11-13-2013 06:29 AM - edited 03-16-2019 08:22 PM
This is such a basic question, I'm almost embarrassed to ask after 10 years of looking after call manager, but I've had a query from a user and it sounds as though it should be possible but I can't seem to see how to do it.
When transferring a call, is it not possible to use one of your speed or abbreviated dials to send the call to? I've tried on both a 6941 and 7940 handset and you hit the xfer key, get a dialtone, but then don't appear to be able to use an abbr dial.
Solved! Go to Solution.
11-13-2013 06:42 AM
Hi there,
This functionality is possible, but is based on the IP phone
model and firmware. You would need the Offhook with Feature softkey
for this to work
Off-Hook Abbreviated Dialing
Cisco Unified Communications Manager release 7.1(2) (firmware 8.5(2)) introduces Off-Hook Abbreviated Dialing. The user can initiate Off-Hook Abbreviated Dialing while conferencing a call, while transferring a call, or while placing a new call after putting a call on hold.
Note The phone must be assigned a softkey set that includes the AbbrDial softkey before it can be used. The softkey can be assigned by using the Softkey Template Configuration for the following states-Offhook, Offhook with Feature, and Digits After First.
The following Cisco Unified IP Phones (SCCP and SIP) support Off-Hook Abbreviated Dialing:
Cisco Unified IP Phone 7975G
Cisco Unified IP Phone 7971G-GE
Cisco Unified IP Phone 7970G
Cisco Unified IP Phone 7965G
Cisco Unified IP Phone 7962G
Cisco Unified IP Phone 7961G
Cisco Unified IP Phone 7961G-GE
Cisco Unified IP Phone 7945G
Cisco Unified IP Phone 7942G
Cisco Unified IP Phone 7941G
Cisco Unified IP Phone 7941G-GE
Cisco Unified IP Phone 7931G
Cisco Unified IP Phone 7911G
Cisco Unified IP Phone 7906G
Cheers!
Rob
"Why do the best things always disappear "
- The Band
11-13-2013 06:42 AM
Hi there,
for this to work
Cheers!
Rob
- The Band
11-13-2013 07:58 AM
Fantastic, thanks! your quick answer has just trumped my 2 hours of googling...
