Translate rule 2921
Hello Friends,
I´m programming 2921 Cisco and translate rules, but calls can´t go from PSTN to internal numbering. My public numbers are 2414 83XX and 2414 84XX (2xE1 PRI ISDN). PSTN sends me last three digits (3XX and 4XX). My internal numbering is 63XX and my telephone cisco test is 6301. . What kind of translate rule can i do?  Can i see or monitoring the incoming calls after the translation rule? What command can i use?
GATEWAY 2921
GW-Sede-Sjoaquin#sh run
Building configurat
Current configuration : 6156 bytes
! Last configuration change at 18:31:08 UTC Wed Jun 5 2013 by utalca
version 15.2
hostname GW-Sede-Sjoaquin
boot-start-marker
boot-end-marker
card type e1 0 0
no aaa new-model
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip cef
no ipv6 cef
isdn switch-type primary-net5
trunk group LR
hunt-scheme round-robin
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  h225 h245-address on-connect
modem passthrough nse codec g711alaw
voice class codec 100
codec preference 1 g729r8
codec preference 2 g711ulaw
codec preference 3 g711alaw
voice class h323 200
  h225 timeout tcp establish 3
  h225 timeout setup 3
voice translation-rule 1
rule 1 /\(3..$\)/ /6\1/
rule 2 /\(4..$\)/ /6\1/
voice translation-rule 2
voice translation-profile incPSTN
translate called 1
voice translation-profile incPSTN2
translate called 2
license udi pid CISCO2921/K9 sn FTX1712AJLK
hw-module pvdm 0/0
username utalca privilege 15 password 0 utalca
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/0/1
framing NO-CRC4
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.200.10.2 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.200.10.2
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.200.10.1
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
trunk-group LR
voice-port 0/1/1
trunk-group LR
voice-port 0/1/2
trunk-group LR
voice-port 0/1/3
trunk-group LR
voice-port 0/0/1:15
voice-port 0/2/0
trunk-group LR
voice-port 0/2/1
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.200.1.5 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register CFBbofaeb92b8d0
dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 4
associate application SCCP
dial-peer voice 1000 pots
description Llamadas PSTN
destination-pattern 92[2-9]......
direct-inward-dial
port 0/0/0:15
forward-digits 8
dial-peer voice 1001 pots
description Llamadas Emergencia
destination-pattern 91[3-4].
direct-inward-dial
port 0/0/0:15
forward-digits 3
dial-peer voice 1002 pots
description Llamadas Informaciones
destination-pattern 910.
direct-inward-dial
port 0/0/1:15
forward-digits 3
dial-peer voice 1003 pots
description Llamadas 600
destination-pattern 9600.......
direct-inward-dial
port 0/0/1:15
forward-digits 10
dial-peer voice 1004 pots
description Llamadas 800
direct-inward-dial
port 0/0/1:15
forward-digits 9
dial-peer voice 1005 pots
description Llamadas LDN
destination-pattern 9188T
direct-inward-dial
port 0/0/1:15
prefix 188
dial-peer voice 1006 pots
description Llamadas LDI
destination-pattern 91880T
direct-inward-dial
port 0/0/1:15
prefix 1880
dial-peer voice 5000 voip
description Anexos Internos
destination-pattern ....
session target ipv4:10.200.1.5
incoming called-number .T
voice-class codec 100
voice-class h323 200
dtmf-relay cisco-rtp h245-alphanumeric
ip qos dscp cs5 media
dial-peer voice 1007 pots
description Llamadas Celulares
destination-pattern 909[5-9].......
direct-inward-dial
port 0/0/0:15
forward-digits 10
dial-peer voice 56 pots
translation-profile incoming incPSTN
direct-inward-dial
port 0/0/0:15
dial-peer voice 57 pots
translation-profile incoming incPSTN2
preference 2
direct-inward-dial
port 0/0/1:15
dial-peer voice 1008 pots
description Desborde Llamadas PSTN
preference 2
direct-inward-dial
port 0/0/1:15
forward-digits 8
dial-peer voice 1009 pots
description Desborde Llamadas Celulares
preference 2
direct-inward-dial
port 0/0/1:15
forward-digits 10
dial-peer voice 1010 pots
description Desborde Llamadas de Emergencia
preference 2
direct-inward-dial
port 0/0/1:15
forward-digits 3
dial-peer voice 1011 pots
trunkgroup LR
description Respaldo PSTN
preference 3
direct-inward-dial
forward-digits 8
dial-peer voice 1012 pots
trunkgroup LR
description Respaldo Celulares
preference 3
direct-inward-dial
forward-digits 10
dial-peer voice 1013 pots
trunkgroup LR
description Respaldo Emergencias
direct-inward-dial
forward-digits 3
gatekeeper
shutdown
call-manager-fallback
max-conferences 4 gain -6
transfer-system full-consult
ip source-address 10.200.10.2 port 2000
max-ephones 55
max-dn 110
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
TRACE DEBUG
GW-Sede-Sjoaquin#terminal monitor
% Console already monitors
GW-Sede-Sjoaquin#debug isdn q931
debug isdn q931 is              ON.
GW-Sede-Sjoaquin#
*Jun 18 15:57:36.825: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0068
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x0183, '0981080968'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0xA1, '301'
                Plan:ISDN, Type:National
        Sending Complete
*Jun 18 15:57:36.825: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x8068 cal
lID = 0x0088 switch = primary-net5 interface = User
*Jun 18 15:57:36.833: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x
8068
*Jun 18 15:57:36.845: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0
x8068
        Cause i = 0x80A6 - Network out of order
*Jun 18 15:57:37.237: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x00
68
*Jun 18 15:57:37.237: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x8068
*Jun 18 15:58:13.841: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x01D9
                Standard = CCITT
        Sending Complete
*Jun 18 15:58:13.841: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x81D9 cal
lID = 0x0089 switch = primary-net5 interface = User
*Jun 18 15:58:13.849: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x
81D9
*Jun 18 15:58:13.861: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0
x81D9
*Jun 18 15:58:13.997: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x01
D9
*Jun 18 15:58:13.997: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x81D9terminal monitor
81D9
x81D9
D9
GW-Sede-Sjoaquin#
*Jun 18 16:01:53.893: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x1246
                Standard = CCITT
        Progress Ind i = 0x8283 - Origination address is non-ISDN
        Calling Party Number i = 0x0183, '22090466'
        Sending Complete
*Jun 18 16:01:53.893: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x9246 cal
lID = 0x008A switch = primary-net5 interface = User
*Jun 18 16:01:53.901: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x
9246
*Jun 18 16:01:53.913: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0
x9246
*Jun 18 16:01:54.265: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x12
46
*Jun 18 16:01:54.265: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x9246
12 Replies 12
Chris Deren
rule 1 /\(^3..\)/ /6\1/
rule 2 /\(^4..\)/ /6\1/
voice translation-profile Test
translate called 1
Apply to voice-port(s) as
voice-port 0/0/0:23
translation-profile incoming Test
To monitor use "debug voice translation"
HTH,
Chris
Chris,
I made you told me, but the problem goes on. The call don´t pass.
¿dial-peer or voice port?
GATEWAY 2921
translate called 1
translate called 2
direct-inward-dial
port 0/0/0:15
preference 2
direct-inward-dial
port 0/0/1:15
voice-port 0/0/0:15
voice-port 0/1/0
trunk-group LR
voice-port 0/1/1
trunk-group LR
voice-port 0/1/2
trunk-group LR
voice-port 0/1/3
trunk-group LR
voice-port 0/0/1:15
voice-port 0/2/0
trunk-group LR
voice-port 0/2/1
Please provide:
debug voice dialpeer
debug isdn q931
Chris
Now it doesn't work. I called, but there isn't anything Chirs
GW-Sede-Sjoaquin#debug voice dialpeer
voip dialpeer default debugging is on
GW-Sede-Sjoaquin#debug voice translation
VoIP Translation Rule debugging is enabled
GW-Sede-Sjoaquin#
Did you type in "term mon"?
Chris
GW-Sede-Sjoaquin#
*Jun 18 21:37:28.936: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x1985
                Standard = CCITT
        Calling Party Number i = 0x0181, '24139496'
        Sending Complete
*Jun 18 21:37:28.936: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x9985 callID = 0x00DE switc
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_voiceport_internal: Found
rofile incPSTN defined on voice-port
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
   Voice port 0x33035738 dsl=0 timeslot=1 does not belong to any trunk group
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset
g=0
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_subst_internal: Error: ruleset for
alling number not found
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_match_internal: Matched with rule
in ruleset 1
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/RXRULE/sed_subst: Successful substitution; pattern=301 mat
Pattern=(^3..) replacePattern=6\1 replaced pattern=6301
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_type: Match Type = none, Replace
ype = none Input Type = national
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace
lan = none Input Plan = isdn
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=24139496, Called Number=6301, Voice-Interface=0x33035738,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=56
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
   Calling Number=24139496, Called Number=6301, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/RXRULE/regxrule_match: No match; number=6301 rule preceden
=1
=2
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_match_internal: No match found
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_subst_internal: Number parameters
not match ruleset in profile incPSTN
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=6301, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=6301
   Result=Success(0) after DP_MATCH_DEST
*Jun 18 21:37:28.940: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=5000
g=0
in ruleset 1
g=0
edirect-called number not found
*Jun 18 21:37:28.940: //-1/1C008F808063/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x330BAAE
count=1
*Jun 18 21:37:28.940: //-1/1C008F808063/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x316
4A0
*Jun 18 21:37:28.944: //-1/1C008F808063/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack
x330BAAE0; count=1
*Jun 18 21:37:28.944: //-1/1C008F808063/RXRULE/regxrule_profile_translate_internal: number=2413949
type=unknown plan=isdn numbertype=calling
*Jun 18 21:37:28.944: //-1/1C008F808063/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset
g=0
*Jun 18 21:37:28.944: //-1/1C008F808063/RXRULE/regxrule_profile_match_internal: Error: ruleset for
*Jun 18 21:37:28.944: //-1/1C008F808063/RXRULE/regxrule_profile_translate_internal: No match: numb
=24139496 type=unknown plan=isdn
*Jun 18 21:37:28.944: //-1/1C008F808063/RXRULE/regxrule_profile_translate_internal: number= type=U
NOWN plan=UNKNOWN numbertype=redirect-called
g=0
= type=UNKNOWN plan=UNKNOWN
*Jun 18 21:37:28.944: //-1/1C008F808063/RXRULE/regxrule_profile_translate_internal: number=6301 ty
=national plan=isdn numbertype=called
*Jun 18 21:37:28.944: //-1/1C008F808063/RXRULE/regxrule_match: No match; number=6301 rule preceden
=1
=2
*Jun 18 21:37:28.944: //-1/1C008F808063/RXRULE/regxrule_profile_match_internal: No match found
=6301 type=national plan=isdn
*Jun 18 21:37:28.944: //-1/1C008F808063/DPM/dpMatchPeersCore:
*Jun 18 21:37:28.944: //-1/1C008F808063/DPM/dpMatchSafModulePlugin:
   dialstring=6301, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
*Jun 18 21:37:28.944: //-1/1C008F808063/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
*Jun 18 21:37:28.944: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=6301, Called Number=6301, Peer Info Type=DIALPEER_INFO_SPEECH
*Jun 18 21:37:28.944: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jun 18 21:37:28.944: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Jun 18 21:37:28.944: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6301, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=5000
   Result=SUCCESS(0)
   dialstring=6301, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
*Jun 18 21:37:28.944: //-1/1C008F808063/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x330BAAE
count=1
*Jun 18 21:37:28.944: //-1/1C008F808063/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x316
4A0
x330BAAE0; count=1
*Jun 18 21:37:28.948: //-1/1C008F808063/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x330BAAE
count=1
*Jun 18 21:37:28.948: //-1/1C008F808063/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x316
4A0
*Jun 18 21:37:28.948: //-1/1C008F808063/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack
x330BAAE0; count=1
*Jun 18 21:37:28.948: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x9985
*Jun 18 21:37:28.960: //-1/1C008F808063/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
*Jun 18 21:37:28.960: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x9985
*Jun 18 21:37:29.300: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x1985
*Jun 18 21:37:29.300: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x9985
*Jun 18 21:37:29.300: //-1/1C008F808063/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x330BAAE
count=1
*Jun 18 21:37:29.300: //-1/1C008F808063/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x316
4A0
Your issue is with " Cause i = 0x80A6 - Network out of order"
As seen in the debugs call is translated to 6301 and dial-peer 5000 is matched, then you get this error message. Do you have H323 GW properly configured in CUCM?  Can you make an outbound call using this circuit?
Chris
Chirs,
Your help please...
GW-Sede-Sjoaquin#csim start 924139496
csim: called number = 924139496, loop count = 1 ping count = 0
*Jun 19 13:45:51.992: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=924139496, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=924139496
*Jun 19 13:45:51.992: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jun 19 13:45:51.992: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1000
     2: Dial-peer Tag=1008
     3: Dial-peer Tag=1011
     4: Dial-peer Tag=5000
*Jun 19 13:45:51.992: //-1/xxxxxxxxxxxx/RXRULE/regxrule_vp_translate: No profile found in voice por
or trunk group for outgoing direction
*Jun 19 13:45:51.992: //-1/xxxxxxxxxxxx/RXRULE/regxrule_vp_translate: calling_number= calling_octet
0x0
        called_number=924139496 called_octet=0x0
        redirect_number= redirect_type=4294967295 redirect_plan=4294967295
*Jun 19 13:45:51.992: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0082 callID = 0x8009 switch
*Jun 19 13:45:51.996: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0082
                Standard = CCITT
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Called Party Number i = 0x80, '24139496'
                Plan:Unknown, Type:Unknown
*Jun 19 13:45:52.188: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8082
*Jun 19 13:45:52.704: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x8082
        Progress Ind i = 0x8284 - Call has returned to the ISDN
*Jun 19 13:45:52.884: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8082
*Jun 19 13:46:12.832: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8082
*Jun 19 13:46:12.832: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0082
*Jun 19 13:46:13.732: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8082
        Cause i = 0x8090 - Normal call clearing
*Jun 19 13:46:13.732: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0082
*Jun 19 13:46:13.764: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8082
csim err csimDisconnected recvd DISC cid(217)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
GW-Sede-Sjoaquin#
*Jun 19 13:46:15.832: //-1/641EB439822D/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
This originates the call from the GW and verifies nothing for us as we know GW answers call fine, what I was interested in is wheatear the CUCM handles it, please make the same call from a real IP phone registered to the CUCM.
Chris
Chris,
The call does not enter at 2921 gw.
________________________________________________________________________
sh run
voice translation-rule 3
translate called 1
translate called 2
direct-inward-dial
port 0/0/0:15
preference 2
direct-inward-dial
port 0/0/1:15
voice-port 0/0/0:15
voice-port 0/1/0
trunk-group LR
voice-port 0/1/1
trunk-group LR
voice-port 0/1/2
trunk-group LR
voice-port 0/1/3
trunk-group LR
voice-port 0/0/1:15
voice-port 0/2/0
trunk-group LR
voice-port 0/2/1
controller E1 0/0/0
framing NO-CRC4
controller E1 0/0/1
framing NO-CRC4
no ip address
encapsulation hdlc
no cdp enable
no ip address
encapsulation hdlc
no cdp enable
no ip http server
ice_____________________________________________________________________
GW-Sede-Sjoaquin#debug voice ccapi inout
voip ccapi inout debugging is on
GW-Sede-Sjoaquin#
*Jul  5 14:34:23.692: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x1AFA
                Standard = CCITT
        Sending Complete
*Jul  5 14:34:23.696: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x9AFA callID = 0x013D switch
*Jul  5 14:34:23.696: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
*Jul  5 14:34:23.696: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=24139496, Called Number=301, Voice-Interface=0x33035738,
*Jul  5 14:34:23.696: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   Calling Number=24139496, Called Number=301, Voice-Interface=0x0,
*Jul  5 14:34:23.696: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_match_internal: Matched with rule 1
in ruleset 1
*Jul  5 14:34:23.696: //-1/xxxxxxxxxxxx/RXRULE/sed_subst: Successful substitution; pattern=301 match
*Jul  5 14:34:23.696: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_type: Match Type = none, Replace T
*Jul  5 14:34:23.696: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace P
*Jul  5 14:34:23.696: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jul  5 14:34:23.696: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
*Jul  5 14:34:23.696: //-1/D23D8EFA80C2/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=24139496
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=301
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Jul  5 14:34:23.696: //-1/D23D8EFA80C2/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x33035738, Call Info(
   Calling Number=24139496,(Calling Name=)(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentati
on=Allowed),
   Called Number=301(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=56, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Jul  5 14:34:23.696: //-1/D23D8EFA80C2/CCAPI/ccCheckClipClir:
   In: Calling Number=24139496(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=24139496(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
*Jul  5 14:34:23.696: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jul  5 14:34:23.696: :cc_get_feature_vsa malloc success
*Jul  5 14:34:23.696:  cc_get_feature_vsa count is 1
*Jul  5 14:34:23.696: :FEATURE_VSA attributes are: feature_name:0,feature_time:856336176,feature_id:
470
*Jul  5 14:34:23.696: //470/D23D8EFA80C2/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=24139496(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=All
owed),
   Called Number=301(TON=National, NPI=ISDN))
*Jul  5 14:34:23.696: //-1/D23D8EFA80C2/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x330BAC98;
count=1
*Jul  5 14:34:23.696: //-1/D23D8EFA80C2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x316EC
4A0
*Jul  5 14:34:23.696: //470/D23D8EFA80C2/CCAPI/cc_process_call_setup_ind:
   Event=0x325BA0E0
*Jul  5 14:34:23.696: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 301
*Jul  5 14:34:23.696: //470/D23D8EFA80C2/CCAPI/ccCallSetContext:
   Context=0x34813514
   >>>>CCAPI handed cid 470 with tag 56 to app "_ManagedAppProcess_Default"
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0
x330BAC98; count=1
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/RXRULE/regxrule_profile_translate_internal: number=24139496
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset ta
g=0
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/RXRULE/regxrule_profile_match_internal: Error: ruleset for c
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/RXRULE/regxrule_profile_translate_internal: No match: number
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/RXRULE/regxrule_profile_translate_internal: number= type=UNK
g=0
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/RXRULE/regxrule_profile_match_internal: Error: ruleset for r
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/RXRULE/regxrule_profile_translate_internal: number=301 type=
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/RXRULE/regxrule_profile_match_internal: Matched with rule 1
in ruleset 1
in ruleset 1
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/RXRULE/sed_subst: Successful substitution; pattern=301 match
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/RXRULE/regxrule_subst_num_type: Match Type = none, Replace T
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace P
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/RXRULE/regxrule_profile_translate_internal: xlt_number=6301
xlt_type=national xlt_plan=isdn
*Jul  5 14:34:23.700: //470/D23D8EFA80C2/CCAPI/ccCallProceeding:
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/DPM/dpMatchPeersCore:
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/DPM/dpMatchSafModulePlugin:
*Jul  5 14:34:23.700: //-1/D23D8EFA80C2/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
*Jul  5 14:34:23.700: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jul  5 14:34:23.700: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jul  5 14:34:23.700: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Jul  5 14:34:23.700: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
*Jul  5 14:34:23.700: //470/D23D8EFA80C2/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=5000, Params=0x34807D74, Progress Indication=NULL(0)
*Jul  5 14:34:23.700: //470/D23D8EFA80C2/CCAPI/ccCheckClipClir:
   Destination Pattern=...., Called Number=6301, Digit Strip=FALSE
   Calling Number=24139496(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=6301(TON=National, NPI=ISDN),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=D23D8EFA-E4B6-11E2-80C2-B0FAEB92B8D0, Outgoing Dial-peer=5000
*Jul  5 14:34:23.700: //470/D23D8EFA80C2/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=24139496
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=6301
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Jul  5 14:34:23.700: //470/D23D8EFA80C2/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x320F4FD0, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=24139496,(Calling Name=)(TON=Unknown, NPI=ISDN, Screening=User, Passed
   Called Number=6301(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=5000, Call Count O
n=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Jul  5 14:34:23.700: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jul  5 14:34:23.700: :cc_get_feature_vsa malloc success
*Jul  5 14:34:23.700:  cc_get_feature_vsa count is 2
*Jul  5 14:34:23.700: :FEATURE_VSA attributes are: feature_name:0,feature_time:856335952,feature_id:
471
*Jul  5 14:34:23.704: //471/D23D8EFA80C2/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
*Jul  5 14:34:23.704: //471/D23D8EFA80C2/CCAPI/ccCallSetContext:
   Context=0x34807D24
*Jul  5 14:34:23.704: //470/D23D8EFA80C2/CCAPI/ccSaveDialpeerTag:
*Jul  5 14:34:23.704: //471/D23D8EFA80C2/CCAPI/ccGetMediaClassTag:
   media class tag 0
*Jul  5 14:34:23.704: //471/D23D8EFA80C2/CCAPI/ccSetMediaclassIp2ipTags:
   media class tags set: NR 0, ASP 0
*Jul  5 14:34:23.704: //470/D23D8EFA80C2/CCAPI/ccSetMediaclassIp2ipTags:
*Jul  5 14:34:23.704: //471/D23D8EFA80C2/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0
*Jul  5 14:34:23.704: //470/D23D8EFA80C2/CCAPI/ccGet_xc_nr_asp_info:
*Jul  5 14:34:23.704: //-1/D23D8EFA80C2/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x330BAC98;
count=1
*Jul  5 14:34:23.704: //-1/D23D8EFA80C2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x316EC
4A0
*Jul  5 14:34:23.704: //-1/D23D8EFA80C2/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0
x330BAC98; count=1
count=1
4A0
x330BAC98; count=1
*Jul  5 14:34:23.704: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x9AFA
*Jul  5 14:34:23.720: //471/D23D8EFA80C2/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x320F4FD0, Call Id=471
   Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
*Jul  5 14:34:23.720: //470/D23D8EFA80C2/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
*Jul  5 14:34:23.720: //471/D23D8EFA80C2/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=471
*Jul  5 14:34:23.720: //471/D23D8EFA80C2/CCAPI/ccCallDisconnect:
   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
   Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
*Jul  5 14:34:23.720: //471/D23D8EFA80C2/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
*Jul  5 14:34:23.720: //471/D23D8EFA80C2/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x320F4FD0, Tag=0x0, Call Id=471,
   Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
*Jul  5 14:34:23.720: //-1/D23D8EFA80C2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
   Call Disconnect Event Sent
*Jul  5 14:34:23.720: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jul  5 14:34:23.720: :cc_free_feature_vsa freeing 330AA648
*Jul  5 14:34:23.720:  vsacount in free is 1
*Jul  5 14:34:23.720: //470/D23D8EFA80C2/CCAPI/ccCallDisconnect:
   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*Jul  5 14:34:23.720: //470/D23D8EFA80C2/CCAPI/cc_api_get_transfer_info:
*Jul  5 14:34:23.720: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x9AFA
*Jul  5 14:34:24.056: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x1AFA
*Jul  5 14:34:24.056: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x9AFA
*Jul  5 14:34:24.056: //470/D23D8EFA80C2/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x33035738, Tag=0x0, Call Id=470,
*Jul  5 14:34:24.056: //-1/D23D8EFA80C2/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x330BAC98;
count=1
*Jul  5 14:34:24.056: //-1/D23D8EFA80C2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x316EC
4A0
*Jul  5 14:34:24.060: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jul  5 14:34:24.060: :cc_free_feature_vsa freeing 330AA728
*Jul  5 14:34:24.060:  vsacount in free is 0
Claudio,
Please get "debug h225 asn1" along with "debug voip ccapi inout"
Additionally if possible provide the CCM traces detailed from RTMT?
Regards, Avinash
Nishant Savalia
Level 4
Level 4
Could you please tell me the IP address that you see in CUCM where you have configured your H.323 gateway.
"Network out of Order" (cause value = 38) comes when there is mismatch between IP address to which your H323 is bind in your gateway configuration from the IP address that you see in CUCM.
I think in your case, gateway is sending h225 call setup message to cucm with some different source IP address which infact CUCM is not aware of that IP address. Hence CUCM is releasing the call with "Network Out of Order" which you can check with debug h225 asn1 or try to fetch trace from CUCM.
Regards, Nishant Savalia
