11-25-2010 12:53 AM - edited 03-16-2019 02:06 AM
what is the MAIN difference between the two? Upon testing both commands on the CLI and on the CUCM, only the "timeouts wait-release or T305 timer" sets that FXO port to release the call.
In what scenario will "timeouts call-disconnect" can be test or applicable?
Also I can test that the default of "timeout wait-release" is 30 seconds while "timeouts disconnect" is 60 seconds! Is it really 60 seconds? I happend to test some calls and can't find a test scenario where the call will be disconnected on the fxo port by 60 seconds when calling outbound and calling inbound.
Thanks for the inputs
11-25-2010 10:17 PM
anyone
12-11-2010 12:01 PM
anyone?
12-11-2010 09:11 PM
Basically, timeouts call-disconnect is the amount of time that the FXO port waits before a call is being disconnected after the calll has ended and the disconnect tone is detected. Timeouts wait-release is the amount of time that the FXO takes before the system starts the process for releasing voice ports after a failed call.
Hope this helps.
Farbod
12-16-2010 06:16 AM
somehow it is still not clear to me , can you or anyone give me a scenario on where can I test "call-disconnect"? because almost all my test scenario points to "timeouts wait-release"
thanks
