Transfer Calls
Faisal.Saoud
Level 3
Level 3
I have CME , some sccp phone ,and one sip phone 7821.
I can call from SIP to SCCP and vice versa as well. but the issue is if someone called in and SCCP answer the call, it then cannot transfer to SIP user.
regards
2 Accepted Solutions
Why is debug not working? It should work..Please review the configuration I sent..
Can you also remove this command (supplementary-service media-renegotiate) and try again..
voice serv voip
no supplementary-service media-renegotiate
Please rate all useful posts
It seems your dtmf isn't working..try this..
voice register pool  1
dtmf-r rtp-nte sip-kpml
voice regiater glo
cr pr
apply
Then test again
12 Replies 12
Ayodeji Okanlawon
Try the ff:
voice service voip
no supp sip refer
no sup sip moved
also ensure that you configure transfer-pattern in telephony-service
I configured your comments and no change , still transfer call from sccp to sip fails
can you attach your sh run here..
can you also do the ff:
service sequence-numbers
service timestamps debug datetime localtime msec
logging buffered 10000000 debug
no logging console
no logging monitor
default logging rate-limit
default logging queue-limit
Then..
<Enable debugs, then test again.>
debug ccsip messages
<Enable session capture to txt file in terminal program.> (such as Putty)
then do the ff:
terminal length 0
show logging
Attach the logs and sh run here
Connex#
Connex#sh run
Building configuration...
Current configuration : 18711 bytes
! Last configuration change at 13:25:31 UTC Mon Sep 28 2015
version 15.4
hostname Connex
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.154-1.T.bin
boot-end-marker
aqm-register-fnf
logging buffered 51200 warnings
no logging console
enable password cisco
no aaa new-model
ip dhcp pool PCs
 network 10.0.0.0 255.255.255.0
 default-router 10.0.0.138
 dns-server 8.8.8.8 4.2.2.2
 option 150 ip 10.0.0.233
ip domain name yourdomain.com
ip cef
no ipv6 cef
crypto pki trustpoint TP-self-signed-59469111
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-59469111
 revocation-check none
 rsakeypair TP-self-signed-59469111
crypto pki certificate chain TP-self-signed-59469111
 certificate self-signed 01
  30820227 30820190 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  2F312D30 2B060355 04031324 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 35393436 39313131 301E170D 31323036 32383038 33363337
  5A170D32 30303130 31303030 3030305A 302F312D 302B0603 55040313 24494F53
  2D53656C 662D5369 676E6564 2D436572 74696669 63617465 2D353934 36393131
  3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281 81009BF1
  7655998F EA1664DC D0C1791B 10A1E5AD 44790A0A B607E5EA 3331EA2A 10D2A9F7
  B2BE1C9B F41A2960 2905C18A 47D272B5 A43507DC 28CFAD20 71A80FF0 8249A38D
  D7CCF45A 5061A220 70453AC5 DF6722CE 8EA9E720 2CF3F1F5 AB03CA3F B70E8385
  5FA3FC50 99BCB6A4 EAD15A23 B30370CF 10C42F87 4ABFBD84 476CB271 6A0D0203
  010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603 551D2304
  18301680 148D0E31 7FCA9C10 2D060D74 804B6C39 2DE62F8E D0301D06 03551D0E
  04160414 8D0E317F CA9C102D 060D7480 4B6C392D E62F8ED0 300D0609 2A864886
  F70D0101 05050003 81810094 95BEDC4F B1CE2BF2 B1DFA274 84A508DE 2CA7F1BC
  E80FF14D 93694727 48D26486 5D819AA1 C6B1E32B AA763E62 B6C4A35B 264BA041
  71B24AD8 A648FA34 15D059C6 184F3CD1 876E0005 6964E622 EAA8AAE2 ABE32796
  79CE1038 FA665E32 8E251901 7F8210A3 9C5D7EF4 84D3D7E0 DFDD57EF A24C90AB
  9A6F00FA 03169027 5414E6
        quit
voice-card 0
voice call carrier capacity active
voice service voip
 no ip address trusted authenticate
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  registrar server
voice register pool-type  7821
 phoneload-support
 description Cisco IP Phone 7821
 reference-pooltype 6921
voice register global
 mode  cme
 source-address 10.0.0.233 port 5060
 max-dn 100
 max-pool 40
 load 7821 sip78xx.10-1-1SR1-4.loads
 authenticate register
 authenticate realm all
 timezone 25
 date-format D/M/Y
 call-forward system redirecting-expanded
 tftp-path flash:
 create profile sync 0005632651406871
 ntp-server 10.0.0.138 mode directedbroadcast
voice register dn  1
 number 123
 name Eriny
 label Eriny
 busy-trigger-per-button 1
 id mac 204C.9EB2.BB76
 type 7821
 number 1 dn 1
 dtmf-relay sip-notify
 username 123 password 123
 codec g711ulaw
 no vad
voice hunt-group 1 parallel
 final 178
 list 101,106,107,108,109,110,111,112,117,118,119
 pilot 178
voice translation-rule 1
 rule 1 /^9/ //
voice translation-profile PSTN
 translate called 1
application
 package english
  param max-tim-vm-retry 1
  param index 1
  param redirect-number 100
  param queue-len 10
  param second-greeting-time 15
  param language en
  param queue-manager-debugs 1
  param max-time-vm-retry 1
  param uid-len 4
  param voice-mail 600
  param max-time-call-retry 30
  param aa-pilot 177
  param aa-hunt1 197
  param max-extension-length 3
  param aa-hunt2 196
  param number-of-hunt-grps 5
  param aa-hunt3 198
  param location flash:
  param dial-by-extension-option 3
  param handoff-string aa
  param welcome-prompt welcome.au
  param operator 178
  param call-retry-timer 10
  param prefix en
  param service-name queue
 service aa flash:app-b-acd-aa-2.1.2.2.tcl
  paramspace english index 1
  param operator 178
  paramspace english language en
  param aa-pilot 199
  paramspace english location flash:
  param welcome-prompt _bacd_welcome.au
  paramspace english prefix en
 service aa2 flash:its-CISCO.2.0.2.0.tcl
  param uid-len 4
  param aa-pilot 177
  param operator 178
 service queue flash:app-b-acd-2.1.2.2.tcl
  param queue-len 10
  param aa-hunt3 198
  param aa-hunt1 197
  param aa-hunt2 196
license udi pid CISCO2911/K9 sn FCZ162670R9
hw-module pvdm 0/0
username cisco privilege 15 password 0 cisco
username <myuser> privilege 15 secret 5 $1$5.4O$9jcu6nEpULFfu/B1M6Mk9/
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
 ip address 10.0.0.233 255.0.0.0
 duplex auto
 speed auto
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.0.0.233
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.0.0.138
logging server-arp
tftp-server flash:ipc-sccp.jar
tftp-server flash:CME-locale-en_US-English-7.0.1.1.tar.cfg
tftp-server flash:be-sccp.jar
tftp-server flash:g3-tones.xml
tftp-server flashgp-sccp.jar
tftp-server flash:mk-sccp.jar
tftp-server flash:tc-sccp.jar
tftp-server flash:td-sccp.jar
tftp-server flash:/phone/7940-7960/P00308000500.bin alias P00308000500.bin
tftp-server flash:SCCP11.7-2-1-0S.loads
tftp-server flash:cnu11.3-0-0-81.sbn
tftp-server flash:/phone/7940/P00308010200.loads alias P00308010200.loads
tftp-server flash0:kern78xx.10-1-1SR1-4.sbn
tftp-server flash0:rootfs78xx.10-1-1SR1-4.sbn
tftp-server flash0:sboot78xx.10-1-1SR1-4.sbn
tftp-server flash0:sip78xx.10-1-1SR1-4.loads
tftp-server flash0:APP6901SCCP.9-2-1-a.zz.sgn
tftp-server flash0:APP6911SCCP.9-2-1-a.zz.sgn
tftp-server flash0:BFS6911SCCP.9-2-1-a.zz.sgn
tftp-server flash0:KNL6901SCCP.9-2-1-a.zz.sgn
tftp-server flash0:KNL6911SCCP.9-2-1-a.zz.sgn
tftp-server flash0:SCCP6901.9-2-1-a.loads
tftp-server flash0:SCCP6911.9-2-1-a.loads
tftp-server flash0:apps11.9-2-1ES4.sbn
tftp-server flash0:cnu11.9-2-1ES4.sbn
tftp-server flash0:cvm11sccp.9-2-1ES4.sbn
tftp-server flash0:dsp11.9-2-1ES4.sbn
tftp-server flash0:jar11sccp.9-2-1ES4.sbn
tftp-server flash0:SCCP11.9-2-1SR2S.loads
tftp-server flash0:term06.default.loads
tftp-server flash0:term11.default.loads
tftp-server flash0:P00308010200.bin
tftp-server flash0:P00308010200.loads
tftp-server flash0:P00308010200.sb2
tftp-server flash0:P00308010200.sbn
tftp-server flash0:apps45.9-2-1ES4.sbn
tftp-server flash0:cnu45.9-2-1ES4.sbn
tftp-server flash0:cvm45sccp.9-2-1ES4.sbn
tftp-server flash0:dsp45.9-2-1ES4.sbn
tftp-server flash0:jar45sccp.9-2-1ES4.sbn
tftp-server flash0:SCCP45.9-2-1SR2S.loads
tftp-server flash0:term45.default.loads
tftp-server flash0:term65.default.loads
control-plane
voice-port 0/0/0
 translation-profile outgoing PSTN
 connection plar 90074959871775
 caller-id enable
voice-port 0/0/1
 caller-id enable
voice-port 0/0/2
 connection plar 177
 caller-id enable
voice-port 0/0/3
 connection plar 177
 caller-id enable
voice-port 0/1/0
 connection plar 177
 caller-id enable
voice-port 0/1/1
 connection plar 177
 caller-id enable
voice-port 0/1/2
 connection plar 177
 caller-id enable
voice-port 0/1/3
 connection plar 177
 caller-id enable
voice-port 0/2/0
 connection plar 177
 caller-id enable
voice-port 0/2/1
 connection plar 177
 caller-id enable
voice-port 0/2/2
 connection plar 177
 caller-id enable
voice-port 0/2/3
 connection plar 177
 caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 10 pots
 preference 3
 destination-pattern 90[2-9]T
 port 0/0/0
 forward-digits all
dial-peer voice 11 pots
 port 0/0/1
 forward-digits all
dial-peer voice 12 pots
 port 0/0/2
 forward-digits all
dial-peer voice 13 pots
 port 0/0/3
 forward-digits all
dial-peer voice 16 pots
 preference 4
 port 0/1/0
 forward-digits all
dial-peer voice 17 pots
 port 0/1/3
 forward-digits all
dial-peer voice 29 pots
 destination-pattern 901[01246789]........
 port 0/1/3
 forward-digits all
dial-peer voice 35 pots
 destination-pattern 9[2-9]T
 port 0/0/1
 forward-digits all
dial-peer voice 36 pots
 port 0/0/2
 forward-digits all
dial-peer voice 37 pots
 port 0/0/3
 forward-digits all
dial-peer voice 40 pots
 preference 4
 port 0/1/0
 forward-digits all
dial-peer voice 57 pots
 destination-pattern 91....
 port 0/0/2
 forward-digits all
dial-peer voice 58 pots
 port 0/0/3
 forward-digits all
dial-peer voice 59 pots
 preference 3
 port 0/0/0
 forward-digits all
dial-peer voice 60 pots
 port 0/0/1
 forward-digits all
dial-peer voice 7777 voip
 description AUTO-ATTANDENT-PILOT-NUMBER
 service aa2
 destination-pattern 177
 session target ipv4:10.0.0.233
 incoming called-number 177
 dtmf-relay h245-alphanumeric
 codec g711ulaw
 no vad
dial-peer voice 63 pots
 destination-pattern 914.
 port 0/0/1
 forward-digits all
dial-peer voice 64 pots
 port 0/0/2
 forward-digits all
dial-peer voice 65 pots
 port 0/0/3
 forward-digits all
dial-peer voice 68 pots
 preference 4
 port 0/1/0
 forward-digits all
dial-peer voice 101 pots
 destination-pattern 912.
 port 0/1/1
 forward-digits all
dial-peer voice 75 pots
 destination-pattern 918.
 port 0/0/1
 forward-digits all
dial-peer voice 76 pots
 port 0/0/2
 forward-digits all
dial-peer voice 77 pots
 port 0/0/3
 forward-digits all
dial-peer voice 111 pots
 incoming called-number .T
 direct-inward-dial
dial-peer voice 116 pots
 port 0/1/1
 forward-digits all
dial-peer voice 140 pots
 port 0/1/1
 forward-digits all
dial-peer voice 168 pots
 port 0/1/1
 forward-digits all
dial-peer voice 51 pots
 preference 4
 destination-pattern 900T
 port 0/1/0
 forward-digits all
dial-peer voice 34 pots
 preference 3
 port 0/0/0
 forward-digits all
dial-peer voice 780 pots
 destination-pattern 9007495987177.
 port 0/2/1
gatekeeper
 shutdown
telephony-service
 no auto-reg-ephone
 max-ephones 58
 max-dn 300
 ip source-address 10.0.0.233 port 2000
 system message CONNEX Assistance
 load 7911 term31.default.loads
 load 7960-7940 P00308000500
 time-zone 22
 max-conferences 8 gain -6
 moh enable-g711 "en_bacd_music_on_hold.au"
 multicast moh 239.16.10.4 port 2123
 transfer-system full-consult
 transfer-pattern .T
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  1
 softkeys hold  Join Newcall Resume Select
 softkeys idle  Redial Newcall Pickup Cfwdall Dnd HLog Gpickup Join Login
 softkeys seized  Endcall Redial Pickup Cfwdall HLog
 softkeys alerting  Callback Endcall
 softkeys connected  Endcall Hold Park Trnsfer HLog Flash Join
 softkeys ringing  Answer Dnd HLog
ephone-dn  1  dual-line
 number 101
 label 101
 description Aballah
 name abdallah
ephone-dn  3  dual-line
 number 103
 label 103
 description Dr. Helmy
 name Dr. Helmy
ephone-dn  4  dual-line
 number 104
 label 104
 description Lara
 name Lara
ephone-dn  5  dual-line
 number 105
 label 105
 description Samia
 name Samia
ephone-dn  6  dual-line
 number 109
 label 109
 description Eman
 name Eman
ephone-dn  7  dual-line
 number 107
 label 107
 description Rehab
 name Rehab
ephone-dn  8  dual-line
 number 108
 label 108
 description Shaimaa
 name Shaimaa
 call-forward all 40172458*07867053580012
ephone-dn  9  dual-line
 number 106
 label 106
 description Chadi
 name Chadi
ephone-dn  10  dual-line
 number 110
 label 110
 description Rana
 name Rana
ephone-dn  11  dual-line
 number 111
 label 111
 description Mansour
 name Mansour
ephone-dn  12  dual-line
 number 112
 label 112
 description Christen
 name Christen
ephone-dn  14  dual-line
 number 114
 label 114
 description Sally
 name Sally
ephone-dn  15  dual-line
 number 115
 label 115
 description Hossam
 name Hossam
ephone-dn  16  dual-line
 number 116
 label 116
 description Islam
 name Islam
ephone-dn  17  dual-line
 number 117
 label 117
 description Nirmeen
 name Nirmeen
ephone-dn  18  dual-line
 number 118
 label 118
 description Ahmed
 name Ahmed
ephone-dn  19  dual-line
 number 119
 label 119
 description Raham
 name Raham
ephone-dn  20  dual-line
 number 120
ephone-dn  21  dual-line
 number 121
ephone-dn  22  dual-line
 number 122
ephone-dn  23  dual-line
 number 101
 label 101
 description Abdallah
 name Abdallah
ephone-dn  33  dual-line
 number 133
ephone-dn  36  dual-line
 number 108
ephone-dn  37  dual-line
 number 123
 label 123
 description Eriny
 name Eriny
ephone  1
 mac-address 50E5.4985.74E5
 type 7911
 button  1:1
ephone  3
 mac-address 04C5.A44C.98F7
 type 7975
 button  1:3
ephone  4
 mac-address 04C5.A44C.9B5C
 button  1:4
ephone  5
 mac-address F47F.353C.CAFA
 button  1:5
ephone  6
 mac-address 000D.BC5C.296E
 type 7940
 button  1:6
ephone  7
 mac-address 000B.46BD.EB90
 type 7940
 button  1:7
ephone  9
 mac-address 0014.1C0F.0886
 type 7940
 button  1:9
ephone  10
 mac-address 000B.5F05.24A9
 type 7940
 button  1:10
ephone  11
 mac-address 000B.5F92.6010
 type 7940
 button  1:11
ephone  12
 mac-address 50E5.4985.717B
 button  1:12
ephone  14
 mac-address F0F7.55BC.2A26
 button  1:14
ephone  15
 mac-address 10BD.18DC.6676
 button  1:15
ephone  16
 mac-address 10BD.18DC.660F
 button  1:16
ephone  17
 mac-address 0023.339D.04CA
 button  1:17
ephone  18
 mac-address 000B.46D9.CD7F
 type 7940
 button  1:18
ephone  20
 mac-address ECC8.82B0.E89A
 button  1:18
ephone  21
 mac-address 6C50.4D56.B794
 type 7940
ephone  23
 mac-address 0014.6AD6.A6D7
 type 7940
 button  1:23
ephone  25
 mac-address A456.30BA.D94E
 type 7911
 button  1:22
ephone  33
 mac-address 3859.F976.03A5
 button  1:33
ephone  34
 mac-address A456.30BA.D75D
 ephone-template 1
 button  1:12
ephone  35
 mac-address B4A4.E329.B482
 ephone-template 1
 button  1:8
ephone  36
 mac-address 0023.CDF8.2F5A
 type CIPC
 button  1:36
ephone  37
 mac-address B4A4.E3D7.E8C5
 button  1:37
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 access-class 23 in
 privilege level 15
 password cisco
 login
 transport input telnet ssh
line vty 5 15
 access-class 23 in
 privilege level 15
 password cisco
 login
line vty 16 1114
 password cisco
 login
 transport input all
scheduler allocate 20000 1000
end
Connex#
Please attach the debug ccsip message for a failed transfer as requested
Connex#show logging
Syslog logging: enabled (0 messages dropped, 9 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: disabled
    Buffer logging:  level debugging, 1 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 456 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (10000000 bytes):
000500: *Sep 28 13:51:59.391: %SYS-5-CONFIG_I: Configured from console by vty0 (10.0.0.171)
Connex#
debug not working on the router
voice serv voip
but I have 2 problem:-
1- listen the sound is low.
2- when i call number then press 1 , pressing fail
voice regiater glo
cr pr
apply
Then test again
when someone called in and SCCP answer the call, it then can transfer to SIP user but the sound is very low , what is the reason
thanks
I don't know, sorry. You can try and adjust the volume on the phone
