05-30-2011 01:07 AM - edited 03-16-2019 05:11 AM
Is there anyway for a handset on a FXS port to transfer a call ??
I appreciate that they do not have softkeys like 'call pickup' 'call park' 'transfer' 'conference'
Is there a way of using the keypad
- for example press '**4' to pickup or '**6' to transfer
Any help appreciated !
Solved! Go to Solution.
06-02-2011 07:38 AM
I did the STCAPP config and registered my analog wireless phone but can not transfer or pick-up calls. When I press "R" button it closes the connection. I changed the timing hookflash-in values samething happenes. I can not use the fauture codes too.
telephony-service
fac standard
voice-port 0/0/3
timing hookflash-in 120
ephone-dn 73 dual-line
number 101 no-reg primary
pickup-group 1
label Tls
description PhoneA Analog
name Tls
ephone 14
device-security-mode none
mac-address DA2F.E68E.2003
max-calls-per-button 2
username "analog1"
type anl
button 1:73
stcapp ccm-group 1
stcapp
stcapp feature access-code
prefix *#
call forward all 2
call forward cancel 9
stcapp supplementary-services
port 0/0/3
fallback-dn 101
UC_520#show stcapp device summary
Total Devices: 1
Total Calls in Progress: 0
Total Call Legs in Use: 0
Port Device Device Call Dev Directory Dev
Identifier Name State State Type Number Cntl
0/0/3 AN1DA2FE68E2003 IS IDLE ALG 101 CME
UC_520#show stcapp feature codes
malicious call ID (MCID) ***
prefix *#
call forward all *#2
call forward cancel *#9
pickup local group *#3
pickup different group *#4
meetme-conference *#5
pickup direct *#6
forward-to-voicemail *#7
cancel call waiting *#8
stcapp feature speed-dial disabled
stcapp call-control mode is standard mode
and ideas what I am missing?
05-30-2011 01:40 AM
Configure FXS port for SCCP mode (described in documentation).
Register such port to CM or CME as if it was an ephone (also described in documentation) and assign it a DN.
You will be able to use flash for transfer and keypad sequences for other features.
05-30-2011 07:36 AM
So its possible ! Any pointers towards documentation - examples ?
05-30-2011 07:39 AM
I found this
http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxssccpsplmft.html
looks like it hits the mark
05-30-2011 10:20 AM
Correct.
Please remember to rate useful posts clicking on the stars below.
06-02-2011 07:38 AM
telephony-service
fac standard
voice-port 0/0/3
pickup-group 1
label Tls
name Tls
ephone 14
username "analog1"
type anl
button 1:73
stcapp ccm-group 1
stcapp
prefix *#
call forward all 2
port 0/0/3
fallback-dn 101
Total Devices: 1
prefix *#
pickup direct *#6
06-02-2011 08:41 AM
To be honest with you, having given you the exact information you needed, then been rated only "3" in return, that is not really the best incentive to further help.
06-03-2011 12:47 AM
Today I tried with different analog phone and it worked, but it did not worked with wireless analog phone
