***Toll-Free not working***
Hi Everyone,
I'm facing an issue when I try to call a toll-free number like (800-700-8000) but when I try to call 907 it works.
Both the Toll-free and Service numbers use the same dial-peer
I received the below message from the interface connected to SIP Provider
SIP/2.0 480 Temporarily Unavailable
Edge Interface to Sip-Provider = 172.29.26.238
Y.Y.Y.Y = CUCM
Z.Z.Z.Z = CALLING NUMBER
P.P.P.P = IP ADDRESS FOR SIP PROVIDER
8007008000 = Called Number
dial-peer voice 9 voip
translation-profile outgoing OUTCALLS
destination-pattern 9.T
session protocol sipv2
session target ipv4:P.P.P.P
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
IP Phone---->Cucm--->SIPGW--->SIP-Provider
Debug ccsip messages
*Jun 29 12:58:50.361: //889749/7F5F12000000/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.29.26.238:5060;branch=z9hG4bK633513BE
Record-Route: <sip:P.P.P.P:5060;transport=udp;lr>
Call-ID: 70EA31D3-DFF211E2-9B96EA94-227BC254@172.29.26.238
From: <sip:Z.Z.Z.Z@172.29.26.238>;tag=F112E48A-24F3
To: <sip:8007008000@P.P.P.P>;tag=sbc0802ehaf44s7
CSeq: 101 INVITE
Reason: Q.850;cause=16;text="normal call clearing"
Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR"
Content-Length: 0
*Jun 29 12:58:50.361: //889748/7F5F12000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 480 Temporarily Not Available
Via: SIP/2.0/TCP Y.Y.Y.Y:5060;branch=z9hG4bK235dca317f4ad4
From: <sip:Z.Z.Z.Z@Y.Y.Y.Y>;tag=407082033~005a301a-e8f3-4413-8977-6b1590c9f95b-76744502
To: <sip:98007008000@10.176.1.3>;tag=F11322E2-25D8
Date: Sat, 29 Jun 2013 12:58:34 GMT
Call-ID: 7f5f1200-1ce1ef9d-1a92f1-c01a30a@Y.Y.Y.Y
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Reason: Q.850;cause=18
Content-Length:
It's from ITSP, see "Received'.
6 Replies 6
paolo bevilacqua
Llikely you need to call 1800xxxxxxx. Or ask ITSP.
Hi Paolo,
This setup is located in Saudi Arabia
so the toll number here is
  • 800 XXX XXXX - Toll free
The issue is that I dont know if the problem is from the gateway or the provider since the "SIP/2.0 480 Temporarily Unavailable" was generated from the local gateways interface connecting to the ITPS.
If you look at the message :
the following ip address is from the local gateway itself (172.29.26.238), so how can I send myself the message unless the issue originate from the local gateway.
Which is confusing, if it is from the ITSP shouldn't it look like this?
Thanks Paolo It as you said
I had to check the (Call-ID)
Received:
Call-ID: 70EA31D3-DFF211E2-9B96EA94-227BC254@172.29.26.238 (Unique to ITSP)
Orginated from the ITSP
Thank you for the nice rating and good luck!
