Trace collection question
Brad Martin
Level 3
Level 3
We are running callmanager v10.5.2 that has a sip trunk to VPI recording system. Does anyone know which trace to find the following information? This is from an email sent via RTMT. I'm looking for the successful sessions.
RecordedDeviceName : SEP203A07FC4EC9
RecordedDeviceDN : 6057212207
RecordedDeviceCallID : 130961476
GatewayGuid : RecordingMediaPreference : 2
RecordingMediaSource : 1
RecordingDestinationAddress : 6050006500
RecordingClusterID : BHCCCM6Cluster
CauseValue : 16 Reason : 1
AppID : Cisco CallManager ClusterID : BHCCCM6Cluster
NodeID : bhdccucmp02 TimeStamp : Wed Mar 25 10:39:02 MDT 2015.
The alarm is generated on Wed Mar 25 10:39:02 MDT 2015.
Hi Brad
If you're trying to verify that you are sending it in the SIP sig, then the best way in my opinion is to do a packet capture on the CUCM server. That way you see what is actually sent on the line, rather than what CUCM says it's sending in the logs. No room for argument there.
I'm assuming there that you are not encrypting the SIP sig.
On your CUCM servers, run:
utils network capture port 5060 size all count 100000 file sipcap1
Then retrieve the files with RTMT or
file get activelog platform/cli
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
6 Replies 6
Aaron Harrison
I'm not clear what you want.
If the session is succesful, you'll have a recording on your VPI system?
What other information would you want to see? SIP signalling traces? RTP traces? Internal CUCM logic?
Aaron
I'm trying to prove that I'm sending calling number caller-id to our applications group. It isn't displaying in the application. I'll try packet captures.
Hi Brad
Aaron
Dennis Mink
If you collect the call manager tracefiles (detailed) and pull it for the exact timeframe as indicate in your post above, it will contain SIP signalling, you will need to filter based on MAC, so use notepad++ to open the log file(s).  also check to which server the phone is registered as this will prevent you from having to plough through all log files.
Please remember to rate useful posts, by clicking on the stars below.
DJ
CCM Traces would be sufficient enough..
use windows grep and search for called number..
INVITE message will contain the calling number and called number...
Brad Martin
Level 3
Level 3
Thank you all for your input. All very helpful. I was able to get exactly the information I need.
