.pasten
We are working on an upgrade from cucm v8.6 to v10.5, and previously we´re on the ip phones upgrade of his firmware.
But customer has some remote locations with slow links, and upgrade is not possible to complete, and then ip phones stay on a loop tryng to upgrade. So in that cases we leave those phones with phone load name on his current firmware, to prevent they try to upgrade.
We tried with a local tftp server on a computer, loading it with the files to upgrade an cfg files from cucm, but it didnt work.
There is a solution for this situation, I dont want issues on that phones because they cant install also the spanish locale files.
TIA
Andres Pasten Calzada.
Manish Gogna
Hi Andres,
You can check the peer firmware sharing feature
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phones-9900-series/white_paper_c11-583891.html
Manish
Hi Manish,
Thanks for your sooner answer.
There is a procedure to improve a load server? The url speaks as it is correctly configured, but it doesnt says the requirements for that.
On the disvantages it says:
• IP must be set on each phone
     Does it means that I cant use a dhcp server to inform the load server as tftp server?
• Administrator must manually file copy to load server
     There is a list for all the required files?
We cant use peer firmware sharing because we have all the phones with the old firmware. And because of the slow link no phone become upgraded.
TIA
Hi Andres,
Check this
https://supportforums.cisco.com/document/96856/upgrade-firmware-3rd-party-tftp-server-tfpd32
Manish
